Water leak
Discussion in '1st Gen. Tacomas (1995-2004)' started by ponethousand, May 2, 2013.
  1. May 2, 2013 at 7:51 AM
    ponethousand
    ponethousand [OP] Well-Known Member
    Paul
    Virginia Beach
    04 trd dc limited
    regeared, locked, armor, and stuff
    Anybody with a first gen ever experience water leaking on the front passenger side bottom wall closest to the door? It's not totally soaked but when it rains a few drops seems to come in by the wall near the floor of the passenger side. It has been raining a few days and I took the truck to work and noticed that my floor mat was collecting water. Wondering where I should start checking. Thanks in advance for your help.
  2. May 2, 2013 at 8:13 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    There is a TSB on this. IIRC there was a bad sealing job around the lower firewall on the pass side. The fix was just a bead of sealer on the joint. Sorry but I don't remember the exact spot.
    You mentioned "when it rains" so AC condensate issues should be discounted.
  3. May 2, 2013 at 8:29 AM
    ponethousand
    Paul
    Virginia Beach
    04 trd dc limited
    Yup I just found the TSB. I'm going to try and tackle this one and put sealant where it needs to be.
  4. May 2, 2013 at 9:13 AM
    Aquatic Tacoma
    Aquatic Tacoma Well-Known Member
    Odessa, Fl.
    2019 Tacoma TRD Sport 4x4 Dbcb , 2004 Tacoma S-Runner
    Both are Stock - built correct from the start.
    I've had the same problem for a while now. Flushed the ac drain, thought it might be the windshield seal. Where can I find the TSBs?
  5. May 2, 2013 at 9:32 AM
    ponethousand
    Paul
    Virginia Beach
    04 trd dc limited
  6. May 2, 2013 at 1:35 PM
    Aquatic Tacoma
    Odessa, Fl.
    Thanks much ponethousand.
