Water leaking in passenger floorboard
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tacoman00, Jan 5, 2022.
  1. May 4, 2022 at 1:43 PM
    Hobadger
    Hobadger Well-Known Member
    Mark
    2021SuperwhiteTRD4×4offroad
    Cold air intake - CAT-BACK
  2. May 4, 2022 at 1:46 PM
    thomasburk
    thomasburk Keep on Truckin'
    Tom
    Tampa, FL
    2020 OR DCLB AT
  3. May 4, 2022 at 1:47 PM
    Hobadger
    Mark
    Does yours have a sunroof? If not, was you running your AC?
  4. May 4, 2022 at 1:48 PM
    thomasburk
    Tom
    Tampa, FL
    2020 OR DCLB AT
    No sunroof, and yes I'm in Florida and run the AC most all the time due to humidity, and not using recirculation button.
  5. May 4, 2022 at 1:52 PM
    gfk
    gfk Well-Known Member
    I’m in FL and had the exact same issue in my 2017. What fixed it was getting hit from behind while stopped by a car going 65mph ☠️
  6. May 4, 2022 at 1:57 PM
    thomasburk
    Tom
    Tampa, FL
    2020 OR DCLB AT
    Oh my gawd, exactly what happened to my 2006 Tacoma, it was perfect. Shaking my head.
  7. May 4, 2022 at 2:08 PM
    Hobadger
    Mark
    Here's the problem, it's a Toyota engineering design problem, which I'm going to get hammered for suggesting on here that something is wrong w/ a Toyota, but who cares! Lol. I have a lemon law lawsuit breeding right now, so I know why water is on passenger side mat and on carpet when running AC in hot humid conditions as due many others on here but most just accept it or just gotta be a smartass! THE OUTSIDE OF THE HVAC BOX WHICH IS INSIDE OF VEHICLE SWEATS WHEN RUNNING IT IN HOT HUMID CONTIONS ON LONG DRIVES AND DRIPS DOWN INSIDE OF VEHICLE ONTO THE MAT AND CARPET! Toyota Corp is aware of this problem but it's not a safty issue, only a money issue for them, so they just say, operating as designed! I know because I watched the dealer take glove box out to expose HVAC BOX and and it was literally enveloped on the outside of box w/ water and dripping!
    thomasburk[QUOTED] likes this.
  8. May 4, 2022 at 2:19 PM
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    Why are you guys running a/c without recirc?
    clownkillerloaf and cryptolime like this.
  9. May 4, 2022 at 2:34 PM
    Hobadger
    Mark
    One of the sale pitches when I was shopping around was, auto climate control, set to the desired temp and it adjust automatically when to recirc or fresh air mode. Lol. Oh well, I tried the recirc mode manually as was recommended by dealer and Toyota headquarters, but it still dripped. Driving around town or a short trip, no problem, no dripping, but a steady drive @ highway speeds or above for an extended time, like close to an hour is when mine does it!
  10. May 4, 2022 at 2:51 PM
    musicisevil
    Alaska
    2019 TRD Sport
    I respect the desire for “set it and forget it” but we still have to use our heads...
    Using a/c without recirc is just flushing money down the toilet, regardless of wether the condenser sweats or not.
    It was 35 degrees on my way to work this morning and auto still picked a/c. I really don’t care if the truck thinks it’s too humid in the cab or outside or whatever, I’m not paying for the gas to use a/c while heating the truck lol
  11. May 4, 2022 at 3:19 PM
    Hobadger
    Mark
    Your right, but just because your AC light is illuminated on your button doesn't mean ac compressor is actually engaged ! Mine also illunates on chilly morning when I have heater or defrost on but ac compressor is not on or operating like it does when it's hot. Oh well, hopefully most don't have water leaking on the floor mat and carpet like some of us, but I have seen a few threads on here w/ the same problem, so it does happen, just I never owned a vehicle or ridden in one that leaks water from the operating the ac and the HVAC BOX SWEATING AND DRIPPING inside of vehicle!
    musicisevil[QUOTED] likes this.
  12. May 4, 2022 at 3:45 PM
    Gen2 Man
    Gen2 Man Well-Known Member
    Midwest
    07 Sport DCLB
    3rd Gen Sport wheels
    Would it surprise you to find out the issue you described was also happening to Gen 2 models? Numerous service bulletins and fixes confirms Toyota is well aware of this problem but like the rusty frame problem which goes back 20 plus years it confirms that the company doesn’t care too much. How else do you explain problems that span decades without resolution?
  13. May 4, 2022 at 4:00 PM
    Hobadger
    Mark
    Doesn't surprise one bit, I just didn't know if it was only 3rd Gen. The explanation is pretty simple, it's all about the money, unless it is a safty issue that they determine will cost them more in the long run w/ lawsuits, they as do all manufactures are not gonna spend money on an inconvenience as water dripping on the floor, the only reason Toyota had a recall w/ the 3rd brake,light leaking water inside of vehicle wasn't because of going in the vehicle, but the potential of it shorting out the 3rd brake light and them getting sued for defective equipment! It's always all about the money my friend!
  14. May 4, 2022 at 4:28 PM
    thomasburk
    Tom
    Tampa, FL
    2020 OR DCLB AT
    Fresh air is tastier to me than recirculated.
    atpage, 4Stents and AxisCab like this.
  15. May 4, 2022 at 4:40 PM
    #35
    HisDad
    HisDad Well-Known Member
    Texas at last
    2019 Cement Tacoma SR5 Double Cab
    Found this out with my wife's '07 Highlander. It happened about the same time we got a new windshield, so it took a while to sort out. They make brushes that will help clean them out.
  16. May 13, 2022 at 4:54 PM
    #36
    Smokes
    Smokes Well-Known Member
    Same issue but it’s under the mat or carpet. Going to run the ac and check for condensation. The carpet stinks.
    cryptolime likes this.
  17. May 16, 2022 at 6:17 AM
    #37
    Gen2 Man
    Midwest
    07 Sport DCLB
    Recirculating the cabin air removes humidity and drops the temp further both of which makes you feel cooler. Best advice is to comply with all the known water leak areas outlined in the TSBs then before exiting the vehicle turn AC off and run fan on high for at least 3 to 5 minutes to dry the condenser. Ive tried this and viola no more stale smell coming out the vents. It’s definitely a design problem that Toyota doesn’t care to address. You can buy the deodorant foam to clean condenser and then do what I’ve mentioned above. What have you got to lose?
    cryptolime, AxisCab and musicisevil like this.
  18. May 23, 2022 at 6:48 PM
    #38
    Miguel@87
    Miguel@87 New Member
    Miguel
    98 toyota tacoma prerunner 2.7 4l
    I have the same issue with a few drops of water in the passenger floor mat i just noticed it about a week ago is the second time that i see water this happened may/20/2022 i have a 2021 so i been having my truck a lilbit more than a year 30k miles on it and im trying to see in how can i fix it
  19. May 23, 2022 at 6:58 PM
    #39
    thomasburk
    Tom
    Tampa, FL
    2020 OR DCLB AT
    Good luck on finding a solution. You can do it! I'm with you thinking there's got to be a solution.
  20. May 23, 2022 at 9:13 PM
    #40
    k20pham
    k20pham Well-Known Member
    KP
    2019 taco
    Canadian Caber likes this.
