Water Leaking on Passenger Side
Discussion in '1st Gen. Tacomas (1995-2004)' started by bellassaiw10, Apr 27, 2011.
  1. Apr 27, 2011 at 4:41 PM
    bellassaiw10
    bellassaiw10 [OP] Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    Like the title says, when i use my ac water leaks all over my passenger floor mat, pretty sure the condenser hose came off or is blocked, but i was wondering if anyone had a diagram of this :confused::confused:
  2. Apr 27, 2011 at 4:44 PM
    beefcake
    beefcake J-rob
    J-Rob
    Central California
    98 4WD V6
    Debadged,Deck Plate mod, Helix throttle body spacer, magnaflow two chamber, smoked corner marker lamps, cb radio, smoked headlights, grillcraft mesh grill, URD short throw shifter, ultagauge, billstein 5100 front struts, spidertrax 1.25 spacers on all four
    does your ac still function properly?
  3. Apr 27, 2011 at 4:45 PM
    Bamfs01
    Bamfs01 Well-Known Member
    Magnetic Gray TRD Offroad. Locker, ATrac, DAC
    Stock leaf pack with TSB AAL, Wheelers progressive 3 leaf AAL, and Bilstein 5100's in the rear. Front OME coilovers with 885 coils. Cab mount chop. http://www.tacomaworld.com/forum/wheels-tires/37734-how-tire-rub-cab-mount-mod.html rcbs204 4x4 Illuminated Switch. http://www.tacomaworld.com/forum/lighting/68173-rcbs204-4x4-illuminated-switch.html JBL P963 6x9's and an MTX 10" sub wired inline to the stock HU with a MTX Jackhammer 404 amp. Rear diff breather relocation mod.
  4. Apr 27, 2011 at 4:50 PM
    bellassaiw10
    Currituck NC
    yeah still comes out cold as S$^t
  5. Apr 27, 2011 at 4:50 PM
    bellassaiw10
    Currituck NC
    and i have a 1st gen
  6. Apr 27, 2011 at 5:55 PM
    Awesome
    Awesome Member
    Justin
    Austin TX
    96 Taco 4x4
    Your drain tube is clogged. if you have access to shop air, blow air up in the tube (get under the truck) then water should start pouring out of the tube. may be better to disconnect the tube from the evap case and blow air into the other end of the tube so you dont blow the gunk into your case.
  7. Apr 27, 2011 at 9:10 PM
    bellassaiw10
    Currituck NC
    Can i get to the hose form under the truck or do i need to take some stuff out in the cab
  8. Apr 29, 2011 at 10:35 AM
    Aquatic Tacoma
    Aquatic Tacoma Well-Known Member
    Odessa, Fl.
    2019 Tacoma TRD Sport 4x4 Dbcb , 2004 Tacoma S-Runner
    Both are Stock - built correct from the start.
    Good question. I get water on the passenger side floor when it rains, not from the ac. Yeah..... the windows are up, ha ha. Haven't been able to find the source yet.
  9. May 4, 2011 at 12:23 AM
    beefsteak
    beefsteak Active Member
    TRD 4x4
    Grey Wire mod, Eibach and bilstein 5100s all around, Alcan leafsprings, tundra brake swap with steel lines, loose steering column weld mod, keyless/alarm mod
    I just unclogged mine cause it was leaking all over the passenger side floor. If you look under your dash under the glove compartment, there's a rubber tube that's about 1.5-2inches long at the bottom back right corner of that big black cooling unit box, that goes through the firewall to the other side. That's the tube that you need to unclog. If you follow the that tube to the engineside, you'll see it come out of the firewall as an aluminum curved tube about 2-3 inches long curved toward the ground and enclosed by a rubber boot. What I did was just go under the dash and disconnect the tube from the black cooling box and push the whole tube through the firewall and the whole assembly dropped onto the ground underneath the car. I then unclogged it and put it back on in reverse. Just be careful as you disconnect the tube from the cooling box under the dash, all the water that couldn't drain through the tube will start gushing. so make sure you have something handy to redirect and catch that water so it doesn't go all over your floor.
    and no, you don't have to take your dash apart, you should be able to see it pretty clearly under the glove compartment
  10. May 4, 2011 at 6:32 AM
    bellassaiw10
    Currituck NC
    Ok thanks, got one more exam then back home for the summer so ill do it within the next couple of days
  11. May 4, 2011 at 6:36 AM
    Kevlar1267
    Kevlar1267 Well-Known Member
    Kevin
    Minneapolis
    2002 Tacoma SR5 4x4 2.7
    Magnaflow exhaust,K & N filter,Bilstein Shocks
    On my 2002 I had someone whos big foot must of cracked the condensior(sp) box and had a crack in it and found water on my passenger side floor mat. I thought it was too much to pull everything out and replace the piece. I bought just the bottom half of the plastic box it was only like $17.00 back in 2005. I just cut the bottom of the box and glued it to the bottom of the broken one and never leaked again..
