Water leaking through speaker grill?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoManTaco, Nov 25, 2018.
  1. Jan 22, 2019 at 8:28 AM
    #61
    TacoManTaco
    TacoManTaco [OP] Well-Known Member
    Thanks all for the input -
    I have watched a lot of videos about taking off the door panel and it does look easy. I ordered the trim removal tool from Amazon. I plan to take off the door on Sunday morning as it will be warmest on Sunday. Anything to watch out for when removing the panel? The only thing that looks a bit tricky is removing the green and white wires where the door handle/lock are.
    What additional tools will I need to remove the speaker from the mount so I can look behind there?
    I plan to take a lot of pictures and post them up here - what should I be looking for exactly?
    Thanks all.
  2. Jan 22, 2019 at 9:52 AM
    #62
    solscooter
    solscooter Sh!t Outta Luck
    Brian
    Minnesota
    2016 TRD OR DCSB 4x4
    A screw driver or a set of sockets to remove the speaker is all you need
  3. Jan 22, 2019 at 11:56 AM
    #63
    runmc
    runmc Well-Known Member
    Ron
    DFW Texas
    2021 Army Green Tacoma TRD OR DCSB
    One Mod after another
    ********* has videos on you tube showing how to take the door panel off.
    shakerhood likes this.
  4. Jan 22, 2019 at 5:49 PM
    #64
    TacoManTaco
    Thanks, i watched all the videos. The only thing that looks tricky is removing the green and white wires behind the door. Anything to be careful about when removing them?
  5. Jan 22, 2019 at 6:20 PM
    #65
    HTOWN4X4
    HTOWN4X4 Well-Known Member
    2017 DCSB MGM 4X4
    Is not hard at all, but if you don't want to pull the green & white wires you can also remove the handle with the wires attached. The door handle just clips from top and bottom of it.
  6. Jan 22, 2019 at 7:20 PM
    #66
    TacoManTaco
    The taco tunes video mentioned something about being careful with those green and white wires or you might snap them. What exactly do i need to watch out for?
  7. Jan 22, 2019 at 7:30 PM
    #67
    HTOWN4X4
    2017 DCSB MGM 4X4
    There is a better video to watch. It is about installing the OEM sound system. There is nothing special about those wires, just remember how you take them out. If you have problems putting them back, you can always look at the other door.
  8. Jan 22, 2019 at 8:12 PM
    #68
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    They are not wires they are cables, i'm guessing the video you watched recommended making sure they are "snapped" back in place. Door panel removal on these trucks is extremely simple, maybe a 2 on a 1 - 10 difficulty scale.
    HTOWN4X4 likes this.
  9. Jan 23, 2019 at 2:55 AM
    #69
    runmc
    Ron
    DFW Texas
    Start taking off the panel from the bottom. If you don't unhook the cables it would be great. It's a little tricky getting them to stay in place during re-install. That was the only thing I had problems with. Take lots of reference pictures.
  10. Jan 23, 2019 at 3:15 AM
    #70
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Did they cut into or partially remove the plastic seal behind the door panel?
  11. Jan 23, 2019 at 11:57 AM
    #71
    TacoManTaco
    20190119_220601.jpg 20190120_112838.jpg 20190123_135023.jpg 20190123_135030.jpg 20190123_135035.jpg 20190123_135039.jpg 20190123_135140.jpg 20190123_135614_HDR.jpg 20190123_135620.jpg 20190123_135843_HDR.jpg
    Success!!!!
    Getting the door off was a piece of cake. I don't know why I didn't do it myself to start with. Lots of pics below.
    My observations. It is not raining today, so this is residual water from the last rain:
    The water shield looks intact and fine. Didn't see any rips anywhere.
    I only saw water in two places. One was at the bottom of the water shield, where I am pointing my finger. I don't see how this could get all the way to the speaker grill holes to leak through, so I don't think this is it.
    I also saw water on the bottom of the speaker, and when I took off the speaker and flipped it over, there was water at the bottom of the mounting bracket. Seems like maybe water is getting in from behind the speaker, and getting between the mounting bracket and speaker, then leaking out the holes.
    Bunch of pics. What do you guys see??
    Also it looks like she installed the speaker upside down inside the mounting bracket- does that matter for anything?
    Next time it rains, I will again take the panel off and inspect again.
  12. Jan 23, 2019 at 4:04 PM
    #72
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Id run a hose over the door with it shut and the panel off and see if I see anything.
    rsimi72 and shakerhood like this.
  13. Jan 23, 2019 at 4:13 PM
    #73
    HTOWN4X4
    2017 DCSB MGM 4X4
    Yep, that's what I'll do
  14. Jan 23, 2019 at 5:44 PM
    #74
    TacoManTaco
    OK thanks all I will take another look.
    While I am back there I will change the wiring harness as the sound has been crackling. I have a cable with a white and black wire - do I just pull these two wires out from the speaker, and plug the new cable in its place? Is there anything special about disconnecting/reconnecting the cable? And then, do I follow the cable up to where it connects to the door and plug it in? Never changed a harness before. Thanks.
  15. Jan 23, 2019 at 6:42 PM
    #75
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Not me but search threads in audio/video, I saw someone did a while ago
  16. Jan 26, 2019 at 10:58 AM
    #76
    TacoManTaco
    So, how to I change the harness? Do the white and black plugs just pull out of the speaker? Anything special to watch out for?
  17. Jan 26, 2019 at 12:41 PM
    #77
    ABA180
    East Bridgewater MA
    Just unplugs, from the look of it this is nothing
  18. Jan 26, 2019 at 6:39 PM
    #78
    TacoManTaco
    Do you think this would do the job for sealant?
    https://www.homedepot.com/p/Fabral-...:{0:1}+pt:{tape}:pt+dln:{571652}+qu:{tape}:qu
  19. Feb 6, 2019 at 7:49 AM
    #79
    TacoManTaco
    Ok -
    I think the problem I am having is related to the drip guard on the factory speaker bracket. Here is a pic of the factory speaker. You can see the bracket has a water shield along the top half of it, so when water gets into the door panel, it hits the drip guard on the bracket and drips off the side.
    My aftermarket speaker brackets do not have this drip guard. I think the water is hitting the speaker, dripping around it to the bottom, and then pushing its way through the door panel speaker grill. This is also why the aftermarket speakers sound like crap when it is cold, because all the water on the speaker turns to ice.
    Are there any speaker brackets that have this drip shield on it that I could use with my aftermarket speakers? What about a speaker baffle like:
    https://www.crutchfield.com/p_237XT69/XTC-6-x9-Speaker-Baffles-5-depth.html
  20. Feb 6, 2019 at 8:12 AM
    #80
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    That’s still a very abnormal amount of water getting in. Looks as if some water is coming in from above the speaker. I’m still very suspicious of your window seals. I would leave the panel off the door shut it and start drenching it with a hose. See if you can tell where the water is making entry. Also if it’s getting in around the speaker I think most would remain around there. Water takes the least resistant path. One of your pics showed the entire door bottom with water dripping off it. Maybe it’s because the door was shut. Looks like it was coming from behind the entire panel. Either was it was a lot of water there shouldn’t of been that much making its way behind the seals
