water leaking under dashboard
Discussion in '1st Gen. Tacomas (1995-2004)' started by mattgray44, Oct 1, 2008.
  1. Jun 19, 2024 at 10:30 AM
    scocar
    scocar hypotenoper
    Make sure you seat those O rings correctly.
    HondaGM[QUOTED] likes this.
  2. Jun 19, 2024 at 10:36 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Funny you should bring that up..Had a few problems with those,but finally figured out i had to Lap them in with Comet..
  3. Jun 19, 2024 at 11:31 AM
    Dare Devil Diablo
    Dare Devil Diablo Well-Known Member
    2000 TRD Offroad MT
    FYI, if the problem is your heater core you will smell antifreeze.
    If no smell then your AC condenser drain is clogged.
  4. Jun 21, 2024 at 6:34 AM
    TexasTacoLT
    TexasTacoLT Well-Known Member
    Killeen, TX
    '14 TRD Offroad
    3" Lift (ToyTech Coilovers and AAL) Bilstein 5100 Shocks Total Chaos UCAs Method Double Standard 17" BFG All-Terrain T/A KO2 (Removed) 33" BFG Mud Terrain Tires Colormatched Grill surround HomerTaco mesh grill insert Legacy "Toyota" Emblem Shrockworks plate rear bumper All-Pro plate front bumper w/ foglights All-Pro rock sliders Smoked Tail-lights DIY Steel Tailgate reinforcement Locking Tailgate handle Tint (15%) w/ sunstrip Tyger Tonneau cover (Removed) Bestop Soft Topper Bushwhacker colormatched fender flares DIY 8-ball shift knob DIY Amber LED grill lights DIY Debadged WeatherTech floormats Sudued US Flag door decals T-100 style tailgate decal Two way radio w/ 3' whip antenna Warn 8000lb winch CalTrend Neoprene seat covers DIY Bed tie-down anchors
    Yeah, the end of the drain is just a nearly horizontal, forward facing, open-ended tube in the engine bay. Not an ideal design; it'll clog again eventually no doubt. Just going to keep that piece of weed trimmer line in the glovebox so I can clear it out if it ever happens again; only takes a minute. If it happens again soon I may try to figure out a more permanent solution, but clearing it out every year or so is no big deal.
