water/meth
Discussion in 'Performance and Tuning' started by colby8100, Aug 30, 2013.
  1. Aug 30, 2013 at 1:44 PM
    colby8100
    colby8100 [OP] Well-Known Member
    Colby
    South carolin
    01 Tacoma 1jz lowered
    Lowered,leather interior,system,1jz swap,rims,painted bumpers mirrors ect
    Had anyone here ever made their own kit. I got a 1gpm@35psi pump for now eventually going to a 1.8gpm. My question is what did yall use for a nozzle and how do you know how much to spray.?
  2. Aug 31, 2013 at 2:20 PM
    DonziGT230
    DonziGT230 Gearhead
    Oscar
    Hacienda Hts, Ca.
    '07 base taco. Sold. Now Taco-less
    Factory cruise added, wood storage box in bed, wood center console/armrest, charcoal air filter delete.
    Those are generally only used with forced induction; you boosting?
  3. Sep 1, 2013 at 7:29 PM
    colby8100
    Colby
    South carolin
    Yea 2jz in a 01 taco through a th400. The set up should be around 1200hp at the crank so around 1100 at the wheels.
  4. Sep 2, 2013 at 7:52 AM
    DonziGT230
    DonziGT230 Gearhead
    Oscar
    Hacienda Hts, Ca.
    Damn sweet....and I have no clue about your nozzle question. I was just checking because I've seen some N/A guys asking about these thinking they're like a magical nitrous power adder.
  5. Sep 2, 2013 at 8:26 AM
    colby8100
    Colby
    South carolin
    It adds normally about 10hp n/a with no retune because of the cylinder temp drop.if you added a good bit of timing or upped the compression you could get huge gains n/a.I think I'm going to go with an adjustable 5gph nozzle with a 2gph high pressure pump. That seems to be what the dsm forums are using over 1000hp.
  6. Sep 2, 2013 at 8:34 AM
    RockyMtnTRD
    RockyMtnTRD Wanderlust.
    Noah
    Colorado
    '11 TRD OR
    hack job
    In for the meth... :eek:
  7. Sep 3, 2013 at 7:44 AM
    DonziGT230
    DonziGT230 Gearhead
    Oscar
    Hacienda Hts, Ca.
    I won't argue what's working, but if the pump had more output than the nozzle flow you could get a nice misting which seems like it'd be better than a stream. My curiosity, as much as it is a suggestion.
  8. Sep 3, 2013 at 5:06 PM
    colby8100
    Colby
    South carolin
    You want a fine mist. The nozzle is adjustable (the one I'm looking at )
  9. Sep 4, 2013 at 9:33 AM
    DonziGT230
    DonziGT230 Gearhead
    Oscar
    Hacienda Hts, Ca.
    I bought some new washdown pumps for one of my boats. After much searching, the best deal I found for high output was TRAC. It's rated at 5.3 gpm and 70psi, bought on amazon for $120. I haven't measured the output, but it's about on par with an average home garden hose using an average hose nozzle on it. Tho the literature doesn't state it, it looks to have an adjustment screw for the pressure cut-out switch. These only run on demand so it can be powered all the time and it waits for a pressure drop before resuming pumping. It's a 5 chamber diaphragm pump and there's very little if any noticeable pulsing. I don't know if methanol will damage the rubber in it, assuming not, but(?). Your other option would be an impeller or vane pump. Harbor freight has both (utility marine pump I think), but don't have the automatic pressure cut-out; could add one in-line or just run it on demand.
  10. Sep 8, 2013 at 8:35 PM
    trdtoy
    trdtoy Well-Known Member
    North Carolina
    02 sr5 4x4 auto v6 turbo (sold)
    Turbo with supporting mods and tranny to hold power.
    Do not make your own setup. Get a devilsown progressive kit. Less than $500 and one heck of a kit for the money. Ran this on a 420whp/500wtq 3.4/5vz and 600whp/1100wtq 5.9 cummins with great results. On your setup start with say 5% water vs fuel being injected and check gains while increasing to 20% or so at most water vs fuel injected. You will find a point where spraying more will not benefit you and this will be dependent on many variables. When calculating remember meth must be factored in as fuel not as part of water mix.
  11. Nov 19, 2013 at 2:06 AM
    lunch box
    lunch box diesel mechanic
    2000 trd tacoma
    diff lock grey wire mod k&n77series cold air intake 2nd gen s/c water meth injection 7th injector urd 5100s lift all the way around add a leaf new excedy clutch and rear main seal scan guage 2 wet okole covers.bazooka tube.& some minor body stuff.TRD supercharger,URD 7th injector kit
    texas ace has a utube vid where he tests different nozzles I think the one he liked best was a devils own nozle for like 20 bucks, but im useing snow performance.
