Water noise behind drivers dashboard?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pster, Dec 27, 2010.
  1. Dec 27, 2010 at 1:47 PM
    Pster
    Pster [OP] Well-Known Member
    Charlotte, NC
    2006 Tacoma 4x4
    Bak Flip bed cover, shorty antenna, Peripheral iPod interface, Garmin 750 mount, add'l bed tie down rings, Westin nerf bars, hitch safe, tailgate lock, Ideal 1 3/4" turn-key clamp to secure tailgate from removal, Spare tire security cable, spare tire stainless air hose extender, Fumoto oil drain valve, Amp Research Bed X-Tender w/Schlage Cable Lock, bed mat, Redline hood struts
    I could swear I am hearing what sound like water sloshing around behind the dash in front of me. Has anyone heard this? Could there be water in the vents behind the dash?
  2. Dec 27, 2010 at 2:24 PM
    Enzo
    Enzo Well-Known Member
    Opie
    Bedford, Va
    2012 FJ Cruiser
    2012 FJ Cruiser Maggiolina Medium Grand Tour w/winter hood National Luna dual battery split charging system ABR Sidewinder Aux battery tray ARB 50qt Fridge w/Transit Bag Bajarack flat rack w/ladder Crawlarado flat black hood blackout TRD exhaust Trasharoo Outback FJ roof console
    Maybe your AC condensation tube is stopped up?
  3. Dec 27, 2010 at 2:26 PM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    I have seen posts about this, but they all seem to refer to drains on the passenger side. This is coming from behind or under the dash in front of the driver. No water on floorboards.
  4. Dec 27, 2010 at 2:26 PM
    DriverSound
    DriverSound Señor Member
    SoCal
    15 DCSB OR 4x4 & 17 AC SR 4x4
    Too few to list.
    Check your coolant. Most likely, you have air in your system.
  5. Dec 27, 2010 at 2:28 PM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    Water engine coolant or A/C coolant?
  6. Dec 27, 2010 at 2:43 PM
    DriverSound
    SoCal
    Too few to list.
    Radiator motor coolant. It will sound like a water trickling sound noise. Usually happens when there is air in the system even if the radiator is filled.
    When cold, take radiator cap off and run the truck with the heat on high. The water level in the radiator should come down. Add coolant. When it's filled, the coolant will slowly overflow. Time to put your cap back on.
  7. Dec 27, 2010 at 2:45 PM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    Thanks, I'll try that! :)
