Water, not Coolant, in Cylinders 4/6
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JRsTallToy, Dec 2, 2024.
  1. Dec 2, 2024 at 4:59 AM
    JRsTallToy
    JRsTallToy [OP] Member
    Northern Virginia
    2012 Tacoma, 2019 Tacoma
    2012—Lift, 20x10 XDs 295/60/20 2019–Stock TRD Sport
    My son’s 2019 Taco is at the dealer for the second time with a misfire code on Cylinder 4 and going into limp mode. I am not satisfied with the dealer’s theory on the problem.
    The truck was at the dealer for the same issue 2 weeks ago. Cylinders 4/6 are getting water inside. The dealer conducted the following diagnostics:
    1. compression tests-normal
    2. Cooling system pressure test-passed
    3. Unsure if they performed a leak down test
    4. Vehicle is not overheating
    Regardless, I have water in cylinders 4/6. I suspected a head gasket, cracked head, or cracked short block. However, the dealer denies any of these as possibilities.
    They claim that water, but not coolant, is in cylinders 4/6—possibly caused by a missing plastic cover that goes over the coil packs on the drivers side. Supposedly there could be water running down the cowling and falling on the head, then entering through the coil and subsequently into the spark plug hole. I do not agree because there is no source of water. The truck may have been exposed to rain one time in 2 weeks, but was not on the night it threw the codes.
    Any ideas before these guys clean me out from diagnostic charges?
  2. Dec 2, 2024 at 5:16 AM
    Sungod
    Sungod Well-Known Member
    St Augustine
    What? If water could get past the spark plug, combustion would easily blast through the other direction. That makes zero sense. Only logical way for water to enter would be through condensation and even that would be almost impossible and minimal at best.
    Head gasket is the most likely culprit.
    I'm curious as to how they determined it was water. Taste?
  3. Dec 2, 2024 at 5:25 AM
    JRsTallToy
    Northern Virginia
    They said it was clear rather than pink.
  4. Dec 2, 2024 at 5:25 AM
    Clearwater Bill
    Billy
    Largo Florida
    That is a whole new level of having smoke blown up your skirt.
    Assuming this is not under an extended warranty, find a quality independent shop and get a proper diagnosis.
    If it is under warranty, find another dealer.
    Phlogiston, dleithaus, bfonic and 2 others like this.
  5. Dec 2, 2024 at 5:27 AM
    JRsTallToy
    Northern Virginia
    Im with you. None of this makes logical sense. But I don’t understand why there’s no coolant in the oil and it passes compression tests.
  6. Dec 2, 2024 at 6:29 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    So they are claiming that rain water got into your engine internals? That is one gifted diagnostic technician!
  7. Dec 2, 2024 at 6:58 AM
    JRsTallToy
    Northern Virginia
    Update—they aren’t charging me to do the proposed repair, so I’ll let them do the work and see if the cylinders fill up again. I asked the tech to show me the cover that was missing, which he did. Still not convinced…
    soundman98 and kahanabob like this.
  8. Dec 2, 2024 at 7:06 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Are you sure they're saying "water inside the cylinders"?
    or just water "in the spark plug tubes"?
    Maybe something is getting lost in translation
    soundman98 and Evostaco like this.
  9. Dec 2, 2024 at 7:07 AM
    JRsTallToy
    Northern Virginia
    I asked exactly this question. Inside cylinders was the response.
  10. Dec 2, 2024 at 7:08 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Time to find a new mechanic
  11. Dec 2, 2024 at 7:44 AM
    Clearwater Bill
    Billy
    Largo Florida
    Could you literally watch his nose grow while he was saying that?
    BillF1564 likes this.
  12. Dec 2, 2024 at 7:46 AM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    X2
  13. Dec 2, 2024 at 7:48 AM
    jmneill
    SE
    So what's the master plan?
    For an impossible problem, he'll need, at the very least, an improbable fix...
  14. Dec 2, 2024 at 7:59 AM
    JRsTallToy
    Northern Virginia
    I guess I’ll have to see if it passes all diagnostic testing after this proposed repair is complete. The same Toyota dealer “fixed” it last time and it ran fine for about 2 weeks.
    TBH, I may just offload it if it runs fine again. I don’t want to be headed back to the dealer every couple weeks. I figure I could get only a couple thousand less than I paid from a dealer and just cut my losses. The good news is this is my 17 y/o son’s truck and I own it outright. He can just wait until it is either fixed or we get something else.
  15. Dec 2, 2024 at 10:36 AM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    little umbrellas over the coil packs.
  16. Dec 2, 2024 at 12:46 PM
    jmneill
    SE
  17. Dec 2, 2024 at 6:30 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    rain water getting in, is a bunch of booshit and their attempt at covering up their inability to properly diganose.
    BUT, for the sake of getting it fixed, find a used plastic cover, slap it on and take it back,, or better yet try a different dealer.
    GL
  18. Dec 2, 2024 at 7:20 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    Water getting in the intake somewhere? Air filter wet?
    Phlogiston, Evostaco and TnShooter like this.
  19. Dec 3, 2024 at 3:00 AM
    JRsTallToy
    Northern Virginia
    It is pretty disappointing to go to the Toyota dealer and get this type of illogical theory. The only thing I could think of that supports it is if water is collecting in the spark plug housing, then dropping inside when the plug is removed. Surely they would suck the water out of the housing before removing the spark plug if this was the case. But at this point nothing would surprise me.
    They insist that compression is fine and cooling system pressure test is good, even after I have asked them about the head gasket multiple times. Since they are doing this repair for free I might just trade the truck in after it is complete. If they tell me that it is good to go then they can’t argue that something is wrong with it. There’s a 2019 TRDOR with a manual transmission on the lot that’s been there a while. I might look to cut my losses to avoid several thousand dollars in a head gasket repair.
  20. Dec 3, 2024 at 3:06 AM
    JRsTallToy
    Northern Virginia
    I never considered that, but the water is only in 4/6 cylinders. Whether this or the cowl drip theory, there is no water source. It has not rained significantly at all.
    Chew likes this.
