Water on Carpet
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jjones67, Nov 18, 2009.
  1. Nov 18, 2009 at 8:42 AM
    jjones67
    jjones67 [OP] Member
    Norfolk, VA
    2006 DoubleCab TRD V6 4x4
    K&N Filter
    So there was a lot of water in Norfolk, VA last week. Unfortunately, my Tacoma got a little bit of brackish flood water on the carpet- water was up to the doors. Recommendations for getting rid of this nasty stuff other than shampooing? Maybe some steam cleaning? Thoughts?
  2. Nov 18, 2009 at 9:55 AM
    DriverSound
    DriverSound Señor Member
    SoCaca
    15 DCSB OR 4x4 & 17 AC SR 4x4
    Too few to list.
    You should just have your insurance company deal with it. They might even replace the carpet for you.
  3. Nov 18, 2009 at 12:10 PM
    jjones67
    Norfolk, VA
    K&N Filter
    not enough water to warrant insurance deductable. really the only portion is the rear driverside carpet (lowest point of the truck in the street somehow).
  4. Nov 18, 2009 at 12:21 PM
    Doc.SS
    Doc.SS ︻╦╤─
    Frank
    O'side
    T4R SR5
    there is a place on Military highway....by Indian River I believe that can clean it.
  5. Nov 18, 2009 at 12:52 PM
    swise
    swise TRIFECTA!!!
    ohio
    08 4x4 dbl cab, TRD offroad
    pull it out of the truck and dry underneath!
  6. Nov 18, 2009 at 1:23 PM
    DriverSound
    SoCaca
    Too few to list.
    You don't have to completely pull it off but get the floor panels off and a good carpet cleaner and wet/dry vac should do it. You want to make sure the underneath gets completly dry or you can develop mold or it could be a good time to pull it off and apply some sound deadning/fatmat/dynamat, etc...
  7. Nov 18, 2009 at 1:26 PM
    jlvhrse
    jlvhrse Well-Known Member
    Jen
    SoCal SGV
    2009 TRD Sport 4X4 Long Bed
    LSK front and rear LT and stuff
    Please be careful with the brackish water, it can be as bad as salt water on your truck. I lived in Norfolk, right off the Lafayette River 2 years ago when we had the two nor-easters back to back and I had water come up to the doors in my Isuzu Trooper. It ran fine for 2 weeks, then the windows started rolling themselves down, radio was playing static when the keys were not in the car, lights would turn themselves on and off.. I eventually disconnected the battery so it would stop, when the insurance adjuster came out the truck was completely dead, they totaled it.
    Personally, I would call the insurance.
    I wish you the best of luck, I know how hard it can be to deal with the aftermath of one of these storms!!
  8. Nov 18, 2009 at 2:50 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Dude that sucks!!!!:eek::mad:
  9. Nov 19, 2009 at 6:25 AM
    jjones67
    Norfolk, VA
    K&N Filter
    Yep- sucks. I called State Farm and let them know the situation, just in case I need to claim anything later on down the road. Also, I imagine I can clean it pretty well for under my $500 deductable. I did a serious detail on the outside/underbody of the truck a few days back to combat that salt water.
    Doc.SS- You have a name for that detail place on Military?
    DriverSound- fatmat/dynomat prices??? you have a ball park $? could be a great opportunity for that.
  10. Nov 19, 2009 at 6:44 AM
    obxfishn
    obxfishn Well-Known Member
    Eastern Virginia
    2.5" ToyTec Lift, Smitty Built Nerf Bars, Scangauge unit,
    That sucks...we got 10.5" of salt waterr in the Fire Station I am assigned to in Hampton...managed to get the Taco to higher ground before the flood. Went out on a rescue call and got back to the station to find the tide was up to the bottom part of my rim in the parking lot. Close call!!! Ended up with just over 2' in the parking lot.
  11. Nov 19, 2009 at 10:15 AM
    DriverSound
    SoCaca
    Too few to list.
  12. Nov 19, 2009 at 10:58 AM
    jjones67
    Norfolk, VA
    K&N Filter
    Update. Called Toyota to see what they would charge- $750 for just the dampening jute they use under the carpet. Called State Farm. Claim is in the works. Nothing like $500 deductable! Kind of hoping there is something else wrong so I at least feel like I'm getting my money's worth.
    DriverSound- might have them put that on as well.
    obxfishn- you got lucky. My roommate's Audi A6 AllRoad is the one pictured above. Other roommate drives a G35 Coupe- both are totaled. I guess I can't complain too much.
  13. Nov 20, 2009 at 10:11 AM
    DriverSound
    SoCaca
    Too few to list.
    This wouldn't have happened at all with a lift! :D You might want to add that later also.
  14. Nov 20, 2009 at 10:14 AM
    rutherk1
    rutherk1 ElPhantasmo&TheChickenRunBlastarama
    09 Silver TRD 4door
    Honestly. Take out your entire interior. It doesn't take more than an hour. All you need is a 10mm and a 12mm (i think the seat belts are 12) socket. Let everything dryout, steam clean/shampoo the carpet and you will be good to go.
    You will also have the security of knowing that is was done correctly (BY YOU!)
