Water on front passenger floor
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Moriarti2001, Mar 28, 2022.
  1. Mar 28, 2022 at 10:56 AM
    Moriarti2001
    Moriarti2001 [OP] Well-Known Member
    Cali
    2016 Tacoma Sport
    Yep
    Hay all,
    We had some rain last night, and this morning three was a whole bunch of water on my front passenger floor. I checked the cabin filter and the walls, but cannot find any moisture tracks?
    A couple weeks ago, it was the drain ports on the sunroof that left some water around the cabin lights. I got that fixed, but I am not sure where to check now.
    Any ideas?
  2. Mar 28, 2022 at 11:07 AM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    There is an active recall on the 3rd Brake Light.
    You can check by entering your VIN here https://www.toyota.com/recall
    I believe Toyota will fix your water damage and seal for free if the 3rd brake light is causing your issues.
  3. Mar 28, 2022 at 11:24 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Check under wiper cowl, see if drains are clear.
    Moriarti2001[OP] likes this.
  4. Mar 28, 2022 at 11:31 AM
    mquibble
    mquibble Well-Known Member
    Michael
    2021 TacomaTRD Pro
    Have you had your windshield replaced? If so, could be an inferior install. I had this situation on another vehicle.
  5. Mar 28, 2022 at 11:50 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    I would check those sunroof drains again just to be sure. After that, I would suspect the AC condensate drain might be the cause. I cannot see how the 3rd brake light leak would get all the way up to the front passenger floorboard area unless it was really coming in from back there.
  6. Mar 28, 2022 at 3:36 PM
    VictorFox78
    VictorFox78 Well-Known Member
    Michigan [Yooper]
    2022 DCSB LR OR
    Get inside the truck and have the wife water spray the truck with the hose while you inspect and look for the leak inside
  7. Mar 28, 2022 at 5:42 PM
    Moriarti2001
    Cali
    2016 Tacoma Sport
    Yep
    There was a lot of debris on the top vents of the cowl on either side. I cleared those. Is there a particular way tp get under the cowl to fin the drains?
  8. Mar 28, 2022 at 6:14 PM
    na8rboy
    WI
    You need to remove wiper arms, and then cowl cover. There is drains under ther, each side
  9. Mar 28, 2022 at 6:25 PM
    Moriarti2001
    Cali
    2016 Tacoma Sport
    Yep
    Thanks. I figure its gotta be the cowl drain, likely considering how much debris gathers on top of it, or the AC condenser since it is only on the passenger side, and I think that is where the condenser drain is. I'll dig into it this weekend and report back.
    Thanks everybody !
  10. Mar 28, 2022 at 6:28 PM
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    I would also suggest checking the seals on your roof, where there are pre-drilled holes for a roof rack.
    Not sure if you have a roof rack or not but when I removed my Prinsu, the holes didn’t get sealed properly and the water that entered through the holes always wound up on the passenger seat floor.
    Even if you don’t have a roof rack, I suppose its possible the factory seal on those holes has failed.
  11. Mar 28, 2022 at 6:31 PM
    na8rboy
    WI
    What happens, drains get plugged and water sloshes/slashes over into air intake for heat/ac.
  12. Mar 28, 2022 at 6:49 PM
    Moriarti2001
    Cali
    2016 Tacoma Sport
    Yep
    Interesting. I don't have a roof racks, never have. Would the holes be under those rubber liners that run down the cab?
    It seems like it might be more rain related as I rarely run the AC and it rained pretty hard last night. The truck had not moved before the water appeared, as in, I don't think it was sloshing around so much as a drain recently clogged or a plug recently failed.
  13. Mar 28, 2022 at 6:50 PM
    Moriarti2001
    Cali
    2016 Tacoma Sport
    Yep
    Maybe that Will Smith slap knocked something lose :) ha ha
  14. Mar 28, 2022 at 7:01 PM
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    Yep, they are under the rubber strips that run along the roof. I also only had the water on the floor issue when it rained.
    I’ve really only ever heard of those holes leaking when someone has a roof rack, or had one and then removed it…but anything is possible!
