Water on passenger floor
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Freeheelbillie, Jul 17, 2021.
  1. Jul 17, 2021 at 4:06 AM
    Freeheelbillie
    Freeheelbillie [OP] Well-Known Member
    Billie
    Saint Clair, MI
    2019 Tacoma SR, DCSB
    FRONT END King Stage 3 3” RR Coil Overs SPC UCA’s REAR END King Stage 3 BAMF Shock Relocation Rear AAL Heavy ARB Universal Diff Breather Kit TIRES & RIMS 16” Method Bronze BFG K02 (315/75/R16) ARMOR Demello Off Road Baja Hoop Front Bumper Main Line Overland Rock Sliders w/ Top Plate ¼” Aluminum RCI Fuel Tank Skid RCI Fuel Tank Straps RCI Rear Diff Skid RCI A-Arm Skids RCI – Front, Transmission, and rear Transfer Case Skid DRIVE LINE YotaWerx, BlackHawk Tune Re Geared w/ Nitro 4.56 Package Front ARB Air Locker Rear ARB Air Locker 8” Reverse Clamshell 3.73 & Down Carrier RECOVERY ComeUp Seal Gen2 9.5RS Winch, Synthetic Line ComeUp Seal Hawse Fairlead ARB On Board Twin Air Compressor LIGHTING Squadron-R Pro Amber Fogs (Wide Cornering) Baja Designs Rock Lights Squadron Sport Fogs (qty 4) Baja Designs Bed Light Kit SPODS, HD 8 Circuit Switch Panel
    So after a car wash I noticed some water on the floor of the passenger side. I know the 2nd gen could have a plugged AC drain…anyone have the same issue with their 3rd gen?
  2. Jul 17, 2021 at 4:12 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Do you have a sun roof? Drain may be blocked. Also check the door seal and AC.
  3. Jul 17, 2021 at 4:17 AM
    Freeheelbillie
    Billie
    Saint Clair, MI
    No sun roof…I could actually watch it dripping from behind the glovebox.
  4. Jul 17, 2021 at 4:23 AM
    rnish
    Tacoma 2nd gen
    There is a fresh air intake above the fan (behind/above the glove box). Check under the hood for blockage.
