Water Pressure Drop?
Discussion in 'Garage / Workshop' started by sammy87, Jan 5, 2015.
  1. Jan 5, 2015 at 5:35 PM
    sammy87
    sammy87 [OP] Well-Known Member
    co
    10 TRD SPORT 4X4
    Hello, Recently I noticed a drop in water pressure in my house. House is only 1 yr old, I can't see any leaks in the basement, everything seems fine. Im not handy at all. Any suggestions where to start?
    Thanks!
  2. Jan 5, 2015 at 5:43 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    Town water or well?
    If no well, do the neighbors have the same issue?
    Pressure reducing valve failing?
    Any DPW work done recently in your area?
  3. Jan 5, 2015 at 5:50 PM
    sammy87
    co
    10 TRD SPORT 4X4
    DPW?
  4. Jan 5, 2015 at 6:03 PM
    File IFR
    Central MA
    Department of public works..... street work, water works, town work... etc.
  5. Jan 5, 2015 at 6:06 PM
    sammy87
    co
    10 TRD SPORT 4X4
    Well, not that I know of. But it is a new development.
  6. Jan 5, 2015 at 6:20 PM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Are you on a water meter?
    I had to have mine replaced, tree roots clogged it up.
    After it was replaced, had more water pressure and had to adjust all of the sprinklers.
  7. Jan 5, 2015 at 6:22 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Do you have a PRV in your house ? Is there any chance the house suppy ball valve is not fully open ?
  8. Jan 5, 2015 at 6:28 PM
    sammy87
    co
    10 TRD SPORT 4X4
    Yes, I will monitor it.
  9. Jan 5, 2015 at 6:29 PM
    sammy87
    co
    10 TRD SPORT 4X4
    I doubt it, everything was fine on Thursday. Then noticed Friday it was getting bad.
    I believe I have a PRV.
  10. Jan 5, 2015 at 6:31 PM
    Idaholandho
    Idaholandho The other white meat
    3 Now - 2022 Trail Edition, 2015 TRD 4x4 and a 2006 SR5 4x4
    2015 Tacoma, Magnuson Supercharger, Bully Dog Flash and GT, Safari Snorkel, Toytec BOSS 2.5 Coil Over Front, Toytec BOSS Aluma 2.5 Rear, Toytec 10 Leaf Pack, Stainless Brake Lines, Icon UCA's, CBI Reverse Adj Shackle Mounts, CBI Ubolt Flip Kit, Timbren Bump Stops, CBI Bushmaster 2.0 Front Bumper w/ Warn M8000S Winch and SR2 Rigid Flood Lights, CBI Bushmaster 2.0 Rear Swingout Bumper, Rigid SR2 backup lights and Dual RotopaX / Fuel/First Aid Pack, CBI Rock Sliders, CBI Full Skids and CBI Rear Diff Armor, BAMF LCA Skids, FrontRunner Outfitters Slimline II Roof Rack w/ Rigid SR2 40" Combo Light Bar, Rock lights, Rigid pods in Bed Rack, Intelligent Battery System w/ Dual NorthStar batteries, Spod Power Distribution, illuminated switch panel in sunglasses holder, Viar Extreme Duty On-Board Air w/ 2.5 Gallon Tank under bed, Air 2 Air Sys, Magnaflow Exhaust, Fuel Off Road Trophy Wheels, 285/75/17 Toyo Open Country R/T, Diff breather mod, FX-R BHLM Demon Eye headlights, Esuse LED Fog Kit, Pelfreybilt Camera Relocation mount, Pelfreybilt ax/shovel bed mount, Debadged, tint, a 2006 Tacoma SR5 and a 2022 Trail Edition
    If you find no issues within your home, as Oz mentioned. Call the city as mentioned as well, asking them to do a leak check. Most municipalities will send someone out to monitor any water usage while all interior plumbing is off for free. They are able to read your meter from the street.
  11. Jan 5, 2015 at 6:51 PM
    File IFR
    Central MA
    Don't adjust it... yet.
    Have the town look into what the trouble is.
    If you adjust your PRV to a higher PSI now, the 'street problem' could clear up and you'll have more pressure than desired. 80psi is the max, otherwise you can blow up plastic components (toilet guts..etc).
  12. Jan 6, 2015 at 9:05 AM
    Indy
    Indy Master of all I survey.
    For about $5 you can get a pressure meter from any big box store and see what your actual pressure is. Beyond that, low pressure at 1 fixture or all fixtures? Does the toilet/dishwasher take longer to fill?
  13. Jan 6, 2015 at 12:25 PM
    sammy87
    co
    10 TRD SPORT 4X4
    Everything seems normal with the toilets. Mostly the shower is the most noticeable drop with the other faucets.
    I called the builder warranty dept, he said that we should expect some pressure changes with new construction.
    I will try the water utility tomorrow.
  14. Jan 6, 2015 at 2:04 PM
    File IFR
    Central MA
    New construction has nothing to do with it. That is total BS, trust me. Any plumber here will say the same.
  15. Jan 6, 2015 at 2:24 PM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    +1 on the pressure gauge. It's a good tool to have in your toolbox. Check the pressure on the sprinkler line (before entering the house) and then on the water heater drain for the inside of the house. the PRV should be set at about 50 lbs as long as the pressure is greater than that before entering the house. Also open the meter cover outside and see if it is full of water. That would be a clue that something is wrong.
    Good luck and let us know how it goes.
  16. Jan 6, 2015 at 2:32 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Is the pressure low late at night the same as in the day? Neighborhood usage will drop the pressure during high demand hours.
    Your pressure regulator (PRV) has a screen on the inlet side. Some have a separate access for cleaning the screen (Wilkins 600 for example) rather than taking the whole thing apart. The outgoing pressure is adjustable too... turning the bolt on top in, increases the pressure. Typically 50 psi is what they come set at, with a range from 25 psi to 75 psi.
  17. Jan 6, 2015 at 2:44 PM
    Clearwater Bill
    Billy
    Largo Florida
    any chance you have a water softer as the first appliance in line?
    If so, the problem could well lie there.
  18. Jan 6, 2015 at 2:57 PM
    OZ-T
    Peter North
    British Columbia
    Good one
  19. Jan 6, 2015 at 3:04 PM
    AWalker
    AWalker Well-Known Member
    Adam
    Tacoma Washington
    08 DC LB SR5
    O.M.E 885 Dakars nitros Snugtop allpro skids allpro bumper 4X inovations sliders Jayco pop up camper Torklift tiedowns
    If the city flushed the main recently or there has been heavy construction in the area it's pretty common for sediment to get trapped in you faucet aerator's and shower heads so just remove and look for sediment. If your pressure prob is the whole hose including your hose bibs then I'd check to see if your meter is running with everything at the house shut off, that would tell you if you have a leak somewhere. If none of those are the culprit then I'd move to the regulator. Mine failed and it was a PITA to replace but it was over 20 years old.
  20. Jan 6, 2015 at 3:33 PM
    David K
    This is true, but the screen in the regulator is the first place crap catches, if there is a screen.
