water puddle in tailpipe?
Discussion in 'Technical Chat' started by hawneye, Nov 27, 2006.
  1. Nov 27, 2006 at 6:12 AM
    hawneye
    hawneye [OP] New Member
    Does anyone know if intermittent water collection in the tailpipe is a cause for concern? I know that condensation build-up especially at start up is normal but I've had it happen when the truck was already running for awhile? Yesterday I purchased a 03" prerunner 3.4L with 29,000 miles & in excellent condition but when I saw the water I had 2nd thoughts. I hope this is not the start of internal coolant leaking problems (head gasket, cracked head)? I had problems in the past with my 95' Tacoma 3.4L engine (recall headgasket) in 98' & it seems like dejavu. Any thoughts? Anyway of checking? Oh, so far I am not loosing coolant & there is no steam or white smoke coming from the tailpipe. I live in Hawaii so weather condition is not a factor.
  2. Nov 27, 2006 at 8:25 PM
    archer of loaf
    archer of loaf Well-Known Member
    check the oil cap - if it has yogurt like stuff in it - it may have a broken head gasket... this is not fool proof but a pretty good way of telling... and smell the exaust - smell sweet? if so... not good at all.
    water does collect in exaust pipes - if the truck was run for short periods it would do this.
  3. Nov 27, 2006 at 10:01 PM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    Is the water clear? If so you've got nothing to worry about it's the cat doing it's job.
  4. Nov 28, 2006 at 10:41 AM
    Ldytaco05
    Ldytaco05 it's all about me
    Orlando, Fl.
    2005 PreRunner,Enkei Wheels
    did you get a history report on your vehicle. It might be a "katrina victim" the reason why is i read on orlando sentinel article that David Maus toyota sold a vehicle that was water damage. the owner was not aware of it until his son did a history check. in the end he wound up with a new vehicle(2007 camry)
  5. Nov 29, 2006 at 2:20 PM
    hawneye
    :) I think the worst is over now. I had forgot to mention that I had purchased my tacoma from a dealer. Before I questioned the dealer about the water problem I asked him if topping the fluids under the hood was a standard practice during prepping of a trade-in? His reply was not always. Had he said yes, I would have had cause for concern. Speaking of prepping, the water might have been residual after washing the truck down during prepping. Its been 2 days now since the purchase & the water puddle is gone & I topped the coolant resevoir to the full line & the level is still there, hurrah! Also, I purchased an extended full warranty on the tacoma for up to 6 years/100,000 miles for $1,200 which gives me peace of mind. Thanks to all who responded.:)
  6. Apr 26, 2021 at 10:17 AM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    the h2o U r referring to is usually a direct result of Toooooooo much idling
    essentially in Ur climate/environs will rust our the exhaust sytem
    premature kill the CAT
    not the same as a head gasket
    if U think it is do a compression check correctly
  7. Apr 26, 2021 at 1:56 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    So easy to smell the difference between Coolant and Water Vapor
  8. Apr 26, 2021 at 2:01 PM
    MDFM31
    MDFM31 Well-Known Member
    Chester Co, PA
    16 DCSBOR
    As long as it does not smell like coolant or oil, you should be good. Water vapor is a product of combustion and will collect on the cooler exhaust pipe. All good :thumbsup:
  9. Apr 26, 2021 at 2:07 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    vssman and MDFM31 like this.
  10. Apr 26, 2021 at 4:45 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    RedWings44 likes this.
  11. Apr 26, 2021 at 5:39 PM
    MDFM31
    Chester Co, PA
    16 DCSBOR
    This must be a record. I didn't even notice
