Water Pump and Timing Belt
Discussion in '1st Gen. Tacomas (1995-2004)' started by Afraz, Oct 25, 2012.
  1. Oct 25, 2012 at 11:29 PM
    Afraz
    Afraz [OP] Well-Known Member
    Toronto
    03 Double Cab TRD
    Projector H.I.D
    Hey Guys,
    I was wondering, what should i get done when i am looking to get the water pump and timing belt done ?
    Is there anything else that needs to be taken care of during this time ?
    I jst hit 205,000 km on my tacoma and heard this needs to be fixed every 100,000 km, but i was wondering should i buy a timing belt kit or just the belt it self ?
    Does anyone have links to good quality parts that i should look into ? or would any company that makes aftermarket parts do the job just as well ?
    Any help regarding this will be greatly appreciated.
    Thank You
    Afraz
  2. Oct 26, 2012 at 8:33 AM
    BamaToy1997
    BamaToy1997 ASE Master Tech Vendor
    Bill
    Navarre, FL
    Multi-point tow hooks, new bored 2.7L engine, custom paint. 3 inch adjustable Fabtech front coils, 2.5 inch rear AAL. Front Aussie locker. LED bed lights. Full LED conversion interior and exterior. Relentless Fabrication front and rear bumpers. 4X4innovation sliders. BAMF bed rack. CVT rooftop tent.
    Assuming you have the V6, I suggest replacing the water pump, the timing belt, the front seal, camshaft seals, and the other two timing belt pulleys (tensioner and idler) that are behind the timing cover.
  3. Nov 5, 2012 at 6:48 AM
    Afraz
    Toronto
    03 Double Cab TRD
    Projector H.I.D
    Are all these which you mentioned available as a package somewhere ? or do they have to be bought individually ?
  4. Nov 5, 2012 at 6:59 AM
    stucksucksnayota
    stucksucksnayota Well-Known Member
    Barry
    Fort Smith, Arkansas
    14 Taco 4x4 TRD Sport DCSB
    OEM roof rack, Shorty antenna (eBay), soft tonneau cover, K&N drop in air filter, bed mat, interior LED lights, 5100's, MT tires to come soon!!!
    When I do mine I buy a package that includes the timing belt and the 2 idler pulleys that ride on the timing belt maybe include something else I can't remember for sure but I think that's it. I have never changed out any of those seals as stated above and I've had no problems with the seals leaking.
    Also go ahead and install a new water pump and if your other belts (fan, power steering, alternator, ac comp) are worn out go ahead and change those out while you have it apart.
