Water pump and timing belt
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DBAlaska, Jan 23, 2013.
  1. Jan 23, 2013 at 2:00 PM
    DBAlaska
    DBAlaska [OP] Active Member
    Dave
    Alaska
    2005 Tacoma Access Cab 4x4
    When do you recommend changing out the water pump and timing belt on a 05 with a 4.0
  2. Jan 23, 2013 at 2:03 PM
    That Dude Tim
    That Dude Tim Toyota Technician
    Elyria, OH
    11 TRD Sport 4x4 DCLB
    Falken Wildpeak AT3/W, BLK Mk6, ICON's, Firestone Ride Rites, SHLM, Rear view camera switch, 7-pin in bumper, Lighted 4x4 switch, ImMrYo bracket, mudflap delete
    The 2005 up Tacomas use a timing chain and can go well over 200k miles. The water pump I'd say around 90,000 miles unless you notice a pinkish coral around the water pump, in which case it is leaking.
  3. Jan 23, 2013 at 2:50 PM
    Badgtho
    Badgtho Well-Known Member
    Ben
    CT
    '13 TRD sport 6spd
    TRD exhaust, TRD beadlock wheels, moto xtender
    How long do the ignition points last?
  4. Jan 23, 2013 at 2:57 PM
    scottw1
    scottw1 Well-Known Member
    Scott
    Norfolk, VA
    2010 SR5 Tacoma 4x4
    Lighted 4wd dial, Sirus XM radio
    Agree. The old belts were around 70-80K, the new timing chains are good for at least 200K.
  5. Jan 23, 2013 at 3:09 PM
    P9HST2
    P9HST2 Well-Known Member
    Iowa
    2012 MGM AC TRD OR
    WeatherTech floor liners, tailgate hoseclamp, Famous Fab sliders, Brute Force Fab rear bumper, Icon "3T" suspension.
    Maybe 20,000 miles with cleaning and adjustment as needed, but that's not important right now.
  6. Jan 23, 2013 at 3:11 PM
    DriverSound
    DriverSound Señor Member
    SoCaca
    2015 DCSB OR 4x4
    Too few to list.
    What about the cap and rotor?
  7. Jan 23, 2013 at 3:12 PM
    Badgtho
    Ben
    CT
    '13 TRD sport 6spd
    Oh. Ok. Phew.
    What about the hand crank starter.... Do I need to grease it?
  8. Jan 23, 2013 at 3:16 PM
    P9HST2
    Iowa
    2012 MGM AC TRD OR
    I believe I used to do the points, cap, rotor, and the plugs at the same time, but that was some time ago. Wires too if they're looking bad.
  9. Jan 23, 2013 at 3:16 PM
    DriverSound
    SoCaca
    2015 DCSB OR 4x4
    Too few to list.
    We're just messin with ya since you're new. Personally, I'd wait to replace the waterpump to 120K if there's no leak though you might want to change the serpentine belt.
  10. Jan 23, 2013 at 3:17 PM
    P9HST2
    Iowa
    2012 MGM AC TRD OR
    I might have owned a couple cars with points but I'm not THAT old! ;)
  11. Jan 23, 2013 at 3:19 PM
    DriverSound
    SoCaca
    2015 DCSB OR 4x4
    Too few to list.
    My first car was a 74 bug that I had to adjust points on. Oldest car I've ever owned was a 68 camaro but replaced the distributor with an electronic one. I've never seen a the cranks. 1920's or older?
  12. Jan 23, 2013 at 3:36 PM
    P9HST2
    Iowa
    2012 MGM AC TRD OR
    I think you're correct.
    I had a 73 Olds Delta 98 with a 455 and a 67 Plymouth with a slant 6 that I know had points. Pretty sure there were one or two more. Everything after those had HEI or similar, but you were always cleaning or replacing caps, rotors, plugs, and wires. Also rebuilt way more carbs than I care to count. People complain about how modern cars are too complex to diagnose and work on but I sure like them compared to the old stuff.
  13. Jan 23, 2013 at 3:47 PM
    DriverSound
    SoCaca
    2015 DCSB OR 4x4
    Too few to list.
    I like my 2011 but I would prefer to not have all the electronics in it. I do like EFI but carbs on bikes. Next thing you know cars will park themselves! Ah! they already have that!
  14. Jan 23, 2013 at 4:10 PM
    DBAlaska
    Dave
    Alaska
    Thanks for all the "points"
    I am so new my son tells me after I made my first post what DB stands for. Geezzzz -
  15. Jan 23, 2013 at 6:09 PM
    Fire Taco Fighter
    Fire Taco Fighter Well-Known Member
    trd
    Points.......
    Oh man I miss those days.....you can set your dwell w/ a book of matches LOL
