water pump gone @45k
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rockbug63, Feb 14, 2012.
  1. Feb 14, 2012 at 2:53 PM
    rockbug63
    rockbug63 [OP] Active Member
    central coast CA
    '09 Dbl cab 4x4 SR5 tow pkg.
    Rear leaf and steering column chatter tsb blower mtr replaced(waste of time) 2nd blw. mtr.; new headlights from DRL melt issue new water pump9 leaking0around block) pwr steering rack leaks, right frt. wheel bearing bad.
    Just found a low coolant level and checked my normal parking spot, then under main pulley. Have been leaking fluid for at least a week. Dealer did replace under warranty. (Thanks Santa Maria Toyota!) said it was a 60k item. Still on a '09 that never sees extreme hot or cold it seems way too early. Anyone else had the same problem?
  2. Feb 14, 2012 at 4:16 PM
    VermonterLost
    VermonterLost Well-Known Member
    Devin
    Castleton, VT
    2014 F150
    Don't remember the exact mileage but mine went at about 40-45K. 2006 2.7L. I got the exact mileage on another thread on here somewhere. Covered under warranty too. Hope this one lasts longer.
  3. Feb 14, 2012 at 5:42 PM
    ecoterragaia
    ecoterragaia Well-Known Member
    Mid-Atlantic
    '06 RC, 4X4, 5 speed
    Mine went at 22,000 miles and it was covered under warranty.
  4. Feb 14, 2012 at 5:46 PM
    2TRunner
    2TRunner Well-Known Member
    Ohio
    2.7 WP repl'd under warranty as well. Around the same mileage as poster #2. Appeared to have a front seal leak. No gasket leak.
    Noticed pink crap on my P/S lines, grabbed a flashlight and followed the trail.
  5. Feb 14, 2012 at 5:49 PM
    05sctaco
    05sctaco Well-Known Member
    Ken
    Santa Cruz
    Mine is going out and i have 87k, i have a new water pump in the mail.
