Water pump leak at 59,964ish!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by superminsoo, Oct 26, 2010.
  1. Oct 26, 2010 at 1:55 PM
    superminsoo
    superminsoo [OP] Well-Known Member
    I stopped by the dealer today for the pedal recall and got a call a couple hours later telling me that my water pump was leaking and that I had 40 something miles left on my warranty so it'd be covered!! Whewww.... but anyone else have their water pump leak before 100,000 miles??? Also, how do I get them to check for the TOB before I roll over 60,000? (I tried searching)
  2. Oct 26, 2010 at 2:46 PM
    supralight
    supralight Well-Known Member
    Dan
    Earth
    2013 4Runner limited
    Wow waterpump leaking on a toyota before 60k, I hope it is an isolated problem. No point in having a timing chain if you have to change the water pump every 60k.
  3. Oct 27, 2010 at 6:15 AM
    VermonterLost
    VermonterLost Well-Known Member
    Devin
    Castleton, VT
    2014 F150
    Just got back from the dealership for my 2006 2.7L. Water pump leaking at 40,500. Thank god thats covered under the 5 year warranty.
    Yours is a V6 though right?
  4. Oct 27, 2010 at 6:18 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    If you call them and they document that the complaint was filed before 60k you should be fine.
  5. Oct 27, 2010 at 9:17 AM
    superminsoo
    Wow at 40,000. Yea it's a v6. Do you know why the pumps would leak so early?
    I'm not going to be driving my tacoma until I get the TOB figured out cause I don't want to risk not getting warranty work but I'll have them document my complaint just in case.
  6. Oct 27, 2010 at 10:00 AM
    VermonterLost
    Devin
    Castleton, VT
    2014 F150
    Dunno why, something screwy there though. I just bought mine in August with 37,000 on it so it kinda sucks to have something go this quickly but again, at least it's covered. Definitely make sure they see the TOB before 60k, god only knows what kind of arguments they'd have for you then.
  7. Oct 27, 2010 at 10:30 AM
    superminsoo
    Yea. Judging by the lack of replies, it's safe to assume that the leaks are isolated incidents.
  8. Feb 21, 2012 at 11:04 AM
    vandalay
    vandalay New Member
    Largo, FL
    Tacoma 2.7L
    I have an 06 Taco 2.7L with 64,000 and my pump just started leaking this week. I too feel that is way too early. I really take exellent care of my truck and keep fresh coolant at the proper mix ratio in it at all times. I plan to replace the pump myself. It is really pretty straightforward especially since it uses a gasket and not silicone. Never had good luck with that stuff. I just ordered the pump and both upper and lower radiator hoses. I figured since I have to drain the cooling system I better go ahead and change the hoses too.
  9. Feb 21, 2012 at 12:40 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Negative. Toyota water pumps are well known for having shaft seal leakage issues. I had mine replaced before the factory warranty was up. Lack of response might be from other causes.
  10. Feb 21, 2012 at 2:22 PM
    Raylo
    Raylo Well-Known Member
    MD, USA
    2009 4x4 Access Cab, TRD Sport
    GF's 2009 Camry water pump shit the bed at 22,000 ish miles.
  11. Feb 21, 2012 at 2:25 PM
    arrrghhh
    arrrghhh Well-Known Member
    Denver, CO
    09 TRD Off-Road
    Custom Front Bumper, Smittybilt XRC-8, 3" OME lift, 33" Falken A/T tires
    Holy hell...
    Imma definitely get mine checked before the warranty runs out.
  12. Feb 21, 2012 at 2:30 PM
    4wd Boss
    4wd Boss Shake and Bake
    Jefferson
    Big D
    07 4dr 4x4 V6
    Fog Light Mod
    with all the members here, and lack of waterpump issue threads, i do not believe this is an issue anyone needs to be "worried " about. drive on!
  13. Feb 21, 2012 at 3:35 PM
    05sctaco
    05sctaco Well-Known Member
    Ken
    Santa Cruz
    I'm changing my water pump this week. I'd take pictures but it just slows me down. I read it's the seal that goes. Got all my parts at rock auto, just remember to get a gasket/o ring for the thermostat if you get one. I'm not going to flush the engine, just drain, fill, burp. The coolant is pink, doesn't smell burned. My truck is weeping like it got spanked.
