Water pump leaking at ~61,000 miles!
Discussion in '4 Cylinder' started by djkontraktor, Mar 4, 2013.
  1. Mar 4, 2013 at 12:19 PM
    djkontraktor
    djkontraktor [OP] New Member
    San Francisco
    05 Tacoma 2.7L
    Xenon bulb headlights, LED brakelights, LED turn signals, Kenwood KDC-400U deck, Sony Xplod speakers, JL Audio Micro Subwoofer, Memphis Audio tweeters, 800 watt amp, K&N Air Filter
    Hi, I have a baseline 2005 2nd gen Tacoma that has around 61000 miles on it. It's also a 2.7 4 cylinder. I got it used in 2010 with 17000 miles on it. I guess it was sitting for a while... Anyways I took it to the dealer and they said there is a coolant "seep" from my water pump. Why is this happening so early? I thought these trucks were more reliable than that... I take great care of my truck, I've always gotten oil changes on time and never had any other problems with it. I'll have to admit though... I'm sometimes a leadfoot, so that might have something to do with it.
  2. Mar 4, 2013 at 12:22 PM
    BnbBlitz
    BnbBlitz Well-Known Member
    over the rainbow
    13 DCLB 4WD
    I would inspect myself to make sure there actualy is a leak and the stealership isnt dicking you around.
  3. Mar 4, 2013 at 1:10 PM
    jassco
    jassco Well-Known Member
    NH
    2023 TRD Offroad
    My guess is the sealant/gasket has disintegrated over time and the fresh use caused something to dislodge. When you don't use machines or fluid systems they tend to have issues like leaks and things go wrong. Fluids can also have some separation after not being circulated frequently and this can obviously cause deposits and other build up. I believe the manual clearly states 100,000 miles OR 6-8 years which ever comes first for complete coolant service as a maximum. No real surprise here with even a tank, sorry
  4. Mar 4, 2013 at 1:33 PM
    StevoNB
    StevoNB Well-Known Member
    NB, Canada
    2020 DCSB TRD Sport 6MT
    I'm not too surprised to hear this, my 2009 Corolla had a leaking water pump at 95000 km. about a year ago. Luckily it was still under warranty. More and more junk seems to slip through quality control these days.
  5. Mar 4, 2013 at 5:25 PM
    djkontraktor
    San Francisco
    05 Tacoma 2.7L
    Well, good to hear that time is the big factor in its failure, and that it shouldn't happen again for a good while after I get this one replaced. It is after all 8 years old, even though it looks and drives like new.
  6. Mar 13, 2013 at 5:04 PM
    watacomaguy
    watacomaguy Active Member
    Washington
    2012 4x4
    I agree I wouldn't expect the water pump to go out but.. every vehicle manufacture out there will have some failures. 93 Ford Ranger I had spun a wheel bearing at 33K. Also was burning about a quart between oil changes at the same mileage. If you only have a few minor items go tits up on a vehicle your doing good.
  7. Mar 13, 2013 at 5:43 PM
    slo13zx3
    slo13zx3 Well-Known Member
    Brian
    forest city pa
    14 trd off 6speed nav
    water pump is a cake job. im a fat kid and i love cake
  8. Mar 26, 2013 at 5:30 AM
    ldfrank
    ldfrank New Member
    Frank
    NC
    Had to have mine replaced at 62000.My luck 2000 miles out of warranty. $425 parts and labor at dealer.
  9. Mar 26, 2013 at 6:43 AM
    BamaToy1997
    Bill
    Navarre, FL
    Yeah, the 2.7 water pump is one of the easiest jobs to do. As for failure, even the best made products will have failures. It is the cost of mass producing any product. They make 500,000 water pumps in a year for the 2.7 engine. If only 2% fail in the first year, and 3% more within 5 years, then within 5 years you will have close to 25,000 water pumps fail.
  10. Mar 26, 2013 at 10:04 AM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    My 1997 Olds with the Quad 4 engine went at 45k. It was sitting for 4 months after I crashed it so that didn't help. $700 for that job since it was in the back of the engine
  11. Mar 28, 2013 at 7:07 AM
    BamaToy1997
    Bill
    Navarre, FL
    Yeah, those are a bit of a pain since they are driven by the balance shaft chain. LOTS of work to take one of those out and replace it.
  12. Mar 28, 2013 at 8:13 AM
    ABA180
    East Bridgewater MA
    I was thrilled with the $700 price, it was the lowest by a couple hundred or so..and the guy knew his stuff so I didn't get a hack job. Then the timing chain tensioner was another issue with that job..the first time it didn't go right so the tensioner was knocking but they replaced it free.
    The single worst part is you can't really do it without a lift..
  13. Mar 28, 2013 at 9:07 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    The leak is easy to diagnose by yourself. If there's a red crust running down from the water pump's shaft, the shaft seal is leaking. They last 30-80k.
