Water Pump Maintenance Interval?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by brian2sun, Aug 29, 2022.
  1. Aug 31, 2022 at 10:12 AM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    Your thinking about it wrong.
    They suggest doing the water pump with a timing belt because its no extra labor to do the pump while you do the timing belt. It saves hours of labor down the road if the water pump pump goes bad as the timing belt has to be removed to do it.
    On newer vehicles they are driving by the serpentine belt so the labor is much less.
    kuruma1, MR E30, blu92in99 and 4 others like this.
  2. Aug 31, 2022 at 10:13 AM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    That interval was to change the timing belt. You replaced the water pump because you have it off anyway. Since we should never have our to touch the timing chains we don't need to remove the water pump. So basically its a forget about it item unless you have an issue with it.
  3. Aug 31, 2022 at 12:01 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    I'm being honest. My first new truck was an 84 4Runner. I've owned many many vehicles since then and never once (and back then I pulled all maintenance myself) did I see a water pump or tensioner maintenance spec.
  4. Aug 31, 2022 at 12:17 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    If I were an automobile manufacturer I would not likely bother to do the testing required to make a legitimate recommendation of the service life for a part beyond the warranty period.
  5. Aug 31, 2022 at 1:58 PM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I never changed the coolant in my tundra. If the dealer added some, or changed it when i did the timing belt replacements every 100k along with the new water pump as a kit, they didn't say.
  6. Aug 31, 2022 at 2:00 PM
    saint277
    saint277 Vigilo Confido
    You would need to add some amount of coolant with a water pump change, a lot leaks out when you pull the pump. Probably enough was added to keep the coolant in ok shape.
  7. Aug 31, 2022 at 2:12 PM
    Servingko
    Servingko Well-Known Member
    2022 DCSB OR MT
    I am a bit OCD on fluid replacement right down to power steering and the clutch system but tend to follow the "if it ain't broke don't fix it" philosophy. It's taken me many years to adopt that approach but it's solid advice.
    Kavanagh and zoo truck like this.
  8. Aug 31, 2022 at 2:25 PM
    C-Rok275
    C-Rok275 Well-Known Member
    2017 TRD Pro
    6112/5160s with Icon stage 2 leaf’s.
    Water pumps, alternators, etc have always been a “change when they fail” kind of thing, or change when they start making too much noise.
  9. Aug 31, 2022 at 2:32 PM
    perterra
    perterra Well-Known Member
    Tejas
    Actually, you are over thinking it. No offense intended, but as others said, it's because you have to remove the water pump when you change the timing belt, not because it has a life span. The pump wobbles or leaks, you replace.
    Chew and Brianz1001 like this.
  10. Aug 31, 2022 at 2:39 PM
    Hairless_Ape
    Hairless_Ape Well-Known Member
    South Jersey
    2021 F150
    Maintenance schedule for a water pump? Dafuq you talkin bout Willis? You replace it if/when it goes bad.
    Junkhead and Brianz1001 like this.
  11. Aug 31, 2022 at 3:00 PM
    03coma
    03coma Well-Known Member
    New Jersey
    2015 DCSB TRD, SR5
    TRD Pro Grille, Skid Plate, TRD Cat-Back Exhaust System, 2017 Tacoma TRD Rims, ARE Series II Lid,
    Toyota adapts to the changes/designs being done, look at oil changes now, a lot of their vechices are recommended 10k oil change no more 5k. If it's not broken or leaking its fine.
    Brianz1001 likes this.
  12. Aug 31, 2022 at 3:04 PM
    brian2sun
    brian2sun [OP] Well-Known Member
    California
    ‘21 TRD OR DCSB ‘17 4Runner Limited ‘97 4Runner SR5
    Again, not overthinking anything, just asking a question. I’ve owned at least 2 other Toyota trucks that did have a replacement interval on the water pump specifically, so I was simply wondering why this truck didn’t seem to as well. I understand (now) that it’s because the timing belt needed to be replaced on those models, so it was recommended to do the water pump at the same time because it’s relatively cheap, and you’re already in there. I get that… but I had to ask to find out that information. My old truck said change it out at this mileage, and my new one doesn’t… just wanted to know why. Isn’t that what these forums are for? That isn’t overthinking, it’s called just doing my due diligence to make sure this truck lasts as long as my 25 year old 4runner has.
  13. Aug 31, 2022 at 3:10 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Why so defensive brother? Your question has been answered multiple times and no one is busting your balls here. Sometimes a simple "thanks for the Intel guys" reply is all that is needed.
    MR E30, 03coma and Brianz1001 like this.
  14. Aug 31, 2022 at 3:22 PM
    Brianz1001
    Brianz1001 Well-Known Member
    Brian
    Retired on my couch with a cold beer in my hand
    too much to type
    We are talking about a Tacoma, TW is Tacoma not 4 Runner World. Not all vehicles even from the same manufacture have the same maintenance schedule.
  15. Aug 31, 2022 at 3:31 PM
    #35
    Gen2 Man
    Gen2 Man Well-Known Member
    Midwest
    07 Sport DCLB
    3rd Gen Sport wheels
    Dude take a deep breath and relax these people are giving you solid advice
  16. Aug 31, 2022 at 3:58 PM
    #36
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    wrong bryan
    Junkhead likes this.
  17. Aug 31, 2022 at 4:10 PM
    #37
    Brianz1001
    Brian
    too much to type
    Wrong guy, Brianz1001 here, not brian2sun
  18. Aug 31, 2022 at 4:49 PM
    #38
    brian2sun
    California
    Because he kept telling me I’m overthinking it after the fact. I got an answer to my question, cool, I accept it. Then for the next 2 days, people keep re-answering the same question and then acting as if I’m not accepting the original answer, and telling me I’m overthinking it. I’m not arguing with the advice given. I’m not thinking about my question at all anymore.
    2 things… 1) a 3rd gen 4runner came with the same engine options as the 1st gen Tacoma, so they have the same maintenance recommendations in regards to this. 2) I also mentioned in that same quote that my old ‘98 TACOMA has the same recommendation, so… Tacoma.
    See above. Cool, I got the answer 2 days ago. It seems just about every thread on this site gets and answer in the first couple of posts, and then it’s just page after page of the same answer over and over again, but with cool guy flexing and other bullshit.
  19. Aug 31, 2022 at 4:58 PM
    #39
    Gen2 Man
    Midwest
    07 Sport DCLB
    Honey hush
    Lt. Dangle likes this.
  20. Aug 31, 2022 at 5:59 PM
    #40
    brian2sun
    California
    It’s ok sweetie pie, I know this is what a lot of people on here do to give themselves a little ego boost when they need it.
