Water Pump mistake please advise
Discussion in '1st Gen. Tacomas (1995-2004)' started by trange, Oct 17, 2009.
  1. Oct 17, 2009 at 2:54 PM
    trange
    trange [OP] New Member
    AL
    4X4 V6 SR5
    I recently had my timing belt changed at the dealer. I am an idiot, simple as that because I didn't get my waterpump changed as well. I told them if their are no signs of the pump leaking to leave it alone. They told me the pump looked fine. 4 days later I returned to the dealer because of a coolant smell. They took it back looked at it and said they could not find any leaks. I have the service report they gave me. This weekend (4 months later) I changed my oil. The bottom of the engine is covered in antifreeze. I will be going back to the dealer when I get home. Does the waterpump have to come off during the timing belt change? I think they screwed up the pumps seal. Any guesses on what they will tell me?
    Thanks
  2. Oct 17, 2009 at 3:02 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    thats why you should do it as long as your in there..its a 50/50 shot something will leak
  3. Oct 17, 2009 at 3:14 PM
    trange
    AL
    4X4 V6 SR5
    I know, I won't make that mistake again. What a poor design having the pump driven off of the timing belt. Why didn't they use an accessory belt?
  4. Oct 17, 2009 at 3:26 PM
    MarkOlson
    MarkOlson Gray beard
    Mark
    San Jose, CA
    03 Tacoma Regular Cab
    You need to get this dealt with right away. When oil mixes with ethylene glycol, it turns into a very thick sludge that will clog your oil passages. If that happens, it is time for a new engine (or a complete cleaning during the rebuild).
  5. Oct 17, 2009 at 3:34 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Do you have the 3.4L?
    If yes..then ... NO, the water pump does not get removed to change only the timing belt.
    Here's a write-up on how to change the water pump only on a 3.4L.
    http://www.lieblweb.com/tacoma/Mechanical/WaterPump/WaterPump.htm
    More often - the gasket that seals the water pump to the block wears /leaks. Atleast, that's what mine did. The actual pump/bearings were fine. Don't forget to change the thermostat too!
  6. Oct 17, 2009 at 3:51 PM
    Tsenekos
    Tsenekos Well-Known Member
    Greg
    Edmonton, CANADA
    2005 DC 4WD trd offroad
    Toytec 3" lift w coils,1.5 AAL,5100's all around,diff drop kit, axel shims,N-Fab nerf bars,bestop supertop,fog mod, weathertech mats
    I think you mean the outside of the engine was covered in anti freeze?? but I would get it looked at as soon as you can, good luck
  7. Oct 17, 2009 at 4:26 PM
    trange
    AL
    4X4 V6 SR5
    Yes, it is the V6. I'm going to see what the dealer says before I try the water pump diy, which is probably the route I will take if I have to.
    Thanks for the link and the info.
    Greatly apprieciated!
  8. Oct 17, 2009 at 5:18 PM
    kevhogaz
    kevhogaz Low Speed, High Drag
    Queen Creek, Arizona
    SR5 PreRunner
    3" lift front & rear, Air Raid Intake System
    You should have had it done with the T-belt. This is definitely one of those Murphy's laws kind of deals. I hate to be the bearer of bad news, but you're basically gonna pay to do the T-belt all over again.
    If you declined the work, the dealers not gonna eat the labor, especially on a 3.4 water pump. As a Toyota tech, I ALWAYS say do 'em both at the same time, and this is why.
  9. Oct 17, 2009 at 5:46 PM
    MarkOlson
    Mark
    San Jose, CA
    Phew!
  10. Oct 17, 2009 at 6:15 PM
    BeefTaco
    BeefTaco WESTern Alliance: NORCAL COAST
    Santa Cruz County Ca.
    X2
    You should also look at the cam and cranks seal's while you or they are in there.
  11. Oct 17, 2009 at 9:29 PM
    trailinTaco
    trailinTaco Well-Known Member
    Bel Air, MD
    2000 Tacoma SR5 TRD 3.4L 4x4
    3 inch suspension lift, 33 inch bfgoodrich mud terrain tires, toytech diff drop, Procomp alloy wheels, hella fog lights, black projector headlights with 8000k HID's, blacked out tail lights, two 12 inch subs, 20% tint, pioneer head unit and speakers
    you may need a new timing belt again cause if any coolant got on the belt its bad and they say to change it.
