Water pump or fan clutch
Discussion in 'Technical Chat' started by Tennessee98, Feb 17, 2020.
  1. Feb 17, 2020 at 1:11 PM
    Tennessee98
    Tennessee98 [OP] Well-Known Member
    2007 Tacoma supercharged
    Have 2007 tacoma with 4.0 V6. When I start the truck the radiator fan is wobbly when spinning. Makes a squeaking noise also. I have the original water pump still. Mileage is 322,000. The weep holes are slowly leaking coolant so I just ordered a new Asian water pump. My question is do you think the bearings in the water pump are causing the fan to wobble or is it the fan clutch. No overheating yet. Thanks
  2. Feb 19, 2020 at 10:07 AM
    12tinker
    12tinker Well-Known Member
    dan
    MA
    08 Off Road
    engine swap (stuck valve @260K)
    get a fan clutch and return it if you don't need it after doing the water pump
    probably will need a belt and an idler pulley or two I can bet
    gotoman1969 and whatstcp like this.
  3. Feb 19, 2020 at 12:54 PM
    Tennessee98
    Ok thanks.
