water pump pulley help
Discussion in '1st Gen. Tacomas (1995-2004)' started by Baby, Dec 8, 2009.
  1. Dec 8, 2009 at 7:14 PM
    Baby
    Baby [OP] Member
    Novato, CA
    03 Tacoma 3.4
    I think my power steering pump pulley bearings are on their way out. (Squeaking quieted by a spray of lube.) Can I replace the bearings or the entire pulley or will I need to replace the entire pump? If the bearings are replaceable, can anyone tell me what size and how many bearings? Thanks.
  2. Dec 8, 2009 at 7:18 PM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    09 DC 4x4 Blown Honda VTEC V8
    trd exhaust,step bars,vent visors,bed lights,tailgate mod
    sure its not the belt?i dont think if it was bearing noise you could stop it with spray lube.
  3. Dec 8, 2009 at 7:26 PM
    Firefighter160
    Firefighter160 Well-Known Member
    Josh
    Eastern VA
    05 DCSB Offroad
    Yea what he said^... Try lubing just the belt if it starts up again and inspect it for cracking and splits. Also if you suspect it is the bearing you can check it easily by using a wooden broom handle and your ear. While the engine is idling hold the blunt end of the wooden rod to the pulley and put your ear up against it and listen. If its the bearing you will hear the grinding and rumbling noise easily...
  4. Dec 8, 2009 at 7:27 PM
    stucksucksnayota
    stucksucksnayota Well-Known Member
    Barry
    Fort Smith, Arkansas
    14 Taco 4x4 TRD Sport DCSB
    OEM roof rack, Shorty antenna (eBay), soft tonneau cover, K&N drop in air filter, bed mat, interior LED lights, 5100's, MT tires to come soon!!!
    Im confused is it the water pump or the power steering pump lol?
    I would guess you will have to replace it all but hopefully im wrong!
  5. Dec 8, 2009 at 7:31 PM
    Baby
    Baby [OP] Member
    Novato, CA
    03 Tacoma 3.4
    I don't think so. (I assume you're suggesting the belt may be slipping on the pulleys.) Maybe it's the bushing???? When I spray WD 40 or Bel Ray 6 in 1 where the pulley connects to the water pump housing while the motor is running, it quiets for a few hours of driving. I'm not spraying anywhere near the belt.
  6. Dec 8, 2009 at 7:36 PM
    Baby
    Baby [OP] Member
    Novato, CA
    03 Tacoma 3.4
    Thanks for your help. The belt is in good shape, but it's been on the truck for 55k miles, so it probably could used replacing. I need to remove the belt and spin the pulley to see if it's the bearings. I'm just trying to determine if it is in fact the bearings if I need to budget for a pump.
  7. Dec 8, 2009 at 7:39 PM
    Firefighter160
    Josh
    Eastern VA
    05 DCSB Offroad
    Here in Virginia from what I can find a brand new pump is anywhere from $99 to $150.....
  8. Dec 8, 2009 at 8:22 PM
    Baby
    Baby [OP] Member
    Novato, CA
    03 Tacoma 3.4
    I'm looking at the diagram---maybe this thing doesn't even have bearings! I'll take off the belt and go from there. Thanks all!
  9. Dec 8, 2009 at 9:40 PM
    kevhogaz
    kevhogaz Low Speed, High Drag
    Queen Creek, Arizona
    SR5 PreRunner
    3" lift front & rear, Air Raid Intake System
    I don't think I've ever seen a Tacoma P/S pump make noise. I'd bet good money it's the belt.
