Water pump question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rcmslm, Jan 13, 2015.
  1. Jan 13, 2015 at 11:07 AM
    rcmslm
    rcmslm [OP] Active Member
    Roger
    texas
    05 prerunner dc
    265 cooper with factory aluminum spoke wheel
    I was reading another forum that a Toyota tech mentioned
    that the weep hole was designed to remove debris .If it is
    just very small amounts then water pump replacement is not necessary.
    Suggesting a flush and refill.Has anybody had any experience with this?
  2. Jan 13, 2015 at 12:03 PM
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    Mine was trickling out, not enough to drip, but left a thin line of pink crystals down the engine block. Dealership replaced the water pump under drivetrain warranty.
  3. Jan 13, 2015 at 5:34 PM
    hotrod53
    hotrod53 Well-Known Member
    Lynd
    Pittsburgh, PA
    ‘14 DCLB Sport, ‘18 TCH, ‘13 TCH
    Weathertech floor liners moded to hold OEM floor mats, weathertech vent visors, Toyota bed mat, LEER 100XL cap, hood gasket mod to stop whistling.
    I find that hard to believe. I always thought that the weep hole was on the outer side of the bearing after the seal. IMO, if you see a drip, you have a problem.
    "Maybe the laws of physics cease to exist on his stove" .... My cousin Vinny
  4. Jan 13, 2015 at 6:38 PM
    rcmslm
    Roger
    texas
    05 prerunner dc
    I have never heard such a statement.The weep hole was an indication of pump
    failure so I thought.But I am use to working on hot rods.
  5. Jan 14, 2015 at 8:30 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    I wouldn't want that guy working on my vehicle(s). How can a hole remove debris?
    Maybe he thinks it's there for debris to escape? If so, guess what else can escape? Coolant is a fluid and fluids flow more easily than debris and like electricity, will always seek the path of least resistance.
    If you're seeing leakage at the weep hole, it's a matter of time before the water pump dies. It could take awhile, but it will eventually happen.
  6. Jan 14, 2015 at 8:38 AM
    toomanytoys84
    toomanytoys84 Well-Known Member
    Stock
    Seal is going bad if leaking from the weep hole.
  7. Jan 14, 2015 at 9:17 AM
    dm1215al
    dm1215al Well-Known Member
    Dan
    Fl
    2014 TRD Offroad 4x4
    Step tubes,Window tint, HomelinK rear view mirror, changed the entune image screen Rear Differential Breather Relocation Extended AC condensate hose KB Voodoo tailgate cap Redline Tuning QuickLIFT ELITE hood lift system.
    If you have a leak/drip you have a problem.
  8. Jan 14, 2015 at 9:23 AM
    rcmslm
    Roger
    texas
    05 prerunner dc
    There is no wet spot just a small amount of crust.
    But here is the bulletin.T-SB-0117-11.Very interesting.
