Water Pump Questions ......
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Uncelou1980, Dec 29, 2011.
  1. Dec 29, 2011 at 3:38 PM
    Uncelou1980
    Uncelou1980 [OP] Active Member
    New Jersey
    2006 Toyota Tacoma Pre-runner 2WD Double Cab
    Hello friends from Tacoma World ......
    I have a 2006 Toyota Tacoma Pre-Runner with 50,455 miles ....
    My question is this one : WHERE IS THE WATER PUMP LOCATED ???? And
    when or at what amont of miles should I replace the water pump ????
    Thanks for the Help .....:)
  2. Dec 29, 2011 at 3:39 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
  3. Dec 29, 2011 at 6:15 PM
    joes06tacoma
    Joe
    Central Coast, CA
    It's that thing behind the fan. It uses the same pulley as the fan. No need to change it unless it's making noise or leaking. Not a normal maintenance item.
