Water pump/timing belt
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dwr80, Sep 4, 2015.
  1. Sep 4, 2015 at 12:52 PM
    dwr80
    dwr80 [OP] Well-Known Member
    Have 09 trd sport w/ 114k.
    Recommend a timing belt/chain replacement? Should they be replaced? If so, do the water pump? How long should they last?
    Overall, not having any issues, just forcasting maintenance.
    Thanks
  2. Sep 4, 2015 at 1:41 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
  3. Apr 5, 2016 at 8:55 PM
    greatfuldead
    greatfuldead Active Member
    central ohio
    2010 accesscab 5sp 4cyl
    none yet
    Is it safe to say all that crap on the front of the engine with the freaking belt around it should last 100,000 miles +?
  4. Apr 5, 2016 at 10:48 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Why not? 140k and only thing I've changed is serpentine belt, at 135k.
    Azgrnhorn likes this.
  5. Apr 5, 2016 at 10:52 PM
    logcabinwc
    logcabinwc Well-Known Member
    Micah
    SF East Bay
    08 4d 4x4 White V6 TRD
    Old Man Emu 885s with Nitrocharged 90000, Bilstein 5100 in the back with AllPro 3 spring progressive AAL, 16 inch Baja Black 6-spoke alloy wheels, Flow Master exhaust, bed lights, Pioneer HD radio, Uniden CB Radio, K&N Air filter, BAMF Sliders w/kickout, Relentless Aluminum IFS Skid, 24 LED light bar, custom/homebuilt expedition style bed rack and basket combo, and Body Armor rear plate bumper.
    Im at 136000 and Im about to have a new serpentine belt put on...
  6. Apr 5, 2016 at 11:04 PM
    Azgrnhorn
    Azgrnhorn Member
    Replaced my belt Sunday. It was so easy that I can't believe it took me a year to do it!
  7. Apr 5, 2016 at 11:30 PM
    Chuy
    Lakeside, CA
    Silver Taco
    My belt still looked good. Had only fine cracks on the outside. However, for $30 its a cheap item to maintain given its vital role.
  8. Apr 6, 2016 at 12:12 PM
    logcabinwc
    Micah
    SF East Bay
    Exactly... Im having the one mechanic I trust do the belt, do a thorough check over the entire truck, and maybe put some new diff oil in.
  9. Apr 6, 2016 at 1:07 PM
    Chuy
    Lakeside, CA
    Silver Taco
    Belt is a relatively easy DIY. You just need a printout of the hose routing diagram and a few tools. I changed mine when I flushed the old coolant out and installed new hoses. With the hoses removed, you get a bit more room to work in. I think I'm beginning to hear one of the idler pulleys squeal a bit. Will change them all out in a few months when I replace alt with a HO alt.
