Water Pump/Timing Belt
Discussion in '1st Gen. Tacomas (1995-2004)' started by Suggs12, Oct 8, 2018.
  1. Oct 8, 2018 at 5:57 AM
    Suggs12
    Suggs12 [OP] Well-Known Member
    Logan
    Johnson City, Tennessee
    2004 PreRunner
    3" Lift kit, Bilstein 5100 front and rear, 2881 EMU coils, 2" Deavers AAL, 18x9 KMC rockstar 1 wheels and 33" Nitto Terra Grapplers, Debadged, Grillcraft insert, clear corner and turn lights, 6k Leds, 30" Led light bar, 4 Pod fog lights.
    I noticed yesterday that my truck is leaking coolant that seems to be coming from the water pump. Got up this morning and had a big puddle under my truck. If I am going to change the water pump, should I go ahead and change the timing belt as well? If so, what is the best kit that I can buy that includes everything I'll need. Thanks in advance!
    FirstTimeFirstGen likes this.
  2. Oct 8, 2018 at 6:17 AM
    FirstTimeFirstGen
    FirstTimeFirstGen Less active than most
    David
    Pacifica
    2004 4WD 3.4L Tacoma (Manual)
    Not enough to have a build thread.
    TXRailroads73 likes this.
  3. Oct 8, 2018 at 6:19 AM
    TXRailroads73
    TXRailroads73 RÖCKIN'ROLLIN',BEER,YOTAS,TACÖCRÜE,MAX/GEMMA
    Adam
    The Lone Star State, RGV, TEXAS
    '23 TRD PRO
    None all stock
    I just did this at 100K, now I'm at 344K time to do plus valve cover gaskets
  4. Oct 8, 2018 at 6:49 AM
    Suggs12
    Logan
    2004 PreRunner
  5. Oct 8, 2018 at 7:40 AM
    TXRailroads73
    Adam
    '23 TRD PRO
    None all stock
    Some do, some don't, I believe the difference between non cooler and having, is the metal tube on the side of water pump, maybe someone with more knowledge will chime in
  6. Oct 8, 2018 at 7:43 AM
    TXRailroads73
    Adam
    '23 TRD PRO
    None all stock
    Who's the parts guru on this forum? Maybe calling the dealer with your VIN# can assist you????
    Suggs12[OP] likes this.
  7. Oct 8, 2018 at 7:55 AM
    zach141b
    zach141b Well-Known Member
    Zach
    Louisiana
    2001, double cab, 4WD, 3.4L Tacoma
    Based on my recent experience, if you're going as far as the timing belt, I'd recommend replacing the cam and crank seals.
  8. Oct 8, 2018 at 8:11 AM
    Suggs12
    Logan
    2004 PreRunner
    Yea I'm going to do the whole kit as seen in the link. Comes with cam and crank seals.
  9. Oct 8, 2018 at 8:30 AM
    zach141b
    Zach
    Louisiana
  10. Oct 8, 2018 at 8:55 AM
    04tacoma trd
    04tacoma trd Well-Known Member
    Just got done doing the valve cover gaskets and also the timing belt. Used the Timmy videos and did the whole shebang (cam and crank seals). I also replaced the spark plugs and wires.
    The best deal on OEM parts for the timing belt/water pump was the ebay kit. Note, I also replaced the idler pulley (Rock Auto) and also the power steering pump belt tensioner.
  11. Oct 8, 2018 at 9:27 AM
    TXRailroads73
    Adam
    '23 TRD PRO
    None all stock
    Link to vids?
  12. Oct 8, 2018 at 9:43 AM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    TXRailroads73[QUOTED] likes this.
  13. Oct 8, 2018 at 9:48 AM
    TXRailroads73
    Adam
    '23 TRD PRO
    None all stock
    otis24[QUOTED] likes this.
  14. Oct 8, 2018 at 11:17 AM
    Suggs12
    Logan
    2004 PreRunner
    Anybody have a link for a kit without oil cooler? Apparently mine doesn't have an oil cooler, called the dealership with my VIN and they said mine does not.
  15. Oct 8, 2018 at 11:21 AM
    zach141b
    Zach
    Louisiana
    Do ensure you watch Part 2 of that video from Timmy.
  16. Oct 8, 2018 at 11:21 AM
    TXRailroads73
    Adam
    '23 TRD PRO
    None all stock
    Is Roman the parts guru like on Tundras.com? I didn't tag him cause I'm new here
  17. Oct 8, 2018 at 11:22 AM
    TXRailroads73
    Adam
    '23 TRD PRO
    None all stock
    Will do thanks!
  18. Oct 8, 2018 at 11:58 AM
    Suggs12
    Logan
    2004 PreRunner
  19. Oct 8, 2018 at 12:05 PM
    FirstTimeFirstGen
    David
    Pacifica
  20. Oct 8, 2018 at 12:17 PM
    Suggs12
    Logan
    2004 PreRunner
