Water pump whining noise when belt is off
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mark06yoda, Apr 4, 2024.
  1. Apr 4, 2024 at 12:58 PM
    mark06yoda
    mark06yoda [OP] Well-Known Member
    marcus
    2006 Black Tacoma TRD Sport DCSB MT
    https://m.youtube.com/shorts/Q3GECZm2vUY
    makes a whining nose, all other pulleys are good except alternator it has a bunch of resistance and is a bit crunchy in some spots. here’s a video
    https://m.youtube.com/watch?v=GGKrh_pVPuE
    this is my alternator, ^^^notice how it’s a bit crunchy and binds up at the end of the video
    if you guys check my last post it is the noise my truck was making when the belt was spinning
  2. Apr 4, 2024 at 1:04 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    It definitely doesn't sound normal.
    But you have to remember, the fan is bolted to the fan clutch.
    So it's hard to "feel" how much resistance there really is.
    I like to grab the fan and lift up/down on it. Then watch the pump shaft (pink part) for movement up and down.
    This gives me a better idea of the state of the bearings.
  3. Apr 4, 2024 at 1:05 PM
    mark06yoda
    marcus
    not much play i tried let me go try again, look at my alternator video i just posted, that has the be the problem
  4. Apr 4, 2024 at 1:06 PM
    mark06yoda
    marcus
    okay i lied when i lift it up there is a little bit of play up and down not much though
    TnShooter likes this.
  5. Apr 4, 2024 at 1:23 PM
    TnShooter
    Deogee
    STOCK
    A tiny bit is normal.
    The alternator is shot. Time for a new one. Don't go cheap on it.
    I'd go with a Denso Reman at a minimum. I've used them, so far I've had good luck with them.
    Kolter45 likes this.
  6. Apr 4, 2024 at 1:32 PM
    mark06yoda
    marcus
    okay boss thank you. man but that water pump whining noise is scaring me now. you think if i change the alternator i’ll still have some sort of noise down there?
  7. Apr 4, 2024 at 1:33 PM
    mark06yoda
    marcus
    and the denso how
    much will that run you? i got a quote for a 9amp one for $240 i’m not sure what brand though
  8. Apr 4, 2024 at 1:36 PM
    TnShooter
    Deogee
    STOCK
    I can't say I've ever heard a water pump make that kind of noise.
    But then again, 90% of my dealings with a water pump is after it leaks.
    I typically lift up/down on them and give them a quick spin when doing belt swaps.
    I don't do this stuff daily. I only do it to save myself, friends, and family money on repair bills.
  9. Apr 4, 2024 at 1:38 PM
    TnShooter
    Deogee
    STOCK
    RockAuto has them for $205.xx + $75 core
    That is for a 130A.
    If your truck has the towing package, you want the 130A one.
  10. Apr 4, 2024 at 1:38 PM
    TnShooter
    Deogee
    STOCK
    BTW, your truck has the towing package.
    I know because the fan clutch is PINK......:thumbsup:
    GilbertOz and Kolter45 like this.
  11. Apr 4, 2024 at 1:48 PM
    mark06yoda
    marcus
    shit okay so it’s the 130A then so it’ll be a bit more pricier
  12. Apr 4, 2024 at 1:49 PM
    mark06yoda
    marcus
    i really appreciate the help though man thank you
    TnShooter[QUOTED] likes this.
  13. Apr 4, 2024 at 4:16 PM
    Clearwater Bill
    Billy
    Largo Florida
    I have a local electrical shop that will rebuild my OE alternator on site, including R&R, for less than parts house bits.
    I'd have them do it even if it was more.
    Anyway, you might see if such a gem exists in your area.
  14. Apr 4, 2024 at 6:17 PM
    TacoTuesday1
    FL
    what year how many miles?
    going to spin my alternator now…
    Just did the water pump. Wasn’t too bad.
    Only thing I’m dreading is the serpentine tensioner. I have a new one sitting in box.
    supposedly it’s angled and held on from the front and side, requiring more component removal to replace. Such as get alternator and compressor out of the way to access. Ridiculous. Most car serp tensioner is a small piece held on the front of the motor with 2 bolts.
    does anyone know if you can just replace the front bearing on the alternator? Other cars you can.
    Though I understand that may not be enough. At this years and miles the alternator is old. So is its regulator and other bearings it may have deeper inside.
    and if DENSO reman is as good as new?
    Definitely cheaper than a higher amp alternator
    whoops sorry highlighted the wrong 100amp one green instead of 130A towing
    dealer shows price not much higher $230. Not sure if new or reman.
    Sometimes dealers stop offering new and only reman. For example certain other brand old car axles.
  15. Apr 4, 2024 at 6:24 PM
    mark06yoda
    marcus
    mines an 06 with 240’000km
    do you need a new alternator aswell?
  16. Apr 4, 2024 at 6:25 PM
    TacoTuesday1
    FL
    damn less miles than me only 149k mi, uhoh
  17. Apr 4, 2024 at 6:26 PM
    mark06yoda
    marcus
    what year you got?
  18. Apr 4, 2024 at 6:35 PM
    TacoTuesday1
    FL
    08
    no idea if age would be a factor vs miles
    I imagine miles more since it’s driving that spins the bearing and not sitting parked
    google: "about seven years
    Most alternators will last between 80,000 and 150,000 miles"
  19. Apr 4, 2024 at 7:18 PM
    mark06yoda
    marcus
    yup, did you need to change your alternator?
  20. Apr 4, 2024 at 7:22 PM
    TacoTuesday1
    FL
    haven't yet but gonna check it after seeing this post
    did the other pulleys, WP, P/S pump, fan clutch
    probably should replace crank pulley
