Water Pump
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2000GTacoma, Dec 17, 2011.
  1. Dec 17, 2011 at 12:47 PM
    2000GTacoma
    2000GTacoma [OP] Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    I am going to replace the timing belts and the other drive belts on my truck. I figured while I am at it replace the water pump as well. My question is should I go with an oem from my local dealership for 137 or go to advance auto parts and get a water pump for 95 with a lifetime warranty? Both come with gaskets. I am replacing all belts with oem for 104. just a few dollars difference between dealership and advance so they are getting oem.
  2. Dec 17, 2011 at 12:55 PM
    2000GTacoma
    Snow Hill NC
    thats what i was thinking and i would be doing the work my brother has his own mechanic shop
  3. Dec 17, 2011 at 1:11 PM
    2000GTacoma
    Snow Hill NC
    think i will get the lifetime warranty and cheaper.
  4. Dec 17, 2011 at 1:14 PM
    2000GTacoma
    Snow Hill NC
    i can also order the water pump online and pick it up in store and use a code to get 20 bucks off so 75 bucks for a new pump not remanned
  5. Dec 17, 2011 at 1:24 PM
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    i would do oem man... thats what mine gets....
  6. Dec 17, 2011 at 1:31 PM
    2000GTacoma
    Snow Hill NC
    hard not to go with a lifetime warranty
  7. Dec 17, 2011 at 1:39 PM
    joes06tacoma
    Joe
    Central Coast, CA
    It's an awful lot of work to replace that pump if it does not last till the next belt change interval. I'd go OEM. Lifetime means nothing to me if I have to take the bus to the parts store to get it warrantied.
    That warranty isn't going to cover collateral damage either. I had a friend who had a lifetime warranty water pump come apart and go through his timing cover on a 22R. Water in the oil, the whole nine yards. He was in Tahoe with his girlfriend when it happened.
    My 2 cents
  8. Dec 17, 2011 at 1:42 PM
    2000GTacoma
    Snow Hill NC
    debating here
  9. Dec 17, 2011 at 3:00 PM
    lotsoftoys
    Jace
    Denver
    bunch of crap
    just go oem youll be glad... proven to work and last just fine
  10. Dec 17, 2011 at 3:03 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    I got a NAPA pump, no lifetime waranty as far as I know. Going strong after 25k miles.
    Also got a GATES belt at NAPA. I re used the idlers though, I'll replace those when I do the belt again at 240k.
  11. Dec 17, 2011 at 3:05 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    They come with gaskets?
    My 96 3.4L water pump didn't have a pre-formed gasket. You had to use gasket material in a tube (RTV).
    I'd go with OEM and make sure you get the right 'gasket' material for it.
  12. Dec 17, 2011 at 3:06 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    Yeah I had to use RTV. I don't recall the type but the FSM will tell you. Make sure you get the right stuff.
  13. Dec 17, 2011 at 3:19 PM
    lotsoftoys
    Jace
    Denver
    bunch of crap
    they used to be fipg'd on but now 3.4 wp's use a gasket
  14. Dec 17, 2011 at 3:25 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    That is so much nicer. I hate using RTV, I always feel like Im not using the right amount :laugh:
    You have to use way less than you would think.
  15. Dec 17, 2011 at 3:55 PM
    lotsoftoys
    Jace
    Denver
    bunch of crap
    yeah forsure... i just resealed an oil pan on a customer's 3.4 the other day... that was a messy job
  16. Dec 17, 2011 at 4:36 PM
    2000GTacoma
    Snow Hill NC
    alright debate decided oem it is and from what i could understand from the dealership i called it comes with a gasket. we will find out on monday or tuesday as im going to go get the parts. they have all the belts and waterpump in stock. i just decided i do not want to have any problems and am doing maintence use the best parts possible.
  17. Dec 17, 2011 at 4:40 PM
    lotsoftoys
    Jace
    Denver
    bunch of crap
    exactly... the w/p comes with a new t-stat gasket as well. pickup a new t-stat at the same time
  18. Dec 17, 2011 at 4:40 PM
    2000GTacoma
    Snow Hill NC
    noted
  19. Dec 17, 2011 at 4:45 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    when is the timing chain supposed to be changed in the 96 2.7l (123k) also if the previous owner didnt change the pump should i get in that soon?
  20. Dec 17, 2011 at 4:49 PM
    2000GTacoma
    Snow Hill NC
    no idea about when the chain needs changing my pump is intact and working fine but im changing it anyway just so i do not have issues. my dads water pump has 296000 plus miles on it and still going strong on his 3.4L
