Water Pump
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2000GTacoma, Dec 17, 2011.
  1. Dec 17, 2011 at 4:56 PM
    2000GTacoma
    2000GTacoma [OP] Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    water pump or the truck itself? my 3.4 has 153k and i still havnt changed the belts or pump :eek: but thats changing as of next week along with some fresh oil while im at it
  2. Dec 17, 2011 at 5:01 PM
    2000GTacoma
    Snow Hill NC
    well im changing mine just in case
  3. Dec 17, 2011 at 5:04 PM
    2000GTacoma
    Snow Hill NC
    exactly not a hard job to do but might as well kill 2 birds with 1 stone
  4. Dec 17, 2011 at 5:30 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    mine is at 123 and the previous owner said he didnt change the chain or pump, what are the symptoms of a dying pump? or does it just catastrophically die all at once?
  5. Dec 17, 2011 at 6:09 PM
    2000GTacoma
    Snow Hill NC
    i have heard some people say going down the road the motor would cause less noise. i personally have never had one fail on me. i guess it could go slowly or all at once not sure.
  6. Dec 17, 2011 at 7:34 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Usually they leak first.
    I had one that was noisy and made a knocking sound once. That wasn't a Toyota though.
  7. Dec 17, 2011 at 8:57 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    The timing chain in the 2.7 never has to be changed.
    That is why chains are far superior to belts in every way.
  8. Dec 17, 2011 at 9:04 PM
    2000GTacoma
    Snow Hill NC
    i call bs its a chain...made out of metal...which stretches.
  9. Dec 17, 2011 at 9:08 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    they're designed to last the life of the engine. Sure at around 350 - 400k it might be stretched a bit by that time you generally need to open the engine up anyway.
  10. Dec 18, 2011 at 3:53 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Theoretically, YES they stretch.... but not enough to cause any sort of timing issues or breakage. Chains will have some sort of 'idler' to keep them at the proper 'tension'. If a chain is properly tensioned, it will last a very very long time with minimal stretch.
    If you abuse the crap out of your truck and race the engine often - well, that's another story You might have more problems than just the timing chain.
