Water seeping under my door
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Newyota16, May 12, 2025.
  1. May 12, 2025 at 6:56 PM
    Newyota16
    Newyota16 [OP] New Member
    2023 Tacoma trd offroad
    I have a 2023 Tacoma and i have noticed water seeping under my door into the side step up. All of the seels seem to be tight and in place. Has anyone had this issue?
  2. May 12, 2025 at 8:28 PM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    Maybe water is stuck in the door, if there are plugs remove them and give the door a good shake.
    Chew, Newyota16[OP] and Greg-tacoma like this.
  3. May 13, 2025 at 9:15 AM
    Newyota16
    I never though to check for plugs. Thanks, ill look and see what i find under there.
  4. May 13, 2025 at 10:20 AM
    yotadust
    yotadust Well-Known Member
    do you have a picture of the water?
    Chew likes this.
  5. May 13, 2025 at 6:26 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Debris could be clogging the door drain holes. Make sure those are clear.
    Do you have a moon roof? If so, pour water into the moon roof drain channel and make sure the water drains properly through slots in the cab pinch weld below the doorsill.
