Water Softener question
Discussion in 'Garage / Workshop' started by weiser5150, May 9, 2011.
  1. May 9, 2011 at 4:56 AM
    weiser5150
    weiser5150 [OP] Stickers and new floormats arent Mods
    JK
    Jacksonville,Fla.
    2008 DC LB 4x4
    Bilsteins all around,Front set at 2.5",Toytec AAL,LR UCAs,18x9 ATX Thugs,275/70R18 Toyo MT's,Relentless Fab Sliders,Satoshi Grill with TRD emblem and Hella Black Magic's converted to HID behind it.
    Looking to buy a water softener and have heard that there are the standard ones that use salt and the ones that use NO salt.
    Anybody have any experience with these saltless ones?
  2. May 10, 2011 at 10:29 AM
    weiser5150
    JK
    Jacksonville,Fla.
    2008 DC LB 4x4
  3. May 10, 2011 at 10:32 AM
    Hunter500ky
    Hunter500ky Well-Known Member
    E-Town Ky
    06 Tacoma 4x4 SR5
    Weathertech Mats, Toolbox, 6k HID fogs, Hardwire Escort 8500 x50,
    We have a salt one and it makes a HUGE difference!!!!
    I can get the name brand of it if you want.
  4. May 10, 2011 at 10:32 AM
    jgwheeler17
    jgwheeler17 I'm a zit. Get it?
    NC
    07 Double Cab TRD Off-Road 4x4
    tint, dents, scratches, two blown speakers and trying to pay her off...
    at work we use salt. works good. its industrial, so its a big unit, and every now and then the boss has me dump another 50 lb bag of salt in there. . . to tell the truth our system is so elaborate with all the tanks, i cant give you to much cause i don't understand it all. the water aint rusty and it taste fine so everybody's happy.
  5. May 10, 2011 at 10:39 AM
    weiser5150
    JK
    Jacksonville,Fla.
    2008 DC LB 4x4
    thanks guys!
  6. May 10, 2011 at 10:45 AM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    What exactly are you curious about? I have some water treatment experience. Like the differences between Salt in general or the effects.
  7. May 10, 2011 at 10:50 AM
    gooch14
    gooch14 Well-Known Member
    Kyle
    Michigan
    2011 Blk DC Taco SR5 4x LB
    Bestop, Child Seats, petrified french fry, dog hair, empty Mtn Dew cans cracked windshield, scratches.
    we also have salted. Not sure on brand but we just ran to a Sears and bought it on sale. One thing you'll want to think about is plumbing the water for the recharge or whatever they call it. It'll cycle every so often and pump out a bunch of water to sorta flush it's self. A lot of people plumb it to their septic, the only real issues with this is are the salts are bad for the bachteria in your septic system (I assume you aren't on city water) and the added stress of water on the system (only an issue if you're near capacity for your holding tank) Best bet is to run the cycle water out to a grassy area, though it may kill the grass.
    I know nothing about the un-salted systems but our salted works wonders. without it our shower is orange in a matter of days. could the un-salted be reverse osmosis?
  8. May 10, 2011 at 10:54 AM
    jgwheeler17
    NC
    i agree with all that as well. hope my less thank knowledgeable input helps.
  9. May 10, 2011 at 10:55 AM
    jester156
    jester156 Well-Known Member
    Cumberland, RI
    08 V6 4x4 DC TRD, 6spd
    TRD Supercharger, TRD CAI, Sirius, Rear TSB, Front 5100 with Eibach coils, 1.5" AAL, URD short throw, fog light mod, weather tech liners,
    reverse osmosis is a filtering process not a softener.
    We have a rain soft system for the entire house then an RO system just for the fridge and the sink, when ever I care to drill our granite counter top for the sink tap.
    I buy my salt in 50lb bricks and it has a rust retardant in it. Although I have well water it is nice to remove the mineral taste.
    Also have no experience on the saltless softeners.
  10. May 10, 2011 at 12:55 PM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    If you've got the $, then go Reverse Osmosis
  11. May 14, 2011 at 4:30 PM
    lynyrd3
    lynyrd3 Strength ,Determination ,Merciless,Forever
    Bill
    Upstate New York ,Columbia County
    2008 SR5 AC SUPER WHITE V6 4x4
    Bilstein 6112s at top setting ,1/4" top plate spacer driver side,Total Chaos UCAs ,SS extended brake lines ,Rear 4 leaf Suspension TSB,Wheelers 2" AAL, Bilstein 5125s , SS extended brake lines rear , Toytec dif drop , Hayden high performance transmission fluid cooler,aFe pro dry filter , ,Powerstop drilled and slotted rotors.N-Fab light bar with 4 Hella OR lights , Devil horns by Andres ,Weathertecs floor protector, American Racing wheels Baja 17x8,4.5 BS , 285/70 Falken Wildpeaks AT/3W .Body Armor rear bumper . Extra D rings in bed ,Blue sea fuse block and 100amp breaker ,G-Tek Fab door sill protectors ,blacked out grille , painted pinch weld.Shorty antenna ,HVAC knob mod ,LED dome and map lights , Tri Fold bed cover ,UltraGauge ,Morimoto XB LED fog lights ,
    The salt is to clean the softner itself .Sort of like a backwash . The salt does not end up in your water system .There is some kind of bead type media in the softener itself that removes the hardness from the water.
  12. May 14, 2011 at 9:05 PM
    Zac808
    Zac808 Custom User Title
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    What I was explained when I bought my softener was there is a bunch of tiny resin balls with dimples all over, like a golf ball. The city water goes through the resin and the dimples collect the crud. And the salt is used to clean the resin balls. My system runs at 2am to clean the resin.
    lynyrd3 likes this.
  13. May 15, 2011 at 6:28 AM
    lynyrd3
    Bill
    You are correct !:thumbsup:
  14. May 30, 2011 at 7:17 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    We had a Kinetico system installed a couple months ago. No electricity needed and it cycles only when needed. The softener side of it uses salt. Spendy but good so far.
