Water softener
Discussion in 'Detailing' started by Cardsallday13, Sep 4, 2018.
  1. Sep 4, 2018 at 10:24 AM
    Cardsallday13
    Cardsallday13 [OP] Well-Known Member
    2017 DCSB TRD Sport 4x4
    Is there any threat to paint finish using water that goes through a water sofesoft that uses salt?
  2. Sep 4, 2018 at 10:27 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    I would think if anything the softener would help with not having water spots on the paint if it dries on. But that is just a guess.
  3. Sep 4, 2018 at 10:32 AM
    Cardsallday13
    Right but most of them basically swap the calcium, etc with diluted sodium
  4. Sep 5, 2018 at 9:52 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Technically yes.
    Salt = rust.
    However its uncommon for the water supply going outside the house to run through the softener first.
    Are you sure your water softener is set up like this?
    If you are can you fix it by hooking the softener up down the line?
    It is incredibly expensive to be softening outside water if you use external water for car washing, pressure washer, grass, and gardens.
    Mostly softened water is not good for plants and grass. Just like salt water for people it causes dehydration.
    Of course its not in high concentrations but its still not preferable.
    I’m not sure its going to be a huge issue but I would fix the softener hook up if possible/economical. Mostly its just expensive in salt.
  5. Sep 5, 2018 at 9:55 AM
    Cardsallday13
    well i don't have it in yet i still have to plum the thing in. BUT i was asking because the way the pipes are, i am going to either repipe the house or just deal with one of the outside spickets going through the softener. I guess i could just put it on bypass when i'm using that one.
  6. Sep 5, 2018 at 10:00 AM
    FFBlack
    FFBlack Well-Known Member
    2019 TRD OFF ROAD
    Why do you need a softener for? Just curious. Where I live the water is really hard and if it dries on your paint you'll have water spots that etch into the paint. I've even seen my truck get a haze to it per persay by drying after wash, it's like a white gray film on my truck just from wiping it down while drying.
  7. Sep 5, 2018 at 10:25 AM
    PackCon
    Connor
    If you have more than one spigot I would just not use that one for anything. If that’s your only one or going to be the one you need for the cars I think it would be worth the PITA to bypass it if you can.
    Or buy very long hoses lol
  8. Sep 5, 2018 at 3:02 PM
    03coma
    03coma Well-Known Member
    New Jersey
    2015 DCSB TRD, SR5
    TRD Pro Grille, Skid Plate, TRD Cat-Back Exhaust System, 2017 Tacoma TRD Rims, ARE Series II Lid,
    water softeners are installed after the water meter, so conditioned water run through the whole house. You could intall a valve and new supply line before the softener to an outside spigot but that would defeat one of the purposes of a whole house water softener.
  9. Sep 6, 2018 at 4:10 AM
    rickm
    rickm Well-Known Member
    Rick
    MA
    2018 BLK Tacoma TRD Pro
    Why not use a rinseless wash such as Optimum No Rinse! Has it's own built in water softener.:D
  10. Sep 6, 2018 at 5:49 AM
    FFBlack
    2019 TRD OFF ROAD
    I do use a rinseless wash sometimes but I have to add tap water to dilute the rinseless concentrate and then I'm right back where I started and I'm not paying for distilled water. I moved about 15 mins from where I used to live and never had this problem untill I moved to the new place.
  11. Sep 6, 2018 at 6:09 AM
    rickm
    Rick
    MA
    Optimum claims there rinseless will soften the water. I run my make up water thru a RODI filter and into a 30gl Brute trash barrel. It was originally used for make up water when I had a coral reef tank so I'm not sure how much it counter acts hard water. So I have no problems with water spotting.
    Were you using a different rinseless product or is there claim BS?
  12. Sep 6, 2018 at 6:30 AM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    Not at all. If I were building my house again I would install car wash faucets off of the softwater conditioner in the house. A good SW conditioner will have 2 or more rinse cycles and remove almost 100% of the salt residue after a recharge. Even at that, running a dishwasher or washing machine once after a SW recharge will flush out any residual brine water. Using SW will reduce water spotting due to lack of Ca and Mg in hard water.
    BTW, using a true SW conditioner with resin beads that extract Ca and Mg is the ONLY way to soften the water. The other exception is a horribly expensive reverse osmosis systems. Adding a chemicals or running water through a magnet is just snake oil. You have to REMOVE the Ca and Mg not just "change" it's properties.
    cookiedough and FastEddy59 like this.
  13. Sep 10, 2018 at 5:17 PM
    5staight
    5staight Active Member
    17sr5
    I actually ran a spickt specially for washing the truck and car from the water softener really helps with less spotting.
  14. Oct 13, 2018 at 2:53 PM
    seamastergmt
    seamastergmt Well-Known Member
    California, OC
    2017 Tacoma Sport, Super White
    plasti-dip emblems, grill. TRD Pro wheels, LED reverse lights
    I have hard ass water too. Our municipal water in my area is well fed. I purchased a CR-Spotless de-ionizer to run all my rinse water to keep a spot free final. It costs alot for the initial set up but worth it when you wash your truck every two weeks...
  15. Oct 13, 2018 at 3:01 PM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    Soft Water is absolutely essential for detergents to work at there best. Should be no residual salt after the slow rinse/ fast rinse regen. cycles in your soft water.
    cookiedough likes this.
  16. Nov 9, 2018 at 9:53 PM
    Slick Taco
    Slick Taco Id Rather Be Airborne
    Lost somewhere in the PNW
    Current vehicles: 2019 Rav4 Lunar Rock. 2018 TRD OR DCSB KD Max tuned. 2010 Tundra Limited Crew Max . 1991 4Runner Crawler. Ivan Stewart Edition
    KD Max Tune, King 2.5 coil overs T.C. UCA's, Deaver leafs, 17x9 Black Rhyno Warlords, 33" Toyo M/T's, Metal Tech rear bumper, Westin HDX drop steps with Bullet Liner coating, K&N CAI, Baja Designs fog pods, Rigid Midnight addition 3" pod ditch lights. Cali Raised brackets and 32" behind the grill mounted light bar, Southern Style Offroad Lopro Stage II front bumper, Warn winch, FACTOR 55 Ultra Hook, FACTOR 55 Hawes Fairleed, full debadge, Cosmetic goodies such as 15% carbon tint, matte black in channel rain guards, interior LED's, Teton Workshop shift knob, Inferno vinyl detailing on the interior, Cali Raised multi rocker switch cubby insert with Mc Tuning LED switches and a few other mods I've probably left out.
    In the summer I use a CR Spotless deionizer and in the winter I collect rain water from three downspouts on the house, two on my out building and two on the garage and store it in a 300 gallon water tank which I repurposed from my retired mobile auto detailing trailer. I run the water with a 1 hp pump through a sediment filter and it's free distilled water for almost 8 month out of the year
  17. Nov 10, 2018 at 5:02 PM
    cookiedough
    cookiedough Well-Known Member
    Phx, Arizona
    02 DCSB OR, 19 DCSB OR
    '02 - No mods. '19 Blue Friday - GFC, RXT S1, Bilsteins
    Another in the "uses soft water" crowd. I added a spigot at the front of the garage from my softener. If I leave soft water droplets on the windshield and windows, they dry and leave a little white powder. But, it wipes off easily with a MF towel. The hard water (i.e. calcium/magnesium) deposits do not remove easily with a MF towel, but do come off with an acidic cleaner since acid dissolve Ca based deposits. (vinegar)
    The hard water in Phx (where I live) has very high chlorides (in the summer, does quite the number on concrete), which do increase the corrosivity of the water. The softened water still has good pH if the softener is working properly - side note - DI filters when saturated and then with continued use, will dump chlorides into your water and increase the corrosivity of the water to mile steel. (so always check your water TDS and conductivity coming out of your filters, if you use DI resin bed filters)
    I would be interested in the pH of your water Slick Taco - just as a curiosity - to compare with some of the estimates given online. Naturally soft water tends to be a little more aggressive to metals than the Ix softened water. But it does work fantastic with soaps!
    A good little read (if you're a nerd like me)
    http://www.ukwta.org/assets/NewFolder/Softened-water-is-not-more-corrosive-Rev2-1.pdf
    Most corrosivity studies talk about the Langelier Saturation Index, which TLDR, indexes a bunch of characteristics to estimate if water will scale, be neutral, or remove scale (think Flint, MI water issues) and expose the metal in the pipes (and leach copper or worse lead).
    There are a number of studies out there, but most deal with the leaching of copper or lead. Some of the state Dept of Roads (CO, IA, WA) have addressed the corrosivity of road salts (CaCl2, MgCl, NaCl) but most concern 300 and 400 series stainless steels, not mild steel or HSLA steels which are in our vehicles. We have a accelerated weathering machine at work, and I've been wanting to do a little experiment with Phx water and softened water, but haven't had the downtime on our machine to "play" a bit.
