Water sound behind dash
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rturner34, Dec 16, 2015.
  1. Dec 16, 2015 at 6:53 AM
    rturner34
    rturner34 [OP] Member
    2006 Toyota Tacoma
    I recently started noticing a water sloshing sound coming from behind my dash when the engine is cold during acceleration. I read some of the threads on this suggesting it was low coolant level. I checked the coolant and it is up to the neck of radiator when cold. The overflow resovior is above the full line. I was wondering what else could be the cause of this noise?
  2. Dec 16, 2015 at 7:02 AM
    unlewser
    unlewser Well-Known Member
    Tempe, AZ
  3. Dec 16, 2015 at 7:03 AM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    You may still have some air bubbles in your coolant system. Let the engine run, with the heater on, with the nose of your truck pointed as high up as you possibly can. This will push as much of the air bubbles toward the top of the radiator as possible. If you still get the noise, you may just have some water and or leaves in your cabin air intake area.
  4. Dec 16, 2015 at 7:04 AM
    RacecarGuy
    RacecarGuy Well-Known Member
    Houston, Texas
    '12 DCSB OR
    Pelfreybilt front and rear HC bumper w/swingout, BAMF LCA Skids, BAMF Diff skid, Pelfreybilt IFS and Trans skid, RCI gas tank skid, Bronze SCS F-5's, Icon RR's ext travel, Dakar leafs, Archive Garage shackle flip
    The heater core would be located in the dash and have coolant flowing through it. Not sure if it going bad or the heater control valve would cause a sloshing noise. Maybe try turning the heater on and see if you can recreate the sound, as coolant will be actively flowing through it while its on.
  5. Dec 16, 2015 at 8:27 AM
    rturner34
    2006 Toyota Tacoma
    Once the engine warms up, i do no think i hear the sound anymore. Which this tells me it should be something with the cooling system right?
  6. Dec 16, 2015 at 10:38 AM
    08TRDOFFROAD
    08TRDOFFROAD Well-Known Member
    Dan
    21' Tundra Platinum & 08' TRD Offroad DCSB 4x4
    Bilstein 5100's w/front's set at 1.75", TRD exhaust, Colormatched grill, Illuminated 4wd selector switch, BAMF Bolt on Sliders w/kickout.
    Check to make sure you coolant is full. When mine did that is was because my coolant was low. Once I topped it off and drove for a bit, and topped off again, it went away.
  7. Dec 16, 2015 at 10:41 AM
    Maximus
    Maximus Well-Known Member
    North Bay
    11 Tacoma TRD OR 4x4
    Icon Suspension with CDCV, SPC Light Racing UCAs, Wheeler's 3 Leaf AAL, Wheeler's Superbumps, sPod SE BAMF Sliders, All-Pro Skids, AFE Drop in filter, Magnaflow Exhaust, RCI Aluminum LCA Skids, BAMF Bed Brackets, 4X Innovations Rear Bumper, FX-R Retrofit Headlights with Philips 4300k, Custom Nestah Edition Firestik AM/FM Antenna, Famous Fab Hood brackets, FrontRunner SlimLine 2 Roof Rack, Mob Town Offroad tailgate reinforcement plate, Ram A pillar mount, Anti-Dark hood lights, Lots of LED lights,
    Does it make a gurgling sound?
  8. Dec 16, 2015 at 10:49 AM
    rturner34
    2006 Toyota Tacoma
    Coolant level is to the top of the radiator neck. And its not a gurgling sound, more a water in a pipe kinda sound.
  9. Dec 16, 2015 at 10:53 AM
    08TRDOFFROAD
    Dan
    What about in the reservoir?
  10. Dec 16, 2015 at 10:54 AM
    BloodThinnerz
    BloodThinnerz Well-Known Member
    Alberta
    2015 MGM DCLB
    TRD Cup Holders
    Mine has been making that sound with a cold engine ever since I bought it brand new last year, I did find it odd, never thought anything of it. Truck has been through many routine inspections and nothing has come up so...?
  11. Dec 16, 2015 at 10:57 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Same.
    It's normal. What it is? Dunno.. but all of my cars have done the same thing. None had issues.
  12. Dec 16, 2015 at 10:58 AM
    rturner34
    2006 Toyota Tacoma
    The reservoir is above the 'full' line. And the truck doesnt run hot by any means, just started to notice the noise and was trying to figure out the cause and/or a solution.
  13. Dec 16, 2015 at 11:03 AM
    T4RFTMFW
    I don't imagine there is a solution, as a solution means there is a problem.
  14. Dec 16, 2015 at 1:16 PM
    rturner34
    2006 Toyota Tacoma
    If it was the cabin air intake or the ac drainage, the sound woul not go away once the engine is warm though, correct?
  15. Dec 18, 2015 at 9:55 PM
    Oz_760
    Oz_760 New Member
    Oz
    2015 Tacoma TRD
    Could also possibly be they water valve I've had that issue before on another vehicle
  16. Jan 5, 2016 at 6:21 AM
    rturner34
    2006 Toyota Tacoma
    Just a quick update. I tried burping the system. Some air did come out. But it is colder in the mornings now, and when i start the truck after sitting overnight, i get the same water rushing noise. But i also get a weird kinda knocking noise. It will come in spurts while the engine is still cold. Once the engine warms to operating temp, all sounds are gone. Anyone have any ideas?
