Water Sound when braking/accelerating?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DSTIDGER, Feb 14, 2012.
  1. Feb 14, 2012 at 7:17 PM
    DSTIDGER
    DSTIDGER [OP] New Member
    David
    Alabama
    09 PreRunner
    Raptor Step Bars
    Hello All. I am brand new to the board and just wanna say looking forward to receiving advice and connecting with other Tacoma owners. I just recently purchased an 09 Prerunner and have been hearing water sloshing sounds when I brake and accelerate. I have Raptor step bars on the truck and read in another forum that there could possibly be water in there? I've looked but appears there is no way to drain them? Any advice would be greatly appreciated!
    The holes under the rubber mounts on top have water around them but they are so small I just don't see how to go about draining.
    BigMike15 likes this.
  2. Feb 14, 2012 at 8:51 PM
    Fractured
    Fractured FPS-a-holic
    Corey
    NOR*Cal
    2012 MGM DCSB 4x4
    TRD wheels, TRD cat back exhaust, ScanGauge 2, Debadged, Avid sliders, UWS bed box w/automatic LED light, Led Interior/Reverse/Lic. Plate lights, Yellow Fogs, Flyzeye Light, Color matched grill, Rearview mirror relocate bracket, Power Sliding rear window, Plasti-dipped bumper/"T" emblem
    There could be water in your frame as well. Did you go through water or mudding lately?
    Oh and welcome to tw!
  3. Feb 15, 2012 at 4:56 AM
    DSTIDGER
    David
    Alabama
    09 PreRunner
    Raptor Step Bars
    No I haven't gone through any water or mud lately. It's really baffling me that if it is the step bars that there is that much water in there! I'm not real sure what to do.
  4. Feb 15, 2012 at 5:01 AM
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    in my 09 I can here gas in the tank sloshing at stops sometimes give that a thought.
  5. Feb 15, 2012 at 5:04 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    Have you checked your coolant level lately? Maybe hearing it sloshing around in your heater core.
  6. Feb 15, 2012 at 5:07 AM
    David Tarantino
    David Tarantino Well-Known Member
    N.J.
    08 tacoma
    does it sound like its coming from the inside or outside of the truck
  7. Feb 15, 2012 at 8:29 AM
    Utard
    Utard Well-Known Member
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    If who ever made the sliders tried to weld them to make them sealed may have left a pinhole on the top. It does not take much of a hole for water to get in. Drill holes in bottom at front and rear.
  8. Feb 15, 2012 at 10:20 AM
    DSTIDGER
    David
    Alabama
    09 PreRunner
    Raptor Step Bars
    Well, I've got it in my head that it's in the step bars, but it's definitely at the sides of the truck. It seems like its louder on the passenger side.
  9. Feb 15, 2012 at 10:29 AM
    Yota Toy
    Yota Toy Taco Sauce
    FX retros, Blazer fog-light retro, JVC KW-NT30HD head unit, Pioneer 6X9's in front doors, Pioneer 6.5's in rear doors, two Pioneer 12" subs in sealed boxes, Sony X-Plod amp, Hidden Hitch trailer hitch, EGR window visors, two PIAA low-tone horns, Westin light bar with two 100-watt KC low profile driving lights.
    It could be a clogged evaporator core housing drain, they get clogged fairly often with leaves and gunk.
  10. Feb 15, 2012 at 11:19 AM
    David Tarantino
    N.J.
    08 tacoma
    this^^^^^^^^^^^^^^^
  11. Feb 15, 2012 at 1:16 PM
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
    Check the doors also by shaking the drains could be clogged
  12. Feb 15, 2012 at 2:29 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    Get out of the truck. Grab the roof with both hands. Shake truck back and fourth.....listen
  13. Feb 15, 2012 at 2:37 PM
    rleeharris
    rleeharris "Old Timer," compliments of 11Taco2.7
    Bob
    San Antonio, Texas
    '11 Tundra Crew Max TRD Off Road
    Happened to me too in my F250 years ago. Ended up I had water collecting under the carpet which collected in the double-walled cabin. Ended up being from a variety of sources to include poor draining around the door gaskets. Rain and going through automatic car washes/hand washing with a hose added to the problem. Not sure if that is your cause but worth taking a look at. As mentioned above, it could be the AC/evaporator too.
    I ended up drilling a hole up from under the truck into the cabin and water came out like a waterfall. Later plugged it up with some RTV and a plastic plug. Replaced all the gaskets/weather stripping around the doors and it was solved.
    Hope you figure it out as it's frustrating.
  14. Feb 16, 2012 at 4:58 AM
    DSTIDGER
    David
    Alabama
    09 PreRunner
    Raptor Step Bars
    Just an update for everyone that took time to comment on the thread: I removed the bolts under the step bars on either side and about a 1/2 gallon of water poured out of each of them! Problem solved. Thanks to everyone who gave some insight into the water sound mystery. I think I will drill holes in bottom of each side bar now
  15. Feb 16, 2012 at 3:21 PM
    BostonBilly
    Easton
    That is cool glad you found the source
  16. Dec 18, 2016 at 11:06 AM
    bssquared82
    bssquared82 b-squared82
    I had THE SAME issue. Thanks for pointing me in the right direction.
  17. Feb 10, 2022 at 11:53 AM
    BigMike15
    BigMike15 New Member
    2015 Tacoma 4X4
    Same thing I just discovered after reading your reply. I had water in both of my raptor rails causing the water noise. Funny early in the mornings I could hear the ice in the water. Probably got a 1/2 gallon of water out of each side. Thanks
