Water sounds behind dashboard
Discussion in '1st Gen. Tacomas (1995-2004)' started by smmarine, Feb 7, 2016.
  1. Feb 7, 2016 at 5:15 AM
    smmarine
    smmarine [OP] Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    All of a sudden my 99 Prerunner is making water noises behind the dash upon startup. Even with A/C off it does it
  2. Feb 7, 2016 at 5:22 AM
    Old School
    Old School You are ignoring covfefe by this member.
    Check your cooling system, low coolant can cause this, you might have a leak...
  3. Feb 7, 2016 at 5:23 AM
    Stags863
    Stags863 Bye Felica!
    Florida
    2014 DCSB TRD Off Road 4x4
    - Bilstein 5100's set at 1.75 - 265/70/r17 Goodyear Wrangler Authorities - 6000k headlight and fog light bulbs - NiLight off road LED rear lights - Light bar mounted behind front bumper - White LEDs in dome, map, and sun visor - Tint (5% around / 35% front) - Universal 13 inch metal antenna - Beer bottle opener in bed - Organizer storage box in center console and glove compartment - Mounted MagLite to top of center console storage box - MGM grille - MGM rear bumper - CamLocker toolbox - Rubber floor mats - 2 USB and Cig lighter chargers in rear of center console - Headrest mounted iPad holders for rear seats
    My first thought is that the seal around your windshield is bad. Could actually have water behind your dash. You can test this with a water hose. Put it up on the seal around your windshield and see if you can see any leaks.
  4. Feb 7, 2016 at 7:21 AM
    high n mighty
    high n mighty Well-Known Member
    Oshawa Ontario
    01 camo taco
    x2 on the low coolant, your prolly hearing the coolant rushing through the heater core
    Old School likes this.
  5. Feb 7, 2016 at 8:30 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Maybe the coolant system has trapped air, and needs to be bled.
  6. Feb 7, 2016 at 8:33 AM
    Old School
    That doesn't happen on it's own, I think he has a coolant leak that needs to be found and repaired!
  7. Feb 7, 2016 at 8:35 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I wonder if the A/C drain coming out of the firewall is plugged and now filled the air box under the dash with water.
    MalinoisDad likes this.
  8. Feb 7, 2016 at 8:37 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    when you say water noise..do you mean like splashing? or moving through pipes?
  9. Feb 7, 2016 at 9:02 AM
    tan4x4
    Rick
    Folsom, CA
    I agree, likely neglected maintenance.
  10. Feb 7, 2016 at 9:05 AM
    Old School
    It is a '99, parts do wear out with time...
    trevor2009 likes this.
  11. Feb 7, 2016 at 9:19 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Coolant.
  12. Feb 7, 2016 at 9:22 AM
    smmarine
    Melbourne FL
    Moving through pipes
  13. Feb 7, 2016 at 12:54 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    what these guys said. there's nothing for water to puddle in under the dash that would cause any noise. check level and burp the system.
  14. Feb 7, 2016 at 1:27 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    have you looked inside the cowling vents? if the drain in there gets clogged up its like a bucket of water that sloshes when you turn or hit brakes.
    ifthe a/c drainis draining and running it is not related to when you hear the noise, its water build up in the cowling unable to drain off as it should
  15. Feb 14, 2021 at 10:12 AM
    trevor2009
    trevor2009 Well-Known Member
    Trevor
    2003 SR5 DC Tacoma
    OP, did you ever find out what this noise was?
  16. Feb 15, 2021 at 5:33 AM
    Brahms
    Brahms Well-Known Member
    Houston, TX
    2004 Tacoma DCSB 4x4 SR5 V6 TRD
    Not OP but I had a similar noise after doing a coolant flush. It sounded like water pulsating through a pipe. Is that what you’re experiencing?
  17. Feb 15, 2021 at 5:40 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    If the truck is standing still how can water slush around? Low coolant more than likely.
  18. Feb 15, 2021 at 8:49 AM
    pontoon
    pontoon Well-Known Member
    2000 Tacoma SR5 TRD V6 3.4 5MT
    Coolant can make some noise going through the pipes. It might not happen if your heat is set to cold and/or your fan is off. I noticed it after doing a coolant flush. idk if it did it before.
  19. Feb 15, 2021 at 9:11 AM
    trevor2009
    Trevor
    2003 SR5 DC Tacoma
    Mine just sounds like water sloshing under my windshield, It only happens when i’m driving during or after heavy rain. I’m thinking my cowl vent may be stopped up where water can’t drain like it’s supposed to.
  20. Feb 15, 2021 at 11:43 AM
    Madjik_Man
    Colorado Front Range
    Did you check the evap drain box? It might be full of water because the drain (coming out/through the firewall) is clogged.
