Water Spigot Mod! Eh?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by drew02a, Aug 7, 2009.
  1. Aug 7, 2009 at 11:15 AM
    drew02a
    drew02a [OP] Rocking your mom's world Since 1997
    San Antonio, TX
    2006 Regular Cab 2.7L 4x4
    Ever been camping or fishing at a remote spot and though of how much easier it would be to wash things up if you had a faucet instead of a jerrycan or whatever? I had a great idea for mounting an on-board water supply in one of the bed sides then putting a faucet near the rear of the bed.
    Here's a simple illustration of the concept:
    The two pipes going up would be for filling, venting air, or cleaning. If you have on-board air you could use it to pressurize the system for better water pressure when the tank is low. Would mount it on the side opposite the gas tank. Maybe put some baffles in the pipe to minimize the inertial effect of sloshing.
    Thoughts?
  2. Aug 7, 2009 at 11:21 AM
    98tacoma27
    Ben
    Not Beech Creek
    Increase tank capacity
  3. Aug 7, 2009 at 11:23 AM
    drew02a
    San Antonio, TX
    Depending on how wide a pipe you can stick up there (or using multiple pipes), I bet you could get a good 20 gal.
  4. Aug 7, 2009 at 11:24 AM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
  5. Aug 7, 2009 at 11:24 AM
    98tacoma27
    Ben
    Not Beech Creek
    Thats the equivalent of 4 - 5 gallon buckets. That's a lot of room.
  6. Aug 7, 2009 at 11:26 AM
    drew02a
    San Antonio, TX
    Meh, I need to measure, but I think it's feasible. I probably would do it even if it was only 5 Gal.
  7. Aug 7, 2009 at 11:29 AM
    98tacoma27
    Ben
    Not Beech Creek
    1 cubic foot of water = 7.48 gallons.
    You may be onto something Drew
  8. Aug 7, 2009 at 11:30 AM
    drew02a
    San Antonio, TX
    If you made it 15 gal it would weight about the same as the gas tank.
  9. Aug 7, 2009 at 11:31 AM
    Caddmannq
    Caddmannq MotoNerd
    California
    2012 PreRunner TRD Sport DC LB
    Undercover toneau
    Back in the early 1960's I knew this grizzled old Jeeper down in Arizona that filled his spare tire with water. He said that way he'd always have extra water if he broke down out in the desert.
    I'm not sure how that water would taste, but then if you're dying in the desert you wouldn't be too picky. ;)
    It's funny...but I haven't thought of that old guy in probably 40 years (he's probably been dead since the 80's) but I wonder if he ever had to drink that tire water. :?
  10. Aug 7, 2009 at 11:34 AM
    98tacoma27
    Ben
    Not Beech Creek
    A 3" dia x 4ft long pipe would give you 1.46 gallons.
    4" x 4ft = 2.5 gallons
    5" x 4ft = 4 gallons
    6" x 4ft = 5.86 gallons
  11. Aug 7, 2009 at 11:51 AM
    drew02a
    San Antonio, TX
    I'll do some measuring this weekend!
    It might be a good idea to use a ball valve instead of a regular spigot. Then mount it inside the small bed compartment with a small hose.
  12. Aug 7, 2009 at 11:56 AM
    #Reistlehr-
    #Reistlehr- AngryTacoma
    Parsippany, NJ
    09 Magnetic Grey Double Cab Long Bed SR5
    make sure you get the TSB.. thats gonna be an extra 100 lbs.. :(
  13. Aug 7, 2009 at 11:58 AM
    drew02a
    San Antonio, TX
    True, but you'd have that much water in your bed anyway if you went camping.
    I do have the TSB so I think it could easily handle it.
  14. Aug 7, 2009 at 12:03 PM
    98tacoma27
    Ben
    Not Beech Creek
    Make two, one for each side. Don't want that "taco lean"...........:D
  15. Aug 7, 2009 at 12:04 PM
    drew02a
    San Antonio, TX
    LOL, it'd probably correct the lean.
  16. Aug 7, 2009 at 12:04 PM
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    Sweet idea!
  17. Aug 7, 2009 at 12:59 PM
    Padilla1880
    Padilla1880 "Let's Ride!"
    Daniel
    Temecula, CA
    05 TRD OffRoad V6 SR5 PreRunner
  18. Aug 7, 2009 at 1:01 PM
    drew02a
    San Antonio, TX
    Those work, but I don't like having to lug 'em around for filling or using. Plus, they have a tenancy to slide around in the bed. None of which is THAT big of a deal, but if there was a better option I'd take it...
  19. Aug 7, 2009 at 1:05 PM
    Padilla1880
    Daniel
    Temecula, CA
    I i hate lugging it around too! Maybe you could make a carrier for it to sit in that way it doesn't move around in the bed.
  20. Aug 7, 2009 at 1:18 PM
    Mandy3206
    Mandy3206 Well-Known Member
    San Juan PR
    Sand Pearl Black 06 6spd DC SB TRD OR Moded
    Great idea, I would have to check my stock of pvc pipes remains.
    This will solve me a problem..............
