Water spots on paint????
Discussion in 'Detailing' started by pinktaco808, Feb 16, 2025.
  1. Feb 16, 2025 at 7:32 PM
    pinktaco808
    pinktaco808 [OP] Hot Steppa
    Water spot on paint from rain week ago. Tried cleaning with chemical guy waterspot removal. Never really help. I can still see the outline of every water spot still. Am I doing something wrong. Help please
  2. Feb 16, 2025 at 7:36 PM
    jpg366
    jpg366 Well-Known Member
    AL
    09 Silver Prerunner SR5
    Hitch, Running Boards
    Vinegar?
    pinktaco808[OP] likes this.
  3. Feb 16, 2025 at 7:39 PM
    pinktaco808
    Tried that first. What step you do for use
  4. Feb 16, 2025 at 7:46 PM
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
    Try polishing it off
  5. Feb 17, 2025 at 12:09 AM
    pinktaco808
    Never work
  6. Feb 17, 2025 at 12:34 AM
    mit88
    mit88 Well-Known Member
    Planet earth
    Set a towel on top of the effected area, spray vinegar on the towel till it’s soaking wet, let it sit as much time as necessary for the vinegar to soften/dissolved the mineral off the paint, polish and wax the surface. That’s what I did to my car which was parked by the sprinkler for long period of time.
    usmc2msu and pinktaco808[OP] like this.
  7. Feb 17, 2025 at 1:33 AM
    4xdog
    4xdog Well-Known Member
    Santa Fe, NM
    03 DC TRD OR, 15 DC TRD OR, 08 RX350, 62 TR3B
    Rainwater shouldn’t be as hard as something like tap or well water.
    Are you sure they’re mineral deposits? I was helping a girlfriend clean her 2023 Lexus RX 350 the other week and what initially looked like water spots on the hood turned out to be clearcoat defects(!)
    JohnDoeFasho likes this.
  8. Feb 17, 2025 at 9:50 AM
    T-Rex266
    Elon
    Post up pix if you can and what polishing pad you are using. If it’s really bad, you’ll need an aggressive compound pad and heavy duty compound.
  9. Feb 17, 2025 at 4:34 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    That some nasty rain if it etched the paint only a week later. Can’t imagine the rain water being that hard.
    TS4x4 and JohnDoeFasho like this.
  10. Feb 18, 2025 at 2:24 PM
    pinktaco808
    Never polish pad, by hand. I'll try post when I get home. It very faint only can see at angles hoe my phone van capture it. It garage kept and only driven twice a week. It poured last week and was sunny right after. The truck is ceramic coated.
  11. Feb 18, 2025 at 2:33 PM
    T-Rex266
    Elon
    Then you will want to get a heavy cutting compound with heavy cutting polish. I had a client who had spots alllll over her brand new vehicle and had to do this.
  12. Feb 18, 2025 at 6:39 PM
    pinktaco808
    So went again with the chemical guy water spot remover. It removed most of it, but still can see parts of the waterspot
  13. Feb 19, 2025 at 3:20 PM
    AZAutoAesthetics
    AZAutoAesthetics Member
    It sounds like the water spots might have etched into the clear coat, which is why they’re still visible even after using a remover. Chemical removers usually work on surface-level mineral deposits, but once the damage sets in, you may need a light polish or clay bar treatment. Try using a fine clay bar with a proper lubricant to see if it lifts the residue. If that doesn’t work, a finishing polish with a microfiber or foam pad should help remove the outlines. To prevent future spots, consider using a water-repelling sealant or window tinting when possible.
  14. Feb 20, 2025 at 2:33 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Get some wire wheel cleaner, spray one section at a time with the top first. Then with a micro rag spread it evenly and rinse off good. This works extremely well and is better than anything I have used in my 40 years of detailing. Don't waste your money on Sud Factory water spot junk. No need to wet sand, buff or home remedies to get the stains off but that rainwater spots could have been acid rain, but the wire wheel cleaner will work!
  15. Mar 4, 2025 at 2:28 PM
    pinktaco808
    It won't haze or screw the paint???
  16. Mar 4, 2025 at 2:39 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    I found this to be one of the most useless products they make.
    If you have some really gnarly water spots that won't come off, the SudsFactory stuff is insane. It will remove any other coatings, including real ceramic's, but it'll get your spots off with no paint damage.
    Don't know why the other user doesn't like them. I've tried everrrryyyything and that stuff is a miracle cure. I have both the paint and glass versions and with absolutely zero effort, all the spots I've ever tried removing comes off. It's the only stuff that has gotten off stubborn spots that even a razor blade, claybar, buffers, and every other home concoction won't remove. Things that appeared etched vanish.
  17. Mar 4, 2025 at 3:45 PM
    VaToy
    Parts Unknown
    spray on a wet surface one section at a time, rub it in and rinse. Start on the top and work down, rinse well as you go
  18. May 5, 2025 at 6:25 AM
    stielinc
    stielinc Well-Known Member
    SPOT-X works well on windshields and glass etc. getting hard water marks up. I'm not sure about paint though. Can't hurt to try it in a inconspicuous spot.
  19. May 30, 2025 at 8:50 AM
    JohnDoeFasho
    JohnDoeFasho St Petersburg, FL
    St Petersburg
    2009 TRD Sport DCLB
    OTT Tune
    You use a razor blade on your paint…?
  20. May 30, 2025 at 9:14 AM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    on the glass when trying to remove stubborn spots
