Water spots on paint????
Discussion in 'Detailing' started by pinktaco808, Feb 16, 2025.
  1. May 30, 2025 at 9:18 AM
    JohnDoeFasho
    JohnDoeFasho St Petersburg, FL
    St Petersburg
    2009 TRD Sport Crew Cab Long Bed
    OTT Tune
    Ahhh… I was gonna say “are you f*ckn nuts?”
  2. May 30, 2025 at 9:34 AM
    Blakeus Maximus
    Blakeus Maximus Well-Known Member
    Southwest
    2000 TACOMA TRD 4X4
    Clay bar for the paint fellas.
  3. May 30, 2025 at 9:36 AM
    JohnDoeFasho
    St Petersburg
    OTT Tune
    Clay bar doesn’t fix etching. It removes contaminants.
  4. May 30, 2025 at 9:38 AM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    Haha yeah noooo. I have used a plastic razor blade on paint but that's a different topic lol.
    Guess you've never had water spots that bad on the paint before. In my case, clay has always been useless for this. The Suds Factory stuff works insanely great though. So great it will even take off Ceramic Pro :/
    JohnDoeFasho[QUOTED] likes this.
  5. May 30, 2025 at 9:47 AM
    JohnDoeFasho
    St Petersburg
    OTT Tune
    That Suds Factory stuff sounds like a solvent… Like a lacquer. Idk sketches me out.
  6. May 30, 2025 at 9:47 AM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    No issues on multiple cars even my 38 year old Supra. It's the only product I've found that actually works and I've tried everryyyyyything including all the homebrews. The water in Phoenix has a ton of calcium and it puts harsh spots on everything instantly. Aside from wetsanding, they make the best product I've used for this. It really does work as well as it does in the videos.
  7. May 31, 2025 at 2:53 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    I have said it before and again. Best stuff is wire wheel cleaner. Sud Factory can't touch this!
  8. May 31, 2025 at 4:07 AM
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    ...whatever you do, be careful, some of these suggestions sound like they could give you a bigger issue than water spots....if anything, perhaps try whatever you feel is worth a shot after plenty of due diligence, on an inconspicuous area first to see how it affects the paint
    JohnDoeFasho likes this.
  9. May 31, 2025 at 7:56 AM
    JohnDoeFasho
    St Petersburg
    OTT Tune
    Agreed… Once you get good at detailing you realize you can fix anything on some horizon. Key is to protect it/get it in the right spot to bide you time to get to that ultimate high effort detail.
    Gotta be comfortable balancing time/effort and the current state of affairs. My wife’s newer Lexus was used from the dealer with 20k miles and they sealed over what appear to be a lot of previous small contaminants from what I presume to be a tree that the previous owner would park under… Bothers me but looks good enough from 5 feet that in not going to lose my mind addressing it now as I know it’s well protected with what I’ve done.
    Canadian Caber likes this.
  10. May 31, 2025 at 8:11 AM
    soggyBottom
    soggyBottom Well-Known Member
    Some 120 grit sand paper should take the spots right off
