Water stuck somewhere....
Discussion in '1st Gen. Tacomas (1995-2004)' started by RattleTractor, Nov 28, 2008.
  1. Nov 28, 2008 at 4:50 PM
    RattleTractor
    RattleTractor [OP] Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
    hey so I did some off roading today with a LOT of mud and puddles. my 96 taco was submerged up past the 32" tires... what fun.
    on the way home (back on roads), however, i noticed a sloshing sound coming from the passenger side back seat area when i accelerate/put it into first. it sounds like the water moves from around the back of the front seat to the back of the cab area, but a friend and i checked and we couldnt find where the water is.
    any suggestions/answers as to where the water is?
  2. Nov 28, 2008 at 5:22 PM
    Cobra69
    Cobra69 Well-Known Member
    Taxachusetts (Massachusetts)
    02 Tocoma TRD Expedition Setup
    2002 Tacoma TRD Access Cab, Deckplate Mod.,Grey wire Mod.,Cobra CB,Ext. Diff. Breather,E-locker rear only for now,CBI Custom Winch bumper, SAW 2.0, All Pro 5" leaf packs+Bilstiens 5150-10" shocks,Cooper STT 285x75x16 on Wheelers Type B 16x8 rims, Budbuilt front+Mid skid plates, Custom transfer crossmember+skidplate,Trail-Gear sliders,custom roof-rack,Ultimate-air CO2 tank,4-Hella 500 H.I.D. Lights,Atlas 10,000 lbs winch. Custom Half-doors for the summer.
    Might be in your exhuast...............or your door maybe.
  3. Nov 28, 2008 at 5:30 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Doors have drain holes in the bottom.......It would burn off/evaporate in the exhaust..........hmm................Is there anything under the seats in the rear? Maybe have a friend ride in the back and try to localize where the water sound is comming from. :confused:
  4. Nov 28, 2008 at 5:48 PM
    RattleTractor
    Harry
    VT
    yea not the exhaust (evap) and not in the door because i got out and shook the door and no sound... is it in the bottom of the cab or something?
  5. Nov 29, 2008 at 5:55 AM
    RattleTractor
    Harry
    VT
    im just worried its gonna rust the inside of whatever the waters in and im gonna be in biiiiig trouble
  6. Nov 29, 2008 at 8:08 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    climb under the truck and see if there are some rubber grommets you can pull out and see if water starts to drain out............and if so...go for a little drive and see if most of it wont drain out.
  7. Nov 29, 2008 at 8:32 AM
    HerNameIsLucy
    HerNameIsLucy I miss Lucy. :-(
    Equador. Don't know why.
    RIP Lucy.
    She's gone but not forgotten.
    Could it be in the frame rails? I can see there's holes in mine. No clue how you'd get it out if it was.
  8. Nov 29, 2008 at 8:56 AM
    oldtacomaguy
    oldtacomaguy four forty four
    Dave
    SE Conn.
    08 SR-5 4WD Impulse Red Pearl
    Alpine deck and amp, Polk speakers front and rear, Kenwood subwoofer, windows tinted to 20%, Sockmonkey decals, TSB, Eibach springs and Bilstein 5100's
    Thats what I was thinking, maybe in the frame rails. If its there it will run out eventually, but in Vermont it will freeze pretty soon and stop sloshing around.
  9. Nov 29, 2008 at 3:02 PM
    RattleTractor
    Harry
    VT
    the frame rails have holes in the bottom, and theres no water in them (just some mud)
    im 99% sure its in the body, and somewhere under the cab floor.
  10. Nov 29, 2008 at 11:24 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    You checked where the jack and jack tools are at right?
  11. Nov 30, 2008 at 9:53 AM
    RattleTractor
    Harry
    VT
    yea. didnt find any water. i can check again
  12. Nov 30, 2008 at 10:42 AM
    johnny12345
    johnny12345 Well-Known Member
    vancouver island, canada
    09 tacoma SR5
    break out the drill.......lol
