Water-tight bed storage boxes
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Hammer16, Feb 5, 2016.
  1. Feb 5, 2016 at 9:34 AM
    Hammer16
    Hammer16 [OP] Well-Known Member
    Western MA
    2016 Quicksand Tacoma DCLB TRD OR
    Does anyone know if someone out there makes some type of rubber gasket for the large slots in the bottom of the bed storage boxes? I'm looking for something that will keep water and dirt/mud out. I drive on a lot of dirt roads and even with the doors shut and a clean bed, those boxes are always dirty inside. I hate to store anything in there with how dirty it is.
    JesseQtheBody likes this.
  2. Feb 5, 2016 at 9:42 AM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    Not idea if someone does.
    I also don’t know about the ’16’s. but i know with the 2nd gens just sealing the door most likely wont work. They have slots in the bottom edge that the door slides into and I think thats where the water is coming in from.
  3. Feb 5, 2016 at 9:45 AM
    Hammer16
    Western MA
    That's exactly the same thing that happens on the 16's. Sucks that Toyota didn't see that and fix it. It makes those boxes almost useless in wet/dirty environments.
  4. Feb 5, 2016 at 10:10 AM
    TnRedNeck721
    Zach
    TN
    07 TRD off road 4WD
    Yeah i agree! I keep some rope and bungee cords and a 4x4 post in them. I was not sure if toyota changed them or not on the ’16 but does not sound like they did.
    one night i was going down some old logging roads with a guy from here that has a 1st gen and he got a flat tire. Maxed out both our jacks and barley had room to get new tire on. Cut a short pice off an old 4x4 post to keep in the bigger bin so that i have a little extra room. rope and bungee cords can all get dirty or hell even stolen and not much is lost. I would not keep much els in them like a bitch or anything.
  5. Feb 5, 2016 at 10:14 AM
    Shellshock
    Iowa
    Yep. I never used them on my 2005 and likely won't on the 16 either. Ive got a pelican case and a cheap Plano case I keep in the back for water tight storage.
  6. Feb 5, 2016 at 10:52 AM
    tacitos
    tacitos Tah-Key-Toes
    16 TRDORDCLBJBL
    check out my build, I have the first of two parts down. I'll be working on completing it this weekend.
  7. Feb 5, 2016 at 10:55 AM
    Hammer16
    Western MA
    The sealer would help but the majority of the water and dirt that's coming into those boxes on my truck is coming in from the bottom via the slots. That's what I'm trying to find some type of rubber gasket/fitting for.
  8. Feb 5, 2016 at 10:57 AM
    tacitos
    16 TRDORDCLBJBL
    That's the part I'll be working on tomorrow. I'm going to lay a thin vinyl sheet with double sided tape over the drain holes. So water will be kept out and whatever is in there won't slide around as much.
    If your looking just for drain plugs, check out mcmaster carr, they may have some there.
  9. Feb 5, 2016 at 11:02 AM
    Hammer16
    Western MA
    Thanks. Can you take a few good pictures tomorrow? I'm curious how it will work
  10. Feb 5, 2016 at 11:03 AM
    tacitos
    16 TRDORDCLBJBL
    of course, I will be posting on my build thread.
  11. Feb 5, 2016 at 11:04 AM
    moe2o4
    moe2o4 Well-Known Member
    Corey
    Pittsburgh PA
    2016 SR Silver 2.7L 5 Speed
    OME 3" Lift, 32" Tires, Lots of Mods!
  12. Feb 5, 2016 at 11:06 AM
    tacitos
    16 TRDORDCLBJBL
    moe2o4[QUOTED] likes this.
  13. Feb 5, 2016 at 1:46 PM
    scocar
    scocar hypotenoper
