Water under driver side floor mat...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Fletcher37, Feb 12, 2023.
  1. Feb 12, 2023 at 11:22 PM
    Fletcher37
    Fletcher37 [OP] Well-Known Member
    PNW
    Hey guys,
    This winter I've been finding a wet spot under the driver's side floor mat. I have a 2019 TRD OR. New windshield put in several months ago. I live in Oregon so it rains a lot. Just noticed it a couple weeks ago after cleaning the floor mats.
    Other than taking it back to the windshield guys, should I be checking anything else under there? It's a small amount if water. No pooling, but enough that on cold mornings I have moisture on the inside of my windows.
    TIA!
  2. Feb 12, 2023 at 11:25 PM
    ET_Quila
    ET_Quila Well-Known Member
    ET
    Ohio
    2033 4Runner Trd Off Road
    If you've had the vehicle through more than this winter, but you only noticed the water after the windshield was replaced, I'd start there.
    blu92in99 likes this.
  3. Feb 13, 2023 at 3:46 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Concern would be rust, wiring corrosion and mold.
    Get back to the glass shop
  4. Feb 13, 2023 at 6:13 AM
    dylanbike1
    dylanbike1 Well-Known Member
    Dylan
    2017 Tacoma TRD off road
    Do you have a sunroof? If yes... check that the sunroof drain tubes are clear. I parked outside and debris from nearby trees during rainstorms eventually clogged my drain tubes and water started appearing in my driver side footwell.
    I used a 6 foot cut length of bicycle cable housing (5mm diameter), and pushed it through the drain holes to clear them. Took all of two minutes after I had the cable housing in hand.
    Irons likes this.
  5. Feb 13, 2023 at 11:05 AM
    Fletcher37
    PNW
    No sunroof. I'll check in with the glass guys. Probably didn't notice it initially because it was replaced during the dry season.
    I checked the windshield cowl area. Sprayed water all over the windshield. Cleaned out the gutters and drain hole. Didn't really see where water would build up enough to seep in.
    Looked under the driver's side dash. No obvious water track to follow. Maybe a little damp on the carpet near the center console hump.
  6. Feb 13, 2023 at 12:01 PM
    hafjell
    hafjell Well-Known Member
    Idaho
    2023 TRD OR MT
    Dumb question, but you're not bringing the water into the vehicle every time you enter, are you? Lots of snow here this winter and it's rare not to track in snow which then melts...
    zoo truck likes this.
  7. Feb 13, 2023 at 1:55 PM
    Fletcher37
    PNW
    I thought about it. The first time I noticed the water, my wife had taken the truck to the coast on a rainy, windy day to photograph the king tides. I had guessed the water was from her getting in and out with wet gear. I don't think it's that. After letting it dry out, I'd get back in after a rainy day and find a damp spot again before getting in.
  8. Feb 13, 2023 at 4:00 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    Also check for water behind the driver’s side kick panel. There have been reports(threads) detailing gross electrical problems due to the windshields leaking.
  9. Feb 14, 2023 at 7:27 AM
    TexasTacoma23
    TexasTacoma23 New Member
    2020 Tacoma 4WD OR
    Have you messed with your firewall any? I ran my trench light wiring through the rubber boot in my firewall (driver side) and noticed sometimes I get some water on my driver side floor mat when it rains.
  10. Feb 14, 2023 at 7:36 AM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    Do you have a roof-rack?
  11. Feb 14, 2023 at 7:43 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    This is how I had water under my carpet. Snow was tracking onto the floor mats, melting, then draining down the anchor holes on the floor mats. Now I keep small towels in the truck to lay on the floor mats to soak up the water.
    hafjell[QUOTED] likes this.
  12. Feb 14, 2023 at 7:48 AM
    mrtonyd
    mrtonyd Well-Known Member
    Tony
    Colorado
    2019 TRD OR DCSB cement
    my windshield has been replaced a few times on my 2019 off road. they messed up the glue around the edge of the glass one time and i could hear the wind making a whistling sound through the gap when i would get to about 45-50 mph+. have you heard anything different since the windshield was replaced? i would think thats the main way water would be getting in if the windshield was installed incorrectly.
