Water under driver side floormat
Discussion in '2nd Gen. Tacomas (2005-2015)' started by andyzx6r, Jul 18, 2015.
  1. Jul 18, 2015 at 8:32 AM
    andyzx6r
    andyzx6r [OP] Well-Known Member
    Atlanta
    Super White TRD Sport
    So last night I went out to my truck because I forgot my wallet. Look down and thought man my floomat is dirty so I took it out to shake it off and it was wet on the underside. Looked at the floorboard and sure enough my floor is soaked. Really weird. Any ideas? A/C? It has rained in the last few days but shouldn't be inside my truck.
  2. Jul 18, 2015 at 8:41 AM
    Justinlhc
    Justinlhc Not looking for a relationship
    Heater core lines run along that side. Hopefully one isn't leaking or even worse, the heater core itself. Can you tell if it's antifreeze?
  3. Jul 18, 2015 at 9:42 AM
    andyzx6r
    Atlanta
    Definatley water. I am wondering if running the A/C for so long may have frozen the vents and then thawed. Maybe?
  4. Jul 18, 2015 at 8:02 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Not if the AC is working properly, the system should never freeze up. Has it been raining? There is a TSB for a body seam on the drivers and passenger side not being fully sealed from the factory. I do not know if it applies to your truck ( year etc ). I'll see if I can locate it.
    For a 1997 - 2004
    http://www.customtacos.com/tech.old/files/tsb/BO02600r2-9704-Leak.pdf
    For a 2005
    http://www.customtacos.com/tech.old/files/tsb/BO00405r-05-Leak.pdf
  5. Jul 19, 2015 at 3:50 AM
    Billo
    Billo Member
    I have a 2012 Taco and had a similar problem, but only on passenger side. It turned out to be a clogged A/C drain hose.
    Billo
  6. Jul 19, 2015 at 10:12 AM
    andyzx6r
    Atlanta
    Well it hasnt done it in a couple of days now. However when I commute to work will be the test. It is about an hour drive and I run my AC on full during the commute because it has been so hot here lately. FYI it is a 2013 so I guess that TSB does not apply.
  7. Jul 20, 2015 at 7:52 AM
    ranger098
    ranger098 Well-Known Member
    Brian
    Minnesota
    Look for the round rubber plug that is near the seat... if that isnt in there you would have a 2" open hole to the underside of your truck that could have maybe let rain water in. Thats the plug that i cut a slit into to run wiring to the back of my truck.....
