Watered down gas?
Discussion in '1st Gen. Tacomas (1995-2004)' started by batcat420, Jan 26, 2015.
  1. Jan 26, 2015 at 4:43 PM
    batcat420
    batcat420 [OP] I'm a Blue Ribbon man.
    Scott
    Atlanta
    2022 Lunar Rock SR5 Trail Edition
    I have a sneaking suspicion that I got some bad/watered down gasoline. Ever since I filled up (at a station I've never used before) the truck has been making a new, annoying clicking noise. Almost like the sound of a baseball card flapping against the spokes of bicycle in motion, but not as loud. It happens whenever I give it gas, but not during idle. Any ideas? 2000 PreRunner, 2.7L.
  2. Jan 26, 2015 at 5:37 PM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    2000 Prerunner SR5 TRD 2WD
    Throw a can of seafoam in it and see what it does.
  3. Jan 27, 2015 at 6:49 AM
    Tinmann
    Tinmann Well-Known Member
    NorCal
    If you think you have some punky fuel that has water in it, get yourself some Sta-Bil Marine and put it in the tank. The stuff will displace the water and is safe to use in your truck even though its advertised for marine use. Or get anything else that will displace the water.
  4. Jan 28, 2015 at 7:16 AM
    Brake Weight
    Brake Weight But it hasn't rained in weeks...I'll make it.
    Deep South near the Third Coast
    Taco pulling 33s and a B6 pushing 33psi
    Weld on sliders, fiberglass shell, 12k winch in an Elite Offroad bumper, front Aussie Lunchbox
    Heet in the red or yellow bottles will fix it. If you have easy access to methanol race gas, put about a quart of that in with a full tank. You need something that will mix with the water to make it combustible.
  5. Jan 28, 2015 at 9:11 AM
    batcat420
    Scott
    Atlanta
    Thanks for the ideas. I'm going to fill up with 93 as soon as I hit half a tank or so and see if that helps. If not, I'll give these suggestions a shot.
  6. Jan 28, 2015 at 9:23 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    Hmmmmm. Where is the water "displaced" to???
  7. Jan 28, 2015 at 9:34 AM
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    It's suspended by the alcohol and burned out.
  8. Jan 28, 2015 at 9:44 AM
    wee
    wee Well-Known Member
    If the water amount is enough it will hardly run and will ruin your injectors....I got bad gas in my HHR a few years ago....I noticed a ruff idle within a mile or two.....Put a can of seafoam in at a parts store and then drove back to the gas station.....They put another can of gas treatment in the tank and I drove it home....Barely made it home and had the car towed to the dealership the next day.....They found water in the gas and believe it are not the station paid the repair bill.
    Brian
  9. Jan 28, 2015 at 10:42 AM
    Indy
    Indy Master of all I survey.
    Octane has nothing to do with water in the gas, it makes the gas harder to burn by raising the flash point. If you're already having trouble burning the gas if anything it may make the problem worse.
  10. Jan 28, 2015 at 10:54 AM
    maju
    maju Well-Known Member
    Davenport Fl
    2010 DC Silver TRD Sport 4x4
    Undercover tonneau, Scangauge II, Garmin GPS, Michelin LTX M/S2
