Waterport GB *CLOSED-Moved to new thread*
Discussion in 'Automotive Group Buys' started by Pirhett, Oct 26, 2016.
  1. Oct 26, 2016 at 7:02 PM
    Pirhett
    Pirhett [OP] Instagram @pirhett_ship
    Rhett
    San Diego
    2014 TRD Sport 4x4 DCLB MGM
    Stock...
    WaterPort is a San Diego based company that sells top quality water supply sources that mount to any vehicles in different ways. I have been in touch to get a group buy going and got the go ahead!
    There are 5 total options:
    Option 1: Trailer Hitch Mount
    WaterPORT_TrailerHitchMount_1024x1024.jpg WaterPORT_TrailerHitchMount_PIC_1024x1024.jpg
    MSRP: $229.99
    WaterPORT Trailer Hitch mount is a plug and play system that fits all standard 2” trailer hitch mounts. Simply slide in your mount, install cotter pin and your ready to go! It also acts as a step! All necessary hardware is included. The custom design sits sleek under your license plate with no obstruction. Simply connect, fill and your ready for use. If a pressurized water source is unavailable, the tank can be filled and then pressurized by using a standard bicycle pump. Either method allows the user 5+ showers of fresh pressurized water.
    Items Included:
    • 3.3 gallon tank
    • 6 ft Hose
    • Quick release
    • Multi Pattern Spray Nozzle
    • Aluminum Mount (Powder coated black)
    • End cap
    • Pressure Regulator
    • Schrader valve
    Option 2: Bed Mounted (Side or Top Spout, please let me know)
    MSRP: $199.99
    Our Bed Mounted WaterPORT is a 3.3 gallon pressurized tank that mounts in the bed of any pickup truck. The custom designed mounting bracket enables you to securely mount the tank in the bed of your pickup truck. This tank is easily filled and pressurized simultaneously with a standard garden hose. Simply connect, fill and your ready for use. If a pressurized water source is unavailable, the tank can be filled and then pressurized by using a standard bicycle pump. Either method allows the user 5+ showers of fresh pressurized water.
    Items Included:
    • 3.3 gallon tank
    • 6 ft Hose
    • Quick release
    • Aluminum bed mount
    • 90 degree bed mount bolts
    • End cap
    • Schrader valve
    Option 3: Frame Mounted
    Screen-Shot-2015-07-30-at-9.24.47-PM-283x283.jpg Screen-Shot-2015-08-26-at-10.18.50-PM-283x283.jpg Screen-Shot-2015-08-26-at-10.33.58-PM-283x283.jpg
    MSRP: $159.99
    Our Frame Mounted WaterPORT is a 3.3 gallon pressurized tank that connects to the frame of all Toyota Trucks and other select trucks and SUV's. This tank is easily filled and pressurized simultaneously with a standard garden hose. Simply connect, fill and your ready for use. If a pressurized water source is unavailable, the tank can be filled and then pressurized by using a standard bicycle pump. Either method allows the user 5+ showers of fresh pressurized water. Our tanks are easily mounted to the frame of your vehicle using steel straps that will keep it securely fastened in any type of terrain. If you would like to know if your vehicle is equipped for a frame mount please email adrian.frick@thewaterport.com.
    Items Included:
    • 3.3 gallon tank
    • 6 ft hose
    • Quick Release
    • 4 j-bolts
    • 3/4” cap
    • Double Trunnion straps
    • Lock nut
    • Schrader Valve
    • End cap
    Option 4: No Mounting Hardware - Side Spout
    WaterPORT_SelfMount_Side1_1024x1024.jpg Screen_Shot_2016-06-27_at_11.11.26_PM_1024x1024.jpg
    MSRP: $119.99
    WaterPORT is a 3.3 gallon water release system that allows the user fresh pressurized water on the go. Our tank only set-up allows the user to custom mount the tank or place it anywhere inside their vehicle. Simply fill the WaterPORT with a standard garden hose for 35 seconds and enjoy fresh pressurized water in any location. Our tanks fill to 50 plus PSI using a pressure regulator and can hold pressure for 30 plus days!
    Items Included:
    • 3.3 gallon tank
    • Quick connect
    • Hose Nozzle
    • 6 ft hose
    • Schrader Valve
    • End cap
    Option 5: No Mounting Hardware - Top Spout
    Screen_Shot_2016-06-27_at_11.17.16_PM_1024x1024.jpg WaterPORT_SelfMount_Top1_1024x1024.jpg
    MSRP: $119.99
    Items Included:
    • 3.3 gallon tank
    • Quick connect
    • Hose Nozzle
    • 6 ft hose
    • Schrader Valve
    • End cap
  2. Oct 26, 2016 at 7:02 PM
    Pirhett
    Rhett
    San Diego
    Stock...
    As of now the pricing:
    *******Round 1: 1-65 will be first to get their codes and get them shipped out once this goes live! Round 2: Anyone after 65 who gets in before this goes live will get the same discount but have to wait 2-3 weeks for products to be made then shipped out. ******
    20 People = 15%
    30+ People = 20%
    Shipping is $30 (Pick up option is free)
    Order Details:
    Payment will be through the main website after I pm you all a code. This code is not to be shared with anyone outside of those on the list. You all know the drill by now! As soon as I get word of the code you'll know.
    Lead Times:
    As of now 3-5 business days to allow for shipping.
    If you are not signing up and just waiting for this to hit 30 people to get the 20% off you are holding back the Group buy.
  3. Oct 26, 2016 at 7:03 PM
    Pirhett
    Rhett
    San Diego
    Stock...
    Over 120 sold via Tacomaworld!
  4. Oct 26, 2016 at 7:04 PM
    3378jakesr5
    3378jakesr5 AOF, trucks, guns, repeat....
    jake
    littleton colorado
    2006 DCLB silver taco. Soild axle swapped, Bumpers, armor, expo..... Money pit. Yata yata yata
    Better to ask what I have not done.
    Mine.
    lobsterbait likes this.
  5. Oct 26, 2016 at 7:05 PM
    Pirhett
    Rhett
    San Diego
    Stock...
  6. Oct 26, 2016 at 7:05 PM
    3378jakesr5
    jake
    littleton colorado
    So i get the sample one right???
  7. Oct 26, 2016 at 7:09 PM
    3378jakesr5
    jake
    littleton colorado
    Hey atleast i got my post in the list. :D
  8. Oct 26, 2016 at 7:12 PM
    3378jakesr5
    jake
    littleton colorado
    :rofl::rofl::rofl: You would not have noticed if i didnt say anything.
    Pirhett[QUOTED][OP] likes this.
  9. Oct 26, 2016 at 7:17 PM
    Pirhett
    Rhett
    San Diego
    Stock...
    Any wondering eyes are more than welcome to ask me questions via comment or PM!
    The vendor owner is going to be on his honeymoon :woot::woot::woot: thus why this is a feeler as of now.
  10. Oct 26, 2016 at 7:40 PM
    Jrobertson
    Jrobertson Well-Known Member
    James
    green valley (Henderson)
    2010 Tacoma off road. 4x4
    Stock. For now.
    Ok so with the frame mount under the truck. Do we have a good place to mount it on our trucks? And is it durable enough to not break from rocks hitting it while offroading
  11. Oct 26, 2016 at 7:42 PM
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    Sign me up for option 4!
    Pirhett[OP] likes this.
  12. Oct 26, 2016 at 7:47 PM
    Pirhett
    Rhett
    San Diego
    Stock...
    Adrian the owner of waterprot explained there is a ton of room for mounting options. You could even do no mounting option and make it work up by the factory spare spot. If it breaks or cracks he will replace it free of charge even shipping on him.
  13. Oct 26, 2016 at 7:47 PM
    Pirhett
    Rhett
    San Diego
    Stock...
    Sweet man thank you!
  14. Oct 26, 2016 at 7:49 PM
    Pirhett
    Rhett
    San Diego
    Stock...
    Just got a text saying out of the 500 sold so far Adrian hasn't had a single one break. 2 had been replaced due to manufacture defect. 90 day warranty from waterport, and 1 year from manufacture but and I quote "Adrian is always willing to help". Hope that clears up some questions.
    3378jakesr5 likes this.
  15. Oct 26, 2016 at 8:03 PM
    Pirhett
    Rhett
    San Diego
    Stock...
    FYI no minimum needed in order to get the 15% off!
  16. Oct 26, 2016 at 8:17 PM
    Boogyman
    Boogyman Well-Known Member
    Phoenix
    Corpus Christi, TX
    2022 Lunar Rock Trail Edition
    I'd be in for option 4 if we get 20%
  17. Oct 26, 2016 at 8:24 PM
    Pirhett
    Rhett
    San Diego
    Stock...
    Figured once I saw your insta comment haha I'll add you in :cheers:
  18. Oct 26, 2016 at 8:25 PM
    Boogyman
    Phoenix
    Corpus Christi, TX
  19. Oct 26, 2016 at 8:25 PM
    Boogyman
    Phoenix
    Corpus Christi, TX
    I might be in for 15 depending on timing
  20. Oct 26, 2016 at 8:25 PM
    Pirhett
    Rhett
    San Diego
    Stock...
