Waterport GB *CLOSED-Moved to new thread*
Discussion in 'Automotive Group Buys' started by Pirhett, Oct 26, 2016.
  1. Nov 15, 2016 at 3:12 PM
    #601
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    In! pending available funds. been eyeing these for awhile.. Then was going to make my own.. but this price might be too good to pass up..
  2. Nov 15, 2016 at 3:16 PM
    #602
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Can anyone get me the Dimensions of this bad boy? I need to see if I have room on my Prinsu rack.
  3. Nov 15, 2016 at 3:17 PM
    #603
    Robman
    Robman Well-Known Member
    Rob
    Hawaii
    '14 Tacoma Double Cab
    Speaking from a position of inexperience and without authority, I chose the side spout because I plan to either strap it to my frame or mount it to the bed rail under my bakflip. At the time of purchase, I couldnt see spending the extra $40 for the kit.
    mtbkr[QUOTED] likes this.
  4. Nov 15, 2016 at 9:57 PM
    #604
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I think I read :boink: somewhere in the thread the tank is ~5x7x30. :notsure:
    XPOTRPR[QUOTED] likes this.
  5. Nov 15, 2016 at 10:03 PM
    #605
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    :confused: but why would I read when I have you fine people...
    thank you. :cheers:
  6. Nov 15, 2016 at 11:38 PM
    #606
    cubiclesurfer
    cubiclesurfer Well-Known Member
    Kailua-Kona, HI
    this is probably a stupid question, but how do you re-pressurize the system if you don't use a hose to fill it up?
    BWS and fatfurious2 like this.
  7. Nov 16, 2016 at 3:13 AM
    #607
    BWS
    BWS Well-Known Member
    Kapolei HI
    2014 DCSB TRD OFFROAD 4X4 6SPEED
    Kings All Around, LR UCA, Allpro leafs, BHLM
    Gotta use a bike pump to re-pressurize. I'm pretty sure it comes with a Schrader valve on one side
    cubiclesurfer[QUOTED] likes this.
  8. Nov 16, 2016 at 6:47 AM
    #608
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Is there a filler/spout on these besides the hose option? Say I'm out camping, it runs out, and I want to refill it with my Rotopax... That possible?
    mtbkr and cubiclesurfer like this.
  9. Nov 16, 2016 at 9:01 AM
    #609
    cubiclesurfer
    Kailua-Kona, HI
    wondering the same thing... how to manually fill, then re-pressurize (using bike pump).
  10. Nov 16, 2016 at 9:04 AM
    #610
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    exactly. I have a power pack that I use to power to camping essentials... that also has a small compressor built in. I can set the PSI I want digitally, and it will pump until it reaches said PSI and shut off. should work perfect. that is IF... you can re-fill and pressurize.
    fatfurious2 likes this.
  11. Nov 16, 2016 at 10:34 AM
    #611
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I would love some pictures if you get the opportunity!
    Also, and this is for anyone... is there anything preventing it being rotated so that the 7" height becomes the width and makes the height 5"? I would like to gain those 2" in clearance.
  12. Nov 16, 2016 at 11:10 AM
    #612
    mtbkr
    mtbkr Well-Known Member
    Allan
    Spring, TX
    2014 Super White DCSB SR5 4x4
    modifying my truck one group buy at a time
    I'm interested to know this too. It would be good to be able to refill from another water container in case you are out there far from any water source with faucet.
  13. Nov 16, 2016 at 6:51 PM
    #613
    kaptankaos
    kaptankaos Well-Known Member
    Martin
    Killeen, TX
    09 Prerunner
    Mine came in today...
    Should have time to look at putting it in place in the stock spare location tomorrow. At a Glance with the frame mount it looks like mounting to that crossmember should be no issue...
    Bat Taco and Pirhett[OP] like this.
  14. Nov 16, 2016 at 7:43 PM
    #614
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    I just paid for mine! Option 4
  15. Nov 17, 2016 at 10:56 AM
    #615
    Pirhett
    Pirhett [OP] Instagram @pirhett_ship
    Rhett
    San Diego
    2014 TRD Sport 4x4 DCLB MGM
    Stock...
    @kenstar @mrbedgood @TakeNoteS @TacoPretzel89 @NC_Husker @Acerwin @JeepAndrew @2ski4life7 @MAV2 @CVYota @swainick13 @renval @Logan503 @Spansfelder @geekhouse23 @PNWFJC @Styx2015 @captainbuttfloss @freedomriding @spilser @Boogyman @cubiclesurfer @94blake @Charles135 @seelyartacus
    Hey guys, not sure if Ive heard from you guys yet so wanted to touch base. Let me know if youre out or paid or how you feel about the number 23. Either way is all good and I dont mind if you guys need out. I get things come up. :cheers:
  16. Nov 17, 2016 at 10:58 AM
    #616
    WhiteNight
    WhiteNight Well-Known Member
    PDX
    13 DCLB SPORT
    Dynamat, Rigid E series 30", Rigid SR2 combo/Rigid grill, Redline elite hood struts, Clear Bra all over
    I have received mine deciding where to mount might have a custom mount being made to put it over the wheel well
    Pirhett[OP] likes this.
  17. Nov 17, 2016 at 11:38 AM
    #617
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    perfect!!
    thanks for the pics!
    so.. nothing preventing it from being mounted on its side.. even better. although, filling might be more difficult.
    regardless, cant wait! :goingcrazy:
    dtaco06[QUOTED] likes this.
  18. Nov 17, 2016 at 2:14 PM
    #618
    mrbedgood
    mrbedgood Isaiah 6:8
    North Carolina
    '11 MGM DCSB TRD Off Road 4x4
    Total Chaos +2" Long Travel Kit; King/TC 2.5 LT C/O w/ 16"x600; TC/CVJ Extended Axles; TC Spindle Gussets; King 2.5 RR shocks; All-Pro Expendition Leaf Pack; Pelfreybilt Sliders; Anti-Dark LED Hood Light mod; LED map and dome light mod; Bed lights; TRD Cold Air Intake; KB Voodoo Tailgate cap system; HomerTaco Thin Lip "Raptor" grille; sPod SE System w/ LCD Touchscreen; Baja Design OnX6 40"; Baja Design S2; Rigid Industries LED Rock Lights; Front Runner Slimline II Roof Rack; A.R.E. Z Series Camper Shell Projector BHLM Headlights (with custom wiring); Method Racing NVs 17"x 8.5; and Nitto Terra Grappers 265/60/17
    Hey dude I'm still in just been a little busy lately to make my purchase. Planning to this weekend tho
    Pirhett[QUOTED][OP] likes this.
  19. Nov 17, 2016 at 2:23 PM
    #619
    The Fluffer
    The Fluffer Keepin dick's hard and pussie's wet since 1990
    Andrew
    Scottsdale, AZ
    07 SWB X-runner /// 01 Jade Mica Tundra
    boughten
    dtaco06, XPOTRPR and Pirhett[OP] like this.
  20. Nov 17, 2016 at 2:29 PM
    #620
    Robman
    Rob
    Hawaii
    Received mine today....55 seconds before the water turns to a trickle. :frusty:
    WaterPORT on the ground, hose elevated about 3ft similar to a frame mount. Filled it up on regulated water pressure (about 60 psi) then again at unregulated (about 100 psi) and both times I got about 40 seconds of really usable pressure in shower mode and by 55 seconds the water was just trickling out. This happen to anyone else?
    Thanks,
    Rob
