Waterport GB *CLOSED-Moved to new thread*
Discussion in 'Automotive Group Buys' started by Pirhett, Oct 26, 2016.
  1. Nov 18, 2016 at 8:59 AM
    #641
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    then I stand corrected...
    IDK then.. I also dont have mine yet. interested to find out now.
  2. Nov 18, 2016 at 9:01 AM
    #642
    tacot0wn
    tacot0wn Mia San Mia
    CO
    07 DCSB on 35s. Slowly becoming #EAF
    I know what I'll be doing after work. I get off at 1400 MST and will be getting after it then, updates to follow after my test this afternoon
    dtaco06 and XPOTRPR like this.
  3. Nov 18, 2016 at 9:01 AM
    #643
    Robman
    Robman Well-Known Member
    Rob
    Hawaii
    '14 Tacoma Double Cab
    Personally, I am disappointed. It's not advertised to require a bike pump unless it loses pressure. And if i were going to go this route, i could have used any length of ABS and some fittings. I bought into the "magic".
  4. Nov 18, 2016 at 9:02 AM
    #644
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I've see quite a few psi numbers being thrown around here. I'm curious if there is a maximum rating from the manufacturer?
    What is the most pressure you have put in yours?
    What is flat mode? Laying on its 7" side?
  5. Nov 18, 2016 at 9:04 AM
    #645
    tacot0wn
    CO
    1. IIRC it's 50PSI per the manufacturer
    2. It's a setting on the spray head thingy
    Digiratus[QUOTED] likes this.
  6. Nov 18, 2016 at 9:04 AM
    #646
    Robman
    Rob
    Hawaii
    Laying flat on its long side, side exit for the water, holding hose about 3ft off the ground simulating a frame mount.
  7. Nov 18, 2016 at 9:05 AM
    #647
    socalktk
    socalktk Well-Known Member
    Kalvin
    San Gabriel Valley
    2016 DCLB TRD: OR
    Kings, Pelfreybilt skids, mobtown sliders, dakars, SCS
    i begin with filling it with a hose. It pressurizes that way. But as soon as I lose pressure after using the water, I use a bicycle pump to get more air in, or the viair.
    Sorry, flat mode was a spray option out of the nozzle. Its sprays out flat like the shower, but less water and more power.
  8. Nov 18, 2016 at 9:05 AM
    #648
    Robman
    Rob
    Hawaii
    Interesting, I haven't measured the PSI after filling. I thought about it but was concerned about water getting into my digital gauge.
  9. Nov 18, 2016 at 9:06 AM
    #649
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    awesome!
    I see what you are talking about regarding them stating it doesnt NEED a source of pressure. that is a little deceiving.. but regardless, I personally would still use a pump to add more pressure. it cant hurt right? more the better. and it only takes a couple seconds.
    from the nozzle.
  10. Nov 18, 2016 at 9:08 AM
    #650
    socalktk
    Kalvin
    San Gabriel Valley
    2016 DCLB TRD: OR
    I have a small bicycle pump, it takes more than just a couple seconds under the beating sun in the Mojave hahaha
  11. Nov 18, 2016 at 9:08 AM
    #651
    Robman
    Rob
    Hawaii
    Actually, I think it can hurt. They advertise that one of the components used to fill it up is a pressure regulator. The purpose would seem to be to prevent over-pressurization.
  12. Nov 18, 2016 at 9:09 AM
    #652
    tacot0wn
    CO
    wait, they advertised as having a PRV? I missed that I think
  13. Nov 18, 2016 at 9:09 AM
    #653
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    :notsure:
  14. Nov 18, 2016 at 9:10 AM
    #654
    The Fluffer
    The Fluffer Keepin dick's hard and pussie's wet since 1990
    Andrew
    Scottsdale, AZ
    07 SWB X-runner /// 01 Jade Mica Tundra
    boughten
    I have a C02 tank mounted in the bed I plan to use t hat to pressurize everything
  15. Nov 18, 2016 at 9:10 AM
    #655
    Robman
    Rob
    Hawaii
    The pressure regulator should have prevented that kind of damage. There are no visual signs of damage and at least one other user has reported the same findings as I have.
  16. Nov 18, 2016 at 9:11 AM
    #656
    socalktk
    Kalvin
    San Gabriel Valley
    2016 DCLB TRD: OR
    I just got back from The mojave road lol. I had to pressureize it with my handheld bike pump, it took a shitload of pumps to get quite a good amount of pressure. Guess ill be looking for an alternative bike pump .
  17. Nov 18, 2016 at 9:11 AM
    #657
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    within a reasonable amount..
    I mean come on guys.. if it doesnt have enough pressure.. use the valve and add some more until it does. IDK.. I guess I just dont see it as that big of deal.
    Smiley52 and dtaco06 like this.
  18. Nov 18, 2016 at 9:12 AM
    #658
    Robman
    Rob
    Hawaii
    Mentioned in the first few seconds of the video.
    socalktk likes this.
  19. Nov 18, 2016 at 9:13 AM
    #659
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    that's ideal, but I know not everyone has OBA. I have a small compressor I use for camping, and a hand pump for backup.. so I'll be good (hopefully).
    tacot0wn and dtaco06[QUOTED] like this.
  20. Nov 18, 2016 at 9:13 AM
    #660
    Robman
    Rob
    Hawaii
    When you receive yours and realize its just a plastic tank with some fittings, then let me know how you feel.
