Waterport GB *CLOSED-Moved to new thread*
Discussion in 'Automotive Group Buys' started by Pirhett, Oct 26, 2016.
  1. Nov 19, 2016 at 2:46 PM
    #701
    Socaltacoma1224
    Socaltacoma1224 Active Member
    Encinitas
    PreRunner
    The tank needs to be sitting upright as in the rips in the back need to be facing up and down. The exact way it sits in the product photo on the website. As you use the tank the pressure slowly depleates. The tank is designed to mimic a bladder. It uses the built up air inside to force all the water out. As you use the system it slowly looses pressure as it forces the wateR out. One other thing is some customers take of the y-valve and thread on the quick connect, this will ruin how the system works. Without the y-balve the system will empty itself. It is also important to make sure the on/off valves are turned to the off position when it's not in use. If the tank is not sitting in the upright position, top cap facing toward the ceiling, you will only be able to get a 30-40 seconds of use! If the tank is sitting correctly you should get 1.5 minutes of pure spray on the shower settings. Again 3.3 gallons isn't large, the idea is to conserve as much as you can. I use mine mainly for surfing and it will last me 3-4 uses(10 seconds showers). Remember the most important part is that the tank needs to be sitting with the top cap towards the ceiling. If you try and use it with the back ribs on the ground it will not work correctly and you will only have 30-40 seconds of use!!
    dtaco06 likes this.
  2. Nov 19, 2016 at 2:54 PM
    #702
    Bruce988jl
    Bruce988jl Well-Known Member
    Southern NH
    08 Tacoma Dbl Cab TRD Off-Road & 05 Mitsubishi Evo
    Looking forward to the email response about my missing sprayer nozzle and leaking y-splitter. Glad to see a vendor posting up responses!
  3. Nov 19, 2016 at 4:09 PM
    #703
    Socaltacoma1224
    Encinitas
    PreRunner
    Hi Bruce,
    Just responded to your email, Ill have them both expedited to you Monday, Sorry for the inconvenience.
    Adrian
    Bruce988jl likes this.
  4. Nov 19, 2016 at 4:50 PM
    #704
    Pirhett
    Pirhett [OP] Instagram @pirhett_ship
    Rhett
    San Diego
    2014 TRD Sport 4x4 DCLB MGM
    Stock...
    Sje1124 likes this.
  5. Nov 19, 2016 at 5:25 PM
    #705
    Pirhett
    Rhett
    San Diego
    Stock...
    Hey guys, if the tank doesn't work properly contact Adrian for a full refund in exchange for the tank. No partial refunds or anything special like that. Hopefully we can get everyone to be fully satisfied.
    itaro likes this.
  6. Nov 19, 2016 at 6:03 PM
    #706
    Robman
    Robman Well-Known Member
    Rob
    Hawaii
    '14 Tacoma Double Cab
    Thanks and get back to your vacation.
    Pirhett[QUOTED][OP] likes this.
  7. Nov 19, 2016 at 6:11 PM
    #707
    Socaltacoma1224
    Encinitas
    PreRunner
    One thing, People who are getting 40 seconds, one solution I found is that some people are holding the regulator to the quick connect. Make sure you slide up the quick connect, attach regulator(make sure you hear a click, that means its secure and air tight). THE WATERPORT WILL EXPAND, DONT BE AFRAID I HAVE REGULATED IT MUCH LOWER THAN ITS CAPACITY. ITS NORMAL IF YOU SEE THE TANK EXPANDING. The regulator will automatically shut off the water to the tank once full.
    Pirhett[OP] and itaro like this.
  8. Nov 19, 2016 at 7:46 PM
    #708
    Pirhett
    Rhett
    San Diego
    Stock...
    Thanks man, my gf didn't let me go on my phone from 4:30-this morning but I was able to sneak a view peaks
  9. Nov 20, 2016 at 1:49 PM
    #709
    XFitTaco
    XFitTaco Well-Known Member
    Mick
    Bucks county Pa
    2017 TRD Sport DCSB quicksand
    She stock
    Can I get a pm for option 4 :)
  10. Nov 24, 2016 at 5:08 AM
    #710
    Kennedyusmc
    Kennedyusmc Well-Known Member
    Christopher
    2017 Cement Pro
    Still waiting for it
    Ok- whose starting the WaterPORT Creative mounting location thread?
    I like the frame mount idea, up, in an under a c channel. Is there a way to extend the nozzle so I can lash it to the high side of a slider?
    Pirhett[OP] likes this.
  11. Nov 24, 2016 at 5:19 AM
    #711
    The Fluffer
    The Fluffer Keepin dick's hard and pussie's wet since 1990
    Andrew
    Scottsdale, AZ
    07 SWB X-runner /// 01 Jade Mica Tundra
    boughten
    Tested one last night filled it through the port on top with a hose and no regulator then added pressure via the air tap and it worked great.
    stumbles, Pirhett[OP] and XPOTRPR like this.
  12. Nov 24, 2016 at 6:40 AM
    #712
    WhiteNight
    WhiteNight Well-Known Member
    PDX
    13 DCLB SPORT
    Dynamat, Rigid E series 30", Rigid SR2 combo/Rigid grill, Redline elite hood struts, Clear Bra all over
    I am going to make some custom brackets to stash it right over the wheel well in the bed where the space is virtually useless to the bed rail. I'll post when I have it done.
  13. Nov 25, 2016 at 10:28 AM
    #713
    tacot0wn
    tacot0wn Mia San Mia
    CO
    07 DCSB on 35s. Slowly becoming #EAF
    I used steel banding to secure mine to the inside of my bedrack
    Pirhett[OP] and fatfurious2 like this.
  14. Nov 25, 2016 at 10:35 AM
    #714
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    How did that work out. Does it restrict the bladder expansion from pressurization? Do you have any pics to share of how you set it up?
    fatfurious2 likes this.
  15. Nov 26, 2016 at 12:41 AM
    #715
    Midship909
    Midship909 Well-Known Member
    SocaL
    13 MGM 4x4 OR 6speed
    group buy still going on?
  16. Nov 26, 2016 at 8:24 AM
    #716
    tacot0wn
    CO
    Nope, it's actually worked out really well, the notches on the waterport perfectly fit into this channel on the inside of the rack. I'm about to leave my parents to drive home, I'll take & post some pics later tonight.
    Digiratus[QUOTED] likes this.
  17. Nov 28, 2016 at 7:06 AM
    #717
    Robman
    Rob
    Hawaii
    Don't know if that thread ever fired up but wanted to share some pics from my mounting location.
    Installed behind rear bumper (empty)
    Filled with swelling
    Filling
    In use
    LogCabins, itaro and dtaco06 like this.
  18. Nov 28, 2016 at 7:57 AM
    #718
    jj_mgm
    jj_mgm Well-Known Member
    J.J.
    Tallahassee, FL
    2016 Tacoma TRD OR 4x4 MGM
    Morimoto HID Low Beams/Fogs, OEM Bed Mat, LED Interior Lights, Rear Diff Breather Mod, A/C Drain Mod, AJT Designs Knob, OEM Tonneau Cover, OEM Running Boards, ArcAudio Amp, AudioControl Processor, Focal Component Speakers, Memphis Subwoofer, TacoTunes Subwoofer Enclosure
    What kind of brackets did you use to mount it?
  19. Nov 28, 2016 at 8:19 AM
    #719
    Robman
    Rob
    Hawaii
    Fabricated from 1/8th inch flat stock. Cut with a plasma cutter and bent on a vice.
    Crom, ETXTacoma, itaro and 2 others like this.
  20. Nov 28, 2016 at 11:41 AM
    #720
    ETXTacoma
    ETXTacoma Someone gave me a plasma cutter.
    Steven
    Tyler, Texas
    2014 DCSB Tacoma TRD OR
    Very nice! I wish I had access to a plasma cutter...
    Side Note: What would be needed to pressurize this unit while using an ARB compressor?
