WaterPort Mounting - inside bed rail
Discussion in '1st Gen. Tacomas (1995-2004)' started by Beater_Bimmer, Jan 13, 2020.
  1. Jan 13, 2020 at 10:23 AM
    Beater_Bimmer
    Beater_Bimmer [OP] Well-Known Member
    San Francisco, CA
    2002 Tacoma 4x4 DCSB
    Hi all,
    Looking to get a waterport and install it for use when I go surfing/camping for some onboard clean water.
    I want a camper shell installed. Does anyone have one installed inside the bed rails? The issue is the 1st gen bed has no stock rails for mounting like the newer trucks.
    Looking for advice. I am considering mounting some cargo track with rivnuts then using that as a mounting surface. Of course, I'm most interested in the cheapest and easiest solution...
    Thoughts?
    Looking at something like this: https://www.tacomaworld.com/threads/waterport-tonneau-cover-diy-drop-mount-bracket.546691/
  2. Jan 13, 2020 at 10:44 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Easiest and cheapest solution:
    6 feet of 4" black ABS plastic pipe with a few fittings and an RV shower nozzle.
    https://www.rei.com/blog/camp/diy-car-top-solar-camp-shower
    If you have a rack/camper shell, mount it to the outside of the rack so the sun heats it up. Use a bike pump to pressurize it.
    I used rivnuts to mount my hi-lift to my bed, you could do something very similar for the shower if you're mounting it inside the bed.
  3. Jan 13, 2020 at 10:56 AM
    Beater_Bimmer
    San Francisco, CA
    Thanks!
    Looks like you made those nut plates yourself? I'd love to find a source for something like that, I'm less handy than you it seems.
    I currently have a DIY camp shower setup using a weed sprayer (hand pump to pressurize) and a hose/nozzle. Looking for something more permanently installed. Don't enjoy the look of the DIY tube on the outside of my rack.
  4. Jan 13, 2020 at 10:58 AM
    Beater_Bimmer
    San Francisco, CA
    May look for a less rigid mount like: [​IMG]
  5. Jan 13, 2020 at 11:34 AM
    jbrandt
    Justin
    Yeah, made them myself. The welds are atrocious, though. I've gotten better since then, lol.
    The brackets were really easy though. Just some ~1" wide 1/8" bar from home depot, a vice, hacksaw, and a drill is all you really need. You can even just bend the flat bar on a rock or something. Something like a light pole will give you a nice smooth bend.
    Honestly, I've seen some commercial options that look worse than the ABS pipe ones. You put them out in the open (like on the rack) so that the sun will warm the water.
    I just find myself cruising up and down the isles of home depot looking for various brackets, hinges or whatever that will help, so I don't fabricate everything form scratch.
    Kwikvette likes this.
  6. Mar 22, 2020 at 4:29 AM
    chrslefty
    chrslefty Well-Known Member
    chris
    Mesa az
    01 trd
    Stockish
    Hey were did you find this pic? I have this model water port and I'm trying to find a way to mount it
    Do thoes look like the old style quick fist straps??
  7. Mar 23, 2020 at 9:19 AM
    Beater_Bimmer
    San Francisco, CA
    Found it on some other TW thread. Search and you shall find yourself.
  8. Mar 23, 2020 at 1:22 PM
    chrslefty
    chris
    Mesa az
    01 trd
    Stockish
