Waterproof Fuse and Relay Boxes - RFRM (10 relay) & RTMR (5 Relay) no Blue Sea/ SPOD
Discussion in 'Buy / Sell / Trade' started by skygear, Jul 15, 2014.
Thread Status:
Not open for further replies.
  1. Jul 25, 2015 at 4:12 AM
    #1981
    weldo
    weldo Well-Known Member
    Pittsburgh, pa
    2014 base ac 2.7 5-speed 4x4
    Thanks for the info gents. I believe my truck has the plug harness wired for the locker (and maybe fogs, can't remember) even though I do not have that option, I should be able to use those dimmer wires. I have also heard that the led contra V switches won't dim properly without some sort of "module" or something. Any experience with this?
  2. Jul 25, 2015 at 4:42 AM
    #1982
    weldo
    Pittsburgh, pa
    Lastly, regarding pin 2 on the Contra V switches, I've seen from Skygear's pics that they can be daisy chained together, but where do you recommend getting power from? I was gonna go directly from the fuse box with a 15A fuse because the switches are labeled as 15A capacity. Or would I be better off just using a fuse tap to power all of my pin 2 terminals?
    And pin 8 just goes to a convenient ground, right?
  3. Jul 25, 2015 at 3:35 PM
    #1983
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    So what's the consensus on getting the led rocker switches to dim anyway? Do they dim "correctly"? The switches I'm currently testing have incandescent bulbs so they will dim for sure. But when I ever seem to get my rtmr outta sky I'm gunna use led switches, so....am I wasting my time with this dimming thing when I'm going to use led switches??
  4. Jul 25, 2015 at 4:13 PM
    #1984
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Yea the led ones dim, it's not as wife a range as incandescent but they do.
  5. Jul 25, 2015 at 6:56 PM
    #1985
    weldo
    Pittsburgh, pa
    Now that i think of it, aren't most of the dash lights led? I believe the instrument cluster is all led on 2012+, but they dim normally.
  6. Jul 25, 2015 at 7:10 PM
    #1986
    Sandman614
    Tim
    '06 SR5 Off Road
    05+ is led
  7. Jul 25, 2015 at 8:11 PM
    #1987
    Climbermac
    Climbermac Member
    Santa Fe, NM
    I just finished sorting out my indicators on a switch bank of 5 contura rockers. I am running a '03 Tundra: so things are a little different but not too much. I ended up running the indicator LED's off the hot from the cabin dim switch; so they are on with headlights, but won't dim. Then I just dropped a few resistors on that feed to dim down the LED's to a nice level. I found the switch indicators were much much brighter than my display lights so dimming them together would not work well. Honestly how often do you change the intensity of your display, I think I set them the first night I drove the truck and have never touched them since. Just my .02
    I will also say I need to post my finished install up here, I promised Sky I would once I finished the overhead switches. Maybe I can snap some pics tomorrow.
    HTH
  8. Jul 25, 2015 at 8:19 PM
    #1988
    Sandman614
    Tim
    '06 SR5 Off Road
    Yea the led switches are bright. Otrattw(james) warned me they would be when I asked for a custom switch. I need to drop a resistor in to bring them closer to the dash lights.
  9. Jul 25, 2015 at 9:10 PM
    #1989
    bry838
    oregon
    Yeah I'm worried the switches will be too bright at night that's why I'm trying to get em to dim down, when I get everything hooked up.
  10. Jul 26, 2015 at 3:52 AM
    #1990
    weldo
    Pittsburgh, pa
    what kind of resistors are you guys looking at? Those tiny little capsule shaped ones you can get from radio shack? Then I guess its a matter of trial and error til you find a resistor that provides the brightness you want.
  11. Jul 26, 2015 at 11:32 AM
    #1991
    Madjik_Man
    Colorado Front Range
    Okay, now we're getting somewhere for the 1st gens.
    @bry838, please report back.
    @skygear, when you say connect the positive and negative from the dimmer switch to the positive and negative on the back of the V1D1 switches, are the latter pos/neg wires the ones you have coming off the switch backs? Brown and white (if my memory serves me correctly).
  12. Jul 27, 2015 at 1:12 PM
    #1992
    weldo
    Pittsburgh, pa
    Woot! Made some switch backs! What a pain this was. Got the hang of it toward the end though. They came out nice. I'm gonna put them in the 3 blanks I have left of the steering wheel.
    The green wire goes to dimmer +, white to dimmer -, red to +12V and black to ground. The grey, blue and purple will go to their respective relays.
    Kudos to you Sky for doing this add nauseum. It's tougher than it looks.
  13. Jul 30, 2015 at 5:20 PM
    #1993
    skygear
    skygear [OP]                    
    Nice. Yes. Connect the + & -
  14. Jul 30, 2015 at 5:22 PM
    #1994
    ttran076
    ttran076 Well-Known Member
    Orange County, CA
    2014 Tacoma Sport 4x4
    Kings, TC UCA, Dakars, Prinsu rack, ARB Snorkel, Method NV, Wildpeak AT3
  15. Jul 30, 2015 at 6:07 PM
    #1995
    skygear
    skygear [OP]                    
    Ok. Just brought on some help and will get to the emails tonight. Making great progress today.
  16. Jul 30, 2015 at 6:33 PM
    #1996
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    Emailed you too last week. Hope to hear from you. Order 2778. Thanks bud.
  17. Jul 30, 2015 at 7:33 PM
    #1997
    Jiveydude
    Jiveydude Well-Known Member
    Micah
    OH
    04Taco
    Stuff and things that make it better.
    If it helps, here is how I got the dimmer (rheostat) to work with my switches (first gen 01-04):
  18. Jul 30, 2015 at 9:15 PM
    #1998
    Madjik_Man
    When you say:
    "One tap is on the white/green wire and the other is on the green/red one"
    Is that coming off the back of the dimmer knob on the dash? Pretty sure my 1998 has different colors coming off of it.
  19. Jul 30, 2015 at 9:16 PM
    #1999
    Madjik_Man
    @skygear - was that in response to me?
  20. Jul 30, 2015 at 10:04 PM
    #2000
    bry838
    oregon
    When you say:
    ^^^^^yeah me too! And I only have two wires off the back of my dimmer. Both of them white with green and black stripes. I'm a 2000 though, could be a 3rd gen 1st gen thing having the third green wire maybe?
    Sorry for the funky quote I was playing around with how to post, quote, copy and paste.....
Thread Status:
