Waterproof Fuse and Relay Boxes - RFRM (10 relay) & RTMR (5 Relay) no Blue Sea/ SPOD
Discussion in 'Buy / Sell / Trade' started by skygear, Jul 15, 2014.
Thread Status:
Not open for further replies.
  1. Aug 3, 2015 at 7:10 PM
    #2081
    Madjik_Man
    Colorado Front Range
    Holy F'in crap dude.
    How did I miss this post of yours? You gave me the answer days ago.
    At least I bought a $3 handy tool and actually used it to find my answer.
    Thank you in arrears.
  2. Aug 3, 2015 at 7:17 PM
    #2082
    Madjik_Man
    That is correct. I have the 3.4 with a 5-speed.
    Both I just tested that dangling connector and it definitely only comes on with the parking/headlights and dims with the dimmer. I have no clue wtf that is for.
    For s and giggles I tested that thing. It's constant hot. Door open, door shut, truck off... it lights up the meter constantly. Dafuq is that too?
  3. Aug 3, 2015 at 7:26 PM
    #2083
    Madjik_Man
    @skygear
    Just to confirm. The brown and white wires coming out of the first switchback are for dimmable illumination. Brown = (+) and White = (-)?
    Here are two pics of what I'm talking about.
  4. Aug 3, 2015 at 7:58 PM
    #2084
    Mako99
    Mako99 Well-Known Member
    Virginia
    2012 Taco Sport
    Sky gear.......sent a pm to you with no response....paid back in February. What's the deal?
  5. Aug 3, 2015 at 8:45 PM
    #2085
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Shoot him an email, he's busy working on all the back orders and doesn't check in here super often. Also, he asked for that in the OP :D
  6. Aug 3, 2015 at 10:53 PM
    #2086
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    That's weird its always constant hot! I'm still 99.99% sure its for your ignition ring and the fact you don't have one means there will be an empty connector hanging there. I'm curious though, I'm gunna test mine next time I'm in there and check it out, should be soon. Whenever I get my box and have a day to install it.
    Oh!! and I have that same connector that you found that has dimmable power just hanging around in the same area!!! Thats what i used for my G-R wire. Mine is a lil different but....Has four wires instead of three, Its that flat connector to the right of the two wire dimmer connector I unhooked (for the pic), in that last pic I posted. But its sure a convenient place to get our dimmable illumination(first gen)!!! Don't have to tap into and mess around right behind the dimmer, just utilize the W-G from that connector instead, along with the G-R as your positive. Easy shmeezy. I do suppose not all first gen just have that connector unused though, for whatever its for?? But if its hanging there it just became very convenient dimmable illumination for all your rocker switches or any lighted switch for that matter.
  7. Aug 4, 2015 at 12:12 AM
    #2087
    bry838
    oregon
    If those two wires will make contact with pins #6 and #7 on your rockers then they are for sure illumination wires. Those two pins are on the right side of the switch, the side with just two pins, one at the top and one at the bottom.
    Then of course
    Pin#6 is positive... G-R wire
    Pin#7 negative... W-G wire
    ^^^^^^First Gens^^^^^^^
  8. Aug 4, 2015 at 9:36 PM
    #2088
    bry838
    oregon
    So the other day I broke my second switch face off. About a year ago I had seen some real nice thin gauge round stock made into u shape switch guards. Thought they were on otrattw but didn't see them there and having a hard time rounding any up. Couple options on eBay but they were semi circle style and Amazon didn't realy pan out either. I thought they would be pretty common but.....anyone have any recomendations??
  9. Aug 4, 2015 at 10:17 PM
    #2089
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Like this?
    http://www.periheliondesign.com/switchguards.htm
  10. Aug 4, 2015 at 10:22 PM
    #2090
    bry838
    oregon
    I did find those a bit ago! I like that design too! Cause the ones I was thinking about had flared ends with holes to mount with screws.
    It's kinda interesting how many of those things are marketed towards the aviation industry... I get it though, can't be "hittin switches" in the cockpit....
    JustinL likes this.
  11. Aug 5, 2015 at 6:44 AM
    #2091
    JustinL
    JustinL Well-Known Member
    Justin
    Berlin, CT
    2009 TRD OffRoad DCSB Pyrite Mica
    2012 Conversion
    Sorry but this:
    Reminded me of something like this:
    KenpachiZaraki likes this.
  12. Aug 5, 2015 at 6:48 AM
    #2092
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    Does anyone know if you can get DPDT relays that fit this box?
  13. Aug 5, 2015 at 11:42 AM
    #2093
    bry838
    oregon
    Hahaha
  14. Aug 10, 2015 at 12:45 PM
    #2094
    skygear
    skygear [OP]                    
    No, I do not believe so. The max pins are 5. Most DPDT that I have seen are 8 pin..
    To all. I ran out of 14gauge red and blue last week. Ordered them and They are in transit to me.
    T4RFTMFW likes this.
  15. Aug 10, 2015 at 12:48 PM
    #2095
    skygear
    skygear [OP]                    
    @Madjik_Man - Yes. I would still check your Switch wiring diagram.
    @Mako99 - I apologize. I will check shortly.
    @bry838 - Wire. That is the only thing stopping the shipment of your order. The Box is done. I reworked the switchbacks.
  16. Aug 10, 2015 at 1:25 PM
    #2096
    jowybyo
    Joe
    Baltimore, MD
    Thanks for the reply. You wouldn't happen to know of a similar box that accepts DPDT relays, would you?
  17. Aug 10, 2015 at 1:44 PM
    #2097
    Up2NoGood
    Up2NoGood Well-Known Member
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    What are you trying to accomplish? Sometimes you can just use two relays to accomplish the same as a DPDT... not ideal as it uses two of them but can work in a pinch.
  18. Aug 10, 2015 at 3:23 PM
    #2098
    skygear
    skygear [OP]                    
    None to my knowledge . However,
    Exactly
  19. Aug 10, 2015 at 4:30 PM
    #2099
    jowybyo
    Joe
    Baltimore, MD
    I converted my Prerunner to 4wd using the Tacoma (electronic shift) transfer case. I was too cheap to buy the ECU and I know a few controls engineers that helped me design a relay control logic circuit. It needs 6 DPDT relays. In some situations you can use two SPDT relays in parallel, but it's not guaranteed that they will switch at the same time. In my circuit, would need the two SPDT relays to switch exactly at the same time to avoid any problems. So I won't be able to use this trick.
  20. Aug 10, 2015 at 6:00 PM
    #2100
    Taco Guy11
    Taco Guy11 Well-Known Member
    Joe
    Western Maryland
    2020 Tacoma TRD off-road
    Any word on my order?
Thread Status:
